Thread: Need Help : Sleeping Dogs Black Screen Problem
    Arrow Need Help : Sleeping Dogs Black Screen Problem
    ami rsb present'r cd kinsi , then unrar korar por "HKship" a click korle , Black screen ashe n stuck hoye thake but sound hoy . . .. now ami ki korbo ? ? ? plz help . . .
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    tomar pc spec ki???sometyms its caused by the lack of juice...:/
    processor- dual core 2.6 ; Ram - 2 gb ; Graphics Card - msi gt 610
    Mother board - gigabyte g41
    Mother board - gigabyte g41 :/
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    may be its due to ur gfx card...it doesnot meet the system requirement for sleeping dogs..
    one advice,...try to update ur gadget section...it will be easier for bg members to give u suggestion...
    Quote Originally Posted by Sweet View Post
    Yes his gfx card is also an issue... way below than minimum requirments for this game.
    Tonmoy do you use crack 1.4 yet ? ...if not than u can try it. I bought softwere garden dvd and i have the similar issue .... but after using 1.4 crack ... games run smoothly.
    But vaiya'ra ; amar je Max payne 3 Smoothly choley :'( :'( and ami crack 1.4 ta DL korey Paste korsi . . .tao kono benefit pai nah !
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    Quote Originally Posted by Tonmoy View Post
    Well ami apatoto integrated gfx card e max payne 3 complete korsi..
    there r some games that doesnt run if the card is below the minimum req..
    here is the latest 1.5 patch link : http://www.skidrowgames.net/sleeping...e-skidrow.html
    if i m not wrong u hav pasted the crack file without running the patch first...u must hav to patch it first then copy the crack file...read full INSTALL NOTES...
    btw i havnt played this game yet...gonna try it soon
  1. Sleeping Dogs
    By Badhon in forum Sand Box
    Last Post: January 10th, 2015, 18:26
  2. sleeping dogs freezeing
    By arefin55 in forum General PC Gaming
    Last Post: September 26th, 2012, 02:37
  3. Sleeping dogs and darksidrs2
    By tapos in forum XBOX
    Last Post: August 30th, 2012, 01:31
  4. : Need help : Sleeping dogs
    By SK in forum Action-Adventure
    Last Post: August 24th, 2012, 05:45
  5. Replies: 1
    Last Post: January 22nd, 2012, 15:10
Page generated in 0.19873 seconds with 14 queries.
