Results 1 to 6 of 6
Thread: Increasing speed using active trackers and Scrapetorrent
    • Necray's Gadgets
      • Gigabyte EP43-DSEL
      • Intel Pentium Core 2 Duo 2.8 Ghz
      • Transcend 4GB DDR2
      • Samsung 500GB SATA
      • ATI Radeon HD 4850 1GB DDR3
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • ASUS DVD Rewritable drive
      • Windows 7 Ultimate 32 bit
      • Smile Silver Package
      • 18
    Necray's Avatar
    Greenroad
    Default Increasing speed using active trackers and Scrapetorrent
    Use Scrapetorrent to find whatever torrent you're looking for. It shows up search results according to number of seeds.
    As for increasing torrent speed using active trackers- dunno if this helps, try this process out.
    => Once the .torrent file is downloaded, head over to BtReannouncer. Upload the previously downloaded torrent file in the upload section. What the site does is find alternative trackers for your torrent meta file. These trackers are then shown along with the original trackers. Select the extra trackers you'd like to add to your new metafile on the screen shown below. Then press the "Reannounce" button.
    =>Download the reannounced torrent file on the next screen
    =>Now head over to Torrenteditor. This site does the hard work of finding obsolete trackers for you. Upload the reannounced torrent file in the first page and press the edit button. On the next screen, the "tracker verification" would start. Bad trackers are demarcated by a red highlight. Cross off bad-trackers on this step
    => Scroll down and click 'update'. After the good trackers are loaded onto your new torrent file, download the final fruit of your labor by pressing the "Download" button.
    Credit goes to http://atunu.blogspot.com/
      • Asrock Z370 Extreme4
      • Intel 8700K @5.0ghz w/ Cryorig R1
      • 2x8GB Trident Z 3600Mhz @3200CL14
      • Phillips x2 HR
      • Zowie Celeritas II
      • Razer Viper Ultimate
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    Default Re: Increasing speed using active trackers and Scrapetorrent
    You dont need to do all of this. Just find the same torrent on another tracker with the exact name, then download it. Your client will automatically ask you to add the new trackers.
    • Necray's Gadgets
      • Samsung 20' LCD
      • Microlab 2:1
      • A4TECH
      • A4TECH optical
      • Thermaltake 500W
      • 18
    Necray's Avatar
    Greenroad
    But what you do manually by searching multiple trackers, just one site(BtReannouncer) will do that for you.
      • Phillips x2 HR
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    Thats true, but I dont think you need the torrent editor part. Your client wont connect to the bad trackers anyway as they will be offline.
    • Diego Maradona's Gadgets
      • AMD ASUS A40/A50 Series FCH
      • AMD E2-1800 APU Dual core 1.8 Ghz
      • 4 GB DDR3 1333 Mhz
      • Seagate 500GB
      • AMD Radeon HD 7340 512MB DDR3
      • 15.6'' backlit LED
      • Built-in HD audio
      • Logiteh 2:1
      • generic
      • A4 tech
      • My 2 Hand
      • nill
      • TSSTcorp CDDVDW
      • 4GB transcend V60 , 32GB transcend V90
      • nill
      • Windows 7 RTM 64-bit
      • 2^p-1
      • M.I.A
      • Smile 256
      • 20-25
      • 10-15
    Diego Maradona's Avatar
    MirPur 10
    piece of crap
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS Crosshair HERO VIII
      • AMD Ryzen 3950x
      • GSkill Trident Z Neo 4x16GB DDR4 @3733MHz
      • Lots of SSD
      • EVGA 980Ti 6GB
      • ASUS ROG 4k + 2x 1080p
      • Internal
      • Logitech Z906
      • Razer BlackWidow Ultimate
      • Logitech G903 x2
      • XBOX Gears of War Editions
      • Seasonic X 850W 80Plus Gold
      • Logitech C920; Blue Yeti
      • Emerson 3000KVA Online
      • Link3/Dot
      • 300000+
      • 100000+
    CvP's Avatar
    Arrow Re: Increasing speed using active trackers and Scrapetorrent
    Quote Originally Posted by BallBoy View Post
    piece of crap
    listen, ballboy, it is a good idea to behave politely esp. with persons you are not very familiar with.
    if you disagree with someone, try to respond like aayman did.
Page generated in 0.18436 seconds with 13 queries.
