Results 1 to 11 of 11
Thread: WiFi HELP!
    • Mahir97's Gadgets
      • Gigabyte H61-S2V-B3
      • Core i5 2400
      • Twinmos 4gb
      • Hitachi 1 TB + Samsung 320 GB
      • Sapphire HD 7770 GHz OC 1gb DDR5
      • Samsung Synchmaster B1930 19"
      • On Board
      • Microlab M-111
      • A4Tech KR-83
      • A4Tech x6 Office
      • Logitech f510
      • CoolerMaster 550w 80+ BRONZE
      • ASUS DVD-RW
      • Lexar 8GB, A4Tech Webcam, Transcend 320GB portable HDD
      • Luminous 1000va
      • Windows 7 64 bit
      • OK
      • 60-70 KBPS
    Mahir97's Avatar
    Default WiFi HELP!
    How can I make a wifi hotspot of my own? Better question is CAN I? I am a total n00b in this matter (dont even know if I spelled wifi right). Please help me out.
    If you are making wifi hotspot from 3G/EDGE connection, android smartphones can do it. Or you can buy a MiFi.
    http://www.amazon.co.uk/Mifi-Devices/lm/R219C7UKNUW0BJ
    If you are making wifi from Qubee/Banglalion modem that has RJ45 LAN port, any wireless router will do it. Or you can get a portable router too like this and power from usb or power pack http://www.amazon.co.uk/Link-TL-WR70...6368610&sr=8-1
    You can make a wifi out of 3G/EDGE usb modems with a device like this
    http://www.amazon.co.uk/TL-MR3020-Po...6368610&sr=8-2
    • salmanshah's Gadgets
      • MSI Z97 Gaming 5
      • i7-4790K - Cooled by Corsair V8 GTS
      • G.SKILL Trident X Series 2400MHz 32GB (4 x 8GB)
      • Samsung 850 EVO 250GB SSD (2TB + 3TB HDD)
      • MSI GTX 970 GAMING 4G
      • Sony KDL-32W654
      • Sound Blaster Z PCIe Gaming Sound Card
      • Sennheiser HD555
      • Thermaltake MEKA G-Unit
      • Steelseries Sensei
      • Microsoft Xbox 360 Wired Controller
      • Corsair TX650w V2
      • Power Saver 1200va
      • Windows 10 PRO Retail key
      • Winrar bench - 11085 KB/s @ OC CPU
      • Casing: NZXT Phantom 001W
      • Radiant Telecommunications
      • 6 - 24 Mbps
      • 6 - 24 Mbps
    salmanshah's Avatar
    Lalbagh
    Goto Multiplan and buy a router which supports USB port for WIMAX.
    Just setup it as per the instruction of manual.
    Its very easy.
    • Mahir97's Gadgets
      • Core i5 2400
      • Twinmos 4gb
      • On Board
      • Microlab M-111
      • A4Tech KR-83
      • A4Tech x6 Office
      • Logitech f510
      • ASUS DVD-RW
      • Luminous 1000va
      • Windows 7 64 bit
      • OK
      • 60-70 KBPS
    Mahir97's Avatar
    OK, then please suggest me a router for my BanglaLion USB modem. I recently bought an Android device and i really wanna use wifi on it.
    Price should be as low as possible.
    Please suggest me a model no. with the price. (suggest from local shops website, please..........)
    THANKS IN ADVANCE
    tp link er ekta router pawa jai price 1.5k,model ta ektu pore dissi ,multiplan e paba.
    The router USB ports are for HDDs to be mounted for central file sharing, very rarely have I seen an actually functional 'bus interface.'
    Quote Originally Posted by Asif 11 View Post
    Tp link TL-WR720N।
    • Mahir97's Gadgets
      • Core i5 2400
      • Twinmos 4gb
      • On Board
      • Microlab M-111
      • A4Tech KR-83
      • A4Tech x6 Office
      • Logitech f510
      • ASUS DVD-RW
      • Luminous 1000va
      • Windows 7 64 bit
      • OK
      • 60-70 KBPS
    Mahir97's Avatar
    Tp link TL-WR720N।
    Is there any USB port in it?? If not then how am i supposed to connect my BanglaLion USB with it??
    Quote Originally Posted by Mahir97 View Post
    you can't. you have to get something like this products
    http://www.tp-link.com/en/products/?categoryid=202
    two months ago I checked the price of TL-MR3020 at IDB 3800tk. available at level 4 shop beside UCC.
    Is this nano router available in dhaka? If yes, whats the price range?
    Life wasn't meant to be 2D..
    The nano router is available at bd. TL-MR3020 model @3800tk with usb modem support. check if it supports your modem, there is a webpage with list of supported modem. this model has three modes(Router, AP) which can be configured.
    there is another one without usb modem support TL-WR702N and I have this one. this one has five modes (Router, AP, Repeater, Client). this was 2800tk at IDB two months back.
  1. Need help regarding WiFi Router
    By Noropishach in forum Technical Support
    Last Post: November 9th, 2012, 03:37
  2. WiFi ND utorrent
    By [email protected]$t3rz3r0 in forum Internet
    Last Post: November 3rd, 2012, 16:11
  3. Wifi router within 6.5k
    By ochin in forum Help - General Shopping
    Last Post: September 19th, 2012, 23:16
  4. Need help about routing wifi
    By SK in forum Smile/BDCom
    Last Post: July 30th, 2012, 20:15
  5. Wifi issue
    By aayman in forum Technical Support
    Last Post: November 1st, 2011, 02:52
Page generated in 0.21990 seconds with 14 queries.
