Thread: Need help regarding WiFi Router
    • Noropishach's Gadgets
      • Intel Dg41cn
      • Intel Core 2 Duo E7400
      • 2 GB DDR2
      • 500GB + 1TB
      • Geforce 8600 :p
      • Dell 17" Widescreen
      • Creative 2.1
      • Normal
      • Asolei normal gula
      • Nai :p
      • TT 400w
      • Asus 24x DvD RAM. (1 week dhore nosto)
      • Windows 7 32bit
      • :p ae config er abr benchmark.. diya lojja paite or dite chai na
      • Get my work done thats it.
      • Brac Net
      • 24KB to 40KB (Majhe majhe 64-70KB o pai)
      • OMG wats that = it sucks
    Chittagong
    Default Need help regarding WiFi Router
    Just got back to BD for a short vacation. I am planning to setup wifi router at my home. The problem is from my ISP end they told me, they will not provide support to setup wifi device. I ve to setup the router on my own. I m kinda noob about this kinda things. My query about the issues are:
    • My isp is nt providing me real IP. I am connected via a fake IP although its fixed. (eg 172.16.50.40), Is it possible to configure such IP in router.
    • I remember trying to setup a router on my own long ago, I used the cd came with the router to put the IP although I was unable to find any option to put DNS address. Later I got help from a friend. (I had real IP on that moment)
    • From my ISP I was told that, If i setup a wifi router I wont be able to connect more than 1 device at a time. Is it true? My ISP didnt bind my mac address.
    • Is it possible for my ISP to track whether I m using router or not?
    • If I connect one of my device using CAT 6 cable and rest using wifi, do I ve to put IP on the cable connected device or it will get a IP automatically from router?
    • Any specific router you guys wanna prefer to buy? (I dont want to spend much for this, as I ll b leaving soon)
    Member xhossain22l's Avatar
    Apr 2009
    Mirpur-12, Dhaka, bangladesh
    I had the same kind of problem after buying a new belkin router. My old router was also belkin and i never had any problem until it burned. New router has some new technology which allow ISPs to prevent routing. Though I called the ISPs and they denied. I solved the problem by changing my ISP. I heard cheap routers like tp-link also solve the problem.
    Answer to your questions
    Yes
    New router configuration software are really user friendly. All You need is the information for WAN (Internet) connection which is provided by ISP.
    Yes its true. Its something they manage to do without MAC address
    Yes. You see they r really bad ppl .
    In LAN section choose DHCP = Enable to assign IP Automatically.DHCP = Disable to assign IP manually. DHCP is Enabled by default for most routers.
    You dont have much option in Bangladesh. Belkin works nice for me.
    Hope it helps a little
    [ I'm here to kill not to give hope ]
      • Intel Dg41cn
      • 2 GB DDR2
      • 500GB + 1TB
      • Geforce 8600 :p
      • Creative 2.1
      • Normal
      • Nai :p
      • TT 400w
      • Windows 7 32bit
      • Brac Net
    Chittagong
    Quote Originally Posted by xhossain22l View Post
    Thanks for the reply.
    Is it like that.. I wont b able to use internet via Ipad or my mobile (symbian) while my pc is turned on? One device at a time???
    Is it really possible? I am curious... All request or packets will go through the router from... Although those are from different device but in the end those will go via router's IP... .
    Apr 2009
    if there is a router then it may not work. Best way is to connect you pc directly. if you want to use ur pC via router then you may try DMZ=Disable option. Please let me know about your experience. I went through many pages in google. Most of them suggested to setup a proxy server then use a router to connect all your devices to the proxy server. in simple wards...use an extra pc which is directly connected to your ISP and then share the internet via router to other wireless devices. I didnt like the option because i have to keep the proxy and router online 24/7 to access internet.
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Intel Core i7 4770K @ 3.5GHz
      • 2 x 4096 MB Apogee DDR3 @1333 MHz
      • Crucial M4 64GB, 1TB Hitachi HDD
      • XFX Radeon HD 4830
      • Philips 190CW Brilliance
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Thermaltake TR2-RX 450W
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    If you can give Teamviewer access to your pc then i might be able to help you configure. Because there is a lot of small things to do.And BTW I can route almost any & every ISP net connection to my desire settings.
  1. Wifi router within 6.5k
    By ochin in forum Help - General Shopping
    Last Post: September 19th, 2012, 23:16
  2. Want to Buy Router + USB Wifi Adapter
    By aayman in forum Shop - Gadgets
    Last Post: August 22nd, 2012, 05:38
  3. Wifi Router with Qubee
    By abir in forum WiMAX
    Last Post: August 18th, 2012, 22:44
  4. Wifi router price
    By Cpt.Mactavish in forum Help - General Shopping
    Last Post: March 5th, 2012, 18:32
  5. Need Wifi Router within 3500tk
    By minitt in forum Others PC Hardware
    Last Post: August 27th, 2010, 03:48
Page generated in 0.17949 seconds with 14 queries.
