Results 1 to 15 of 15
Thread: A Very Big Mess, help needed on router and banglalion connection and nintendo wfc
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    Wink A Very Big Mess, help needed on router and banglalion connection and nintendo wfc
    Hello i am in a bit of a quandary basically, i have a banglalion usb dongle and a laptop which i use my internet on, and then on the other hand i have my Cisco WRT310N V2 Router and my Nintendo DS lite, what i basically want to do is connect my bangalion internet to my router so i can use it to connect my Nintendo DS to Nintendo WIFI Connection(to play pokemon, call me what you will), and on a side note how much is the resell value of the CiscoWRT310N v2 in bangladesh, and also tagging @Codex you seem to know a thing about networking.
    /facepalmiting title (call me what you will) xD
    On topic: Just configure your router to access Internet from your BL modem, and set up a wireless connection under the router's wifi section and connect your DS using the acc/pass.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Look i'm no expert in routers or networking so i have no clue as to connect my router to access internet from my bl modem and set up a wireless connection under the router's wifi section and connect me DS using the acc/pass, and way someone can do a step by step guide for this.
    >USB Modem >Cable router
    Nope. You need something that can take the USB and convert it into normal Ethernet, Windows' ICS comes to mind.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Should i use a ethernet or a USB cable to connect from my router to laptop, it seems i cannot access http://192.168.1.1/ which is my routers homepage.
    Connect usb modem to laptop, connect router to laptop, use ICS, configure ICS.
    This is not easy and requires a ton of manual config to work. Easier would be connectify direct from the laptop.
    See - http://www.connectify.me/
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Ahhh i spent 4 hours trying to connect the router to my xbox via a lan port/wan port and that doesn't even work,getting dns errors and some other crazy ¤¤¤¤, but @Codex is it possible to connect my blion internet to my linksys router so i can connect it to xbox or iphones, or do i need a broadband connection like link 3.
    Get a wired Banglalion modem, or one of the broadband connections. It's not worth all the hassle, and you don't look like you have the experience needed to configure ICS correctly.
    Go the easier path, will help your sanity.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    I Heard you can't connect a banglalion dongle with a wireless router is that true @Codex , even when i goto the routers homepage i don't see any internet ip all the values are 0.0.0.0 and i tried ics i can connect a ethernet cable directly from laptop to xbox and then it will work but i can't when its laptop>router>xbox.
    You can do everything as long as you know how to. But yes, in this case, let's go with impossible.
    Get a indoor unit.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Get a indoor unit.
    Would it be possible in a Broadband connection such as link3 or ispros.
    Yes, it would be. I've said that a couple of times already
    You can do it with Banglalion's Indoor Modems (The larger units, basically) too.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    6.8k for a indoor unit, heh i guess it'll be better to get broadband.
    Don't they have the 3k modems around anymore? I'm pretty sure I saw them around a few days ago, hm...
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Uhh nope, the cheapest i found in clickbd was about 5k and the 4k routers have unpaid bills, say should i sell this router, the prices in ryans are like 13.5k, so i could probably rake in about 7k at the minimum and get the indoor blion modem/router, or is it worth keeping.
    WAIT, i TAKE EVERYTHING BACK,after seeing a post about how to getting youtube to work in bangladesh on google, i finally realized my mistake, connecting the internet to my router and then distributing it among my devices wasn't impossible NOTHING IS, all i had to do was set both my blion connection and router configuration to google public dns and disable NAT and any type of security(the only con about it) in the router and increase the range on my router to 100 ip's and now i can SUCCESSFULLY connect my DS lite and xbox 360 pro to the internet simultaneously and even while i'm browsing on the net, and your post saying it was impossible really encouraged me to give it one last shot and i succeeded.
  1. Replies: 21
    Last Post: September 29th, 2012, 18:57
  2. Want to Buy Banglalion WiFi Router - Anyone wants to Sell?
    By jnathan in forum Shop - Gadgets
    Last Post: September 4th, 2012, 23:32
  3. how do i share a broadband connection without router?
    By offcutter in forum Technical Support
    Last Post: March 29th, 2012, 03:16
  4. How to Connect Banglalion Internet with Nintendo WFC
    By TheNutKicker in forum Technical Support
    Last Post: March 26th, 2012, 14:51
  5. Wireless Router for Banglalion USB Modem
    By rezanur in forum WiMAX
    Last Post: November 27th, 2011, 00:45
Page generated in 0.25117 seconds with 14 queries.
