Results 1 to 11 of 11
Thread: Problem with OS
    • Saz1d's Gadgets
      • Gigabyte 880GM - USB3L
      • AMD Phenom II X4 965 @3.4 GHz (Black Edition)
      • Team 2+2 GB DDR3 1333 MHz
      • Hitachi 1 TB 7200 RPM
      • MSI Nvidia GTX 550Ti 1GB DDR5
      • Samsung SyncMaster SA350 LED Wide 22"
      • Realtec Built-In
      • A4 Tech HS-105
      • Deluxe
      • A4 Tech G3-230 (Wireless)
      • Xbox 360 Controller for Windows + Logitech Force 3D Pro
      • Delux 550Wt
      • ASUS 24X RW ll ASUS 16X QuieTrack
      • ProlinK
      • P*Star
      • Wndows 7 64 bit
      • What's dat???
      • Quite Decent :D
      • Banglalion Wimax
      • 90~120 kbps
      • 25~30 kbps
    Saz1d's Avatar
    Khulna
    Default Problem with OS
    well here's the problem...last week new kore win7 install dewar por je game e install kore run kori na keno highest 10 mintues por memory dump kore crash kortese. display driver and directx runtime duitai update korsi and new kono hardware o lagano nai....new kore OS 2 bar install korsi still the same problem...Can anyone tell me where is the problem ?
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by Saz1d View Post
    remove any antivirus u have , Mr AVG nd some others memory dump e ostad . get the drivers from original sites ... make a backup
    make sure u have an empty primary partition where windows will go ..... try another windows if u think necessary .... during install format ur drive of windows install ....
    lets hope for best , now. if it continues ....
    extreme measure >>>>>>>>
    all u need to do ( maybe if not a hardware failure) , get reqiured backups ...... onto it then ... partiton ur Hdd
    edit : generally antivirus makes driver issues (partly eating up them ................) if no hardware failure is there ............ Good luckk !
    • Saz1d's Gadgets
      • Realtec Built-In
      • A4 Tech HS-105
      • Deluxe
      • Delux 550Wt
      • ProlinK
      • P*Star
      • Wndows 7 64 bit
      • What's dat???
      • Quite Decent :D
      • Banglalion Wimax
      • 90~120 kbps
      • 25~30 kbps
    Saz1d's Avatar
    Khulna
    Quote Originally Posted by genocide_cutter View Post
    First I dont have any Anti-Virus installed.....ami different duita version form different DVD er win 7 install kore dekhsi....windows drive format korei install korsi
    and for the drivers..I've downloaded them from original sites....Still not working....Now HDD partition kora onek jhamelar...is there any other way to solve it ?
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    tumi kon OS setup diso???r BSOD ki shudhu gaming er tym ei ditese naki jekono tym e???
    • Saz1d's Gadgets
      • Realtec Built-In
      • A4 Tech HS-105
      • Deluxe
      • Delux 550Wt
      • ProlinK
      • P*Star
      • Wndows 7 64 bit
      • What's dat???
      • Quite Decent :D
      • Banglalion Wimax
      • 90~120 kbps
      • 25~30 kbps
    Saz1d's Avatar
    Khulna
    Quote Originally Posted by maheer.dhruba View Post
    Win 7...just gaming er time ei..onno time e sob thik thake.
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    Saz1d bhaia koto bit seta janao
    • Saz1d's Gadgets
      • Realtec Built-In
      • A4 Tech HS-105
      • Deluxe
      • Delux 550Wt
      • ProlinK
      • P*Star
      • Wndows 7 64 bit
      • What's dat???
      • Quite Decent :D
      • Banglalion Wimax
      • 90~120 kbps
      • 25~30 kbps
    Saz1d's Avatar
    Khulna
    32 bit...
    I think its a motherboard bios related problem, update your motherboard bios and that may help you
    • Saz1d's Gadgets
      • Realtec Built-In
      • A4 Tech HS-105
      • Deluxe
      • Delux 550Wt
      • ProlinK
      • P*Star
      • Wndows 7 64 bit
      • What's dat???
      • Quite Decent :D
      • Banglalion Wimax
      • 90~120 kbps
      • 25~30 kbps
    Saz1d's Avatar
    Khulna
    Quote Originally Posted by blood stain child View Post
    Well i cant find Q-Flash for my mobo to update bios which is gigabyte 880GM-USB3L...any idea where can i get it ?
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    32 bit...
    32 bit e amio ei BSOD er prob face korsilam...game er 10-15 mins er por auto BSOD....i would suggest switching to a 64bit OS as i did..
    try from this http://www.gigabyte.com/products/pro...?pid=3828#bios
  1. ups problem ???
    By Bijoy Faith in forum Others PC Hardware
    Last Post: April 24th, 2012, 00:47
  2. Nvidia Driver Problem or Graphics Card Problem ??
  3. IP looking Up Problem
    By rakibmukitur in forum Garena Central
    Last Post: October 8th, 2010, 20:29
  4. NFS Carbon NFS MW problem in 7
    By saadbillah in forum Older NFS Games
    Last Post: November 23rd, 2009, 16:46
  5. GTA IV problem, plz help
    By imran_z in forum Sand Box
    Last Post: July 31st, 2009, 19:56
Page generated in 0.22951 seconds with 14 queries.
