Results 1 to 12 of 12
Thread: Power consumption
    • gamer24's Gadgets
      • Asrock Z77 Pro3
      • Intel Core i5- 3570K 3.4Ghz
      • Corsair DDR3 2X4GB
      • Hitachi 500GB
      • Asus GTX 660 DCUII OC Edition
      • 1680x1050
      • Corsair CX600 V2
      • Apollo 1200VA
      • Windows 7 64-bit
    Sep 2012
    Default Power consumption
    Intel Core i5- 3570K 3.4GHZ
    Asrock z77 extreme3
    Nvidia GTX 560ti
    8GB ram
    HP2228h 22" Monitor 1680x1050
    1. How is the build?any suggestions?
    2.Which PSU should i use so that i have no problems even if i overclock? wattage and brand.
    3. I have seen few versions of the gpu - Twinfrozer/ DirectCUII/ Hawk edition, which one is the best? i have seen that HD7850 is new and better... but i know that AMD has driver issues and other problems..so people please tell me bad points about HD7850 so that i dont change my mind.
    4. I'll be using that pc and monitor... how many VA UPS should i use?
    5. Do i need to use a Good thermaltake Casing? Can i use normal casings?
    6. Will i be able to play upcoming games like (GTA V, WATCHDOGS, FAR CRY 3, NEED FOR SPEED Most wanted (2012) and others) at HIGH settings?
    Thanks
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    1)build is good...but taking a hd7850 will give u a performance increment nd less power consumption...
    2)Thermaltake tr2 550w...
    3)take the 7850 instead of 560ti...so far driver issues kono new user der kach shuni nai...
    4)dont have much idea on that...but so far as i know...1000va is more than enough
    5)ya...thermaltake or any good branded casing is amust..coz if u r getting these awesum oc-ing cpu nd a good mobo...ventilation in the casing should be decent...i would suggest taking the tt spacecraft or the inWin Mana 136...
    6)yeah u can..but some games may stutter coz both 7850 nd 560ti are not fully capable of running games at ultra in 1080p..which in ur case is almost 1080p(1050)
    Hope it helps...
    1. nice build,
    2. TT 550W/600W would be enough.
    3. personal opinion take the DCUII & haven't heard any driver issues so far. & yes 7850 will be better than 560ti.
    4. take 1200VA UPS but most important thing take an ups that has power factor of 0.8 minimum.( like mercury ) dont buy power guard,it has a power factor of 0.6 only. u can also buy rahimafroose.
    5.as u wanna overclock,so it will produce a lot of heat, so u better take one casing which got good cooling solution.
    6. yuup u will be able to run these games at full HD
    one more thing take minimum 1600MHz RAM.
    avoid 560Ti at all, at all, AT ALL cost!
    • wackedGUNZ's Gadgets
      • Gigabyte B75M-D3H [Case: InWin Mana 136]
      • Intel Core i5-3450 @3.1Ghz
      • Twinmos Mainstream 4GBx1 1600Mhz
      • Western Digital Cavier Blue 1TB 64MB Cache
      • Sapphire R7 260X 2GB OC
      • AOC i2269VWm IPS 21.5inch
      • Realtek Azalia ALC887
      • Microlab FC-360
      • Razer Deathadder 3.5G Black Edition
      • Corsair VS-450
      • Asus 24X DRW-24B3ST DVD Burner
      • Sentron 1200VA
      • Windows 7 Ultimate
      • lol...don't care!
      • nearly full :)
      • zxonline
      • 160kBps or 1.2mbps
      • same as above
    wackedGUNZ's Avatar
    lol, but yeah avoid 560ti; get 7850 specially the sapphire 7850. It has much better power consumption and performance plus its on the level of GTX 570!
    its the price what makes the sapphire the best contender, Gigabyte one is now 25k!!!! A##holes of SMART! >:
    • gamer24's Gadgets
      • Asrock Z77 Pro3
      • Hitachi 500GB
      • 1680x1050
      • Corsair CX600 V2
      • Apollo 1200VA
      • Windows 7 64-bit
    Sep 2012
    Default Price
    Thanks everybody
    Could you please give me the latest estimated price of the build i mentioned.
    Can i keep it under 60000tk including a PSU,UPS And casing?
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    I5 3570k...23k
    asrock z77...not sure...may be around 12k
    GPU..7850...21k
    8GB RAM...4k
    PSU...tt 550w...7k
    Casing...minimum...tt v4...3.5k
    UPS...no idea...
    TOTAL(without UPS):70.5k!!!!
    so not possible to keep it under 60k...reduce ur needs...
    He better switch to a non-k and B75 instead.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    u bet...mathae ura dhura chinta..but mal-patti o dhalte hobe dada ei spec er jonno... @gamer24
    • gamer24's Gadgets
      • Asrock Z77 Pro3
      • Hitachi 500GB
      • 1680x1050
      • Corsair CX600 V2
      • Apollo 1200VA
      • Windows 7 64-bit
    Sep 2012
    yeah, i see things are going away from my hand.
    The build i mentioned, i can use it happily and meeting high gaming requirements for 2+ years?
    there is a chance of reduced price if i wait a month?
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    well...with a core i5 3450..a B75 board..nd a HD7950...u can make ur pc future proof for 2+ years...buying an 3570k is foolishness...coz the Haswells r coming in 2013...so buying this costly cpu is gonna cost u mentally in the long run!!...
    oh nd yeah...a powerful cpu doesnt make a pc gaming proof for long run...a powerful gpu has this ability..Hope u get it!!!
    Quote Originally Posted by gamer24 View Post
    I would suggest waiting till January for he GPU...coz HD 8000 series is coming up...but u can buy the rest now...
  1. Computer Power Consumption and UPS Backup
    By Muhammad Zunaid in forum Technical Support
    Last Post: September 14th, 2012, 04:22
  2. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  3. Replies: 2
    Last Post: December 1st, 2010, 01:32
  4. Lets Calculte Our Pc's power consumption
    Last Post: November 21st, 2010, 01:31
Page generated in 0.23724 seconds with 14 queries.
