Thread: need a cpu cooling fan urgent !
    Cool need a cpu cooling fan urgent !
    my processor's (core i5) cooling fan's pins are broken... crap plastic pins
    suggest me a cpu cooling fan ! i am not interested to oc atm. so i need a normal cpu cooling fan .. highest temp 65~ acceptable?
    price 1000-2000 tk er moddhe hole valo hoy
    pls reply asap !
    Turn to Allah before you RETURN to Allah
    Quote Originally Posted by saif View Post
    pls reply asap !
    whats ur processor model? Only saying Core i5 doesnt mean a $hit.
    core i5 750... 1st gen
    get a low quality cooling fan for 1156socket. it will cost around 200-250 taka. make sure to use thermal paste properly. first clean it, then reapply.
    or spend more money to get something better.
    & crappy plastic pins... ive also done the same!
    As you can spend 2k then add 1k more and buy a cm 212 cooler. That will be a permanent solution
    Gimme 500/= and your broken fan, I'll have it working plus I'll treat us both half a grilled chicken plus coca cola! It's simple man, buy a cheapo cooler, get those plastic pins off it, and have the original fan working again, and voila!
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by BFG9000 View Post
    tempting deal ... ! amr ta vangle valo hoto
    pls reply asap !
    bhaia just a tip .. u can use gadget like coretemp ... there is tjmax which shows the( daamage level ) max temp for ur cpu max temp 65c .. (acceptable under load though ) buuut ... recommended action : buy new or repair / replace pins asap .
  1. Laptop - Cpu Cooling fan
    By optimus prime in forum Technical Support
    Last Post: December 10th, 2012, 19:31
  2. Sale (New) Some Cooling Fans For Sale
    By codename5302 in forum Shop - Gadgets
    Last Post: June 16th, 2012, 13:36
  3. availability of cpu cooling fan in bd
    By pallab7 in forum Others PC Hardware
    Last Post: March 17th, 2011, 02:41
  4. Want to Buy Thunderblade Cooling Fan
    By Extreme Noob in forum Shop - Gadgets
    Last Post: January 1st, 2010, 13:04
  5. About GPU cooling fan speed
    By Extreme Noob in forum GPU
    Last Post: December 21st, 2009, 13:07
Page generated in 0.19707 seconds with 14 queries.
