Thread: TT Lite Power 500W for a 7850 OC!!!
    • Ghost Riley's Gadgets
      • ASRock Z370 Extreme 4 [Case: Thermaltake Commander GS-II black]
      • Intel core i5 8400 @ 3.9Ghz
      • Corsair Vengeance LPX 16GB @3600Mhz (Dual Channel)
      • Toshiba 2TB
      • Sapphire RX480 Nitro+ 4GB
      • Dell S2216H IPS panel (1920X1080)
      • Creative X Fi Titanium
      • Edifier R2000DB
      • A4 TECH KR-85
      • Havit-MS736
      • Antec Neo ECO 650M [80 PLUS BRONZE Certified]
      • Samsung SH-S223
      • Transcend 32GB USB 3, Adata C906 32GB USB 3, Adata UV120 32GB USB 3
      • https://valid.x86.fr/bench/5bqlvf/1
      • ochcham
      • Alpha Broadway
      • 130-150 KBps
      • 100-150 KBps
    Ghost Riley's Avatar
    Narayangonj
    Question TT Lite Power 500W for a 7850 OC!!!
    Is a TT Lite Power 500W enough to handle a 7850 OC with i3 2120?? it has 36A @12V
    http://www.thermaltake.com/products-...?id=C_00001857
    Another option is TT Lite Power 600W, it has 40A @12V
    http://www.thermaltake.com/products-...?id=C_00001859
    TT Lite Power 500W is 4700
    TT Lite Power 600W is 5500
    TT Smart 550W is 7200 right now
    Do NOT go for the Litepowers. Why and why not, im not going to that discussion as it will take huge amount of time and writings regarding your current knowledge level.
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    if you short on budget then
    1) wait for a few days and get some extra money>>buy TT smart 550W or CM GX-550 (if available, i'd take this one as performance is roughly same and costs less)
    OR
    2) if you dont want to wait then buy TT litepower 600W. its basically a 480W PSU. if you run it with a quad core processor, your system will run and wont get your system fried but you may not get good results with it (eg. frequent restarts during heavy load)
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Really don't go for Litepowers, if you can at least get a TR2
      • built-in
      • CM GX650
    yes TR2 is another good option..and for LP the efficiency is ~70%!!!!!!!!! which isn't going to be good for you in long run
  1. Sale (Used) Cooler Master Extreme Power Plus 500W PSU
    By emroz_2272 in forum Shop - Gadgets
    Last Post: August 1st, 2012, 17:19
  2. GPU upgrade to ATI 7850
    By Tarequl Sifat in forum GPU
    Last Post: July 11th, 2012, 12:50
  3. Sale (Used) Thermaltake Lite Power 430
    By MaDDy in forum Shop - Gadgets
    Last Post: June 8th, 2012, 14:11
  4. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  5. Sale (Used) Value top 500W Power Supply for sell
    By iceman™ in forum Shop - Gadgets
    Last Post: March 8th, 2011, 17:51
Page generated in 0.17049 seconds with 14 queries.
