Results 1 to 13 of 13
Thread: Cpu overheating!!Help....
    Default Cpu overheating!!Help....
    nothing!
    Thermal paste is usually cheap enough, you won't need a cooler change.
    Open it up, clean the older gunk with iso-propyl alcohol (Can be found on most pharmacies), apply new paste in the line method (Google this), put it back in.
    Should get yourself fixed up.
    If it's making sounds, it's probably dirty as hell too.
    No, you can't see paste sticking out from the side, take it apart from the mobo to see if you really must.
    Alcohol is cheap, and is usually sold in pints/ounces, you'll have to figure out prices on your area.
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    there are some deepcool cpu coolers that are below 1k...if you have to change your stock cooler then you can take a look at them..and you'll need TP once you remove your stock cooler
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Get hexisol for cleaning. Priced at 32tk.
    Get the silver tube TP which is priced at 100tk
    Quote Originally Posted by Reznov View Post
    silver tube gula koi pawa jay? Ami khujsilam pai nai
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by Asif 11 View Post
    tp ki mirpur 1 e pawa jabe ,na gele kothai pawa jabe idb or ecs?
    Pentium e 5700 er genuine intel cooling fan kothai pabo? Koto rakbe?
    ECS BM computer 5th/6th flr e TP paben.
    Kintu Orgn intel coolr new pawa jabe bole mone hoena
    I have the orginal stock cooler for e5700 pm your price if it seems good then i will sell it to you
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    First off change the Thermal Paste(don't under/overapply it) and place your current cooler (after cleaning it) FIRMLY. If the temps don't go down than think about a new cooler. FYI if you bought a boxed e5700, it came with a 'original' cooler.
    • Ork7O's Gadgets
      • Asus Xonar DGX
      • Luminous 1000VA
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    yes i bought a boxed cpu nd i got original cooler . Bt can i get that in bd anywhere?
    Did you broke the current one or something? I don't think shops will sell the 'orginal' cooler without a cpu. Both comes in a box. Go for the deepcool Gamma Archar @900 from onix instead. Pretty good cooler for the price.
    shobai k rep. Eitar solution den. Ami intel dg41wv te ram 9-9-9-24 kor disi ar freq. 1066 mhz korsi ekhon pc on hocche na. Age silo 6-6-6-15 .ekhon eita kivabe restore korbo?
    shobai k req. Eitar solution den. Ami intel dg41wv te ram 9-9-9-24 kor disi ar freq. 1066 mhz korsi ekhon pc on hocche na. Age silo 6-6-6-15 .ekhon eita kivabe restore korbo? Plz help
    just put out your motherboard battery and again reset it and your system will be stock again. And dont try to play with bios setting specially if you are using intel reference board/ or others if you dont have any proper ideas about settings. And just buy a 50taka silicon thermalpaste or pepsodent white paste. .apply if on to the upper side of the processor and reset it properly and temperature and other voltage problem will be vanished
    Im gonna tell the same thing that everyone has already told!
    1. clean your heat-spreader(u can use a blower), 2. make sure there is proper amount of cooling paste in there (but i love hte idea of close up blue - dont get me wrong its just a joke) 3. make sure the heat spreader has proper tension(dont over tighten) 4. u can boost up the rpm of ur cooler fan from the bios... use the maximum value if its intel stock.
    if u want to change the previous thermal paste
    1. use Hexisol to clean older paste 2. apply new paste
    wtf, why would you use toothpaste? The thermal paste is a different material than tooth paste. Buy some from IDB. :/ And get the silver ones if you buying the non-brand. Or better yet, get some coolermaster/thermaltake TIM.
  1. Need help with i7 Overheating problem
    By bluenight in forum CPU
    Last Post: September 10th, 2012, 17:43
  2. Overheating problem.
    By Zamil in forum Technical Support
    Last Post: March 8th, 2012, 20:16
  3. help MSI N9800GX2 overheating problem
    By Cyber_Shot in forum GPU
    Last Post: August 21st, 2010, 05:50
Page generated in 0.23574 seconds with 14 queries.
