Thread: Monitor problem
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    Default Monitor problem
    I have a samsung 17 inch syncmaster 793df crt monitor which is currently using as a tv with a Gadmi tv card. The problem is when i bought the monitor home i saw the monitor power cord had a weird looking (3 pin covered with a plastic around it) connection and it wasn't fitting in any multiplug. So i took the power cord to a electrical shop and they cut the connection head and among the three wire they connected two wire with a third party 2 pin plug and told me it will work fine. I did that and it worked. One day when i was moving the antena i touched it i felt a electric shock. Then i tested it with tester and i found a electric flow. Then i disconnected everything from monitor and kept it on, when i tested the VGA connection with a tester i found electric flow. Means current was going through VGA connection to tv card and then to antena. So question is if i connect the monitor directly to motherborad or graphics card will it make any damage.
    no it wont. its not actually that much high to burn nything. 3 pin plugs have 1 earth , 1 neutral , 1 live. u only need the neutral & live wires to run anything. earth bypass excess electrons. if u dont connect it, it may give u small shock but not a big deal.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    Thanks for the answere. But is there any third party 3 pin plug available and will it solve the problem, just to be safe.
    • mmrozibul's Gadgets
      • GIGABYTE GA-X79-UD5 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
      • Intel celeron 1.8 GHZ :) :)
      • OCZ DDR3 PC3-12800 / 1600 MHz /Gold Edition / Triple Channel Kits 12gb
      • Crucial M4 CT256M4SSD2 2.5" 256GB SATA III and hitachi 2TB sataII
      • 2x ATI Radeon HD 5970 2GB DDR5
      • HYUNDAI 22" LED
      • Microlab 7.1
      • CORSAIR CH9000003UK Vengeance K90 Mechanical Gaming Keyboard
      • RAZER Ouroboros Elite Wireless Gaming Mouse - Black
      • Thermaltake Toughpower W0133RU 1200W ..
      • ASUS+SAMSUNG DVD Writer
      • 32 gb transcend pendrive 19mb write and 35 mb read speed. Usb HDD 2TB Transcend USB3
      • Windows 7 Ultimate X64 and win xp service pack2 dual boot( for SL3 Hash calculation)
      • not scored
      • Justify yourself
      • Banglalion 2 MBPS
      • 280 Kilobyte
      • 150 KB
    Oct 2011
    Khulna
    Ur 1st mistake is cut the main plug. There is a converter which converts 3 pin to two pin. And make a board which fitted with 3 pin that will be better and safe.
  1. CRT monitor problem
    By Cpt.Mactavish in forum Technical Support
    Last Post: March 12th, 2012, 11:18
  2. Monitor problem
    By wasi006 in forum Others PC Hardware
    Last Post: April 26th, 2011, 09:23
  3. Monitor Problem
    By zaman_177 in forum Technical Support
    Last Post: February 8th, 2011, 06:55
  4. Monitor problem
    By Dee in forum Others PC Hardware
    Last Post: October 5th, 2010, 08:51
  5. Monitor Problem
    Last Post: June 11th, 2010, 07:18
Page generated in 0.16507 seconds with 14 queries.
