Thread: Need solves for a lot of problems has started recently
    • sl0tR's Gadgets
      • H61M-S2P-B3
      • 6GB DDR3
      • Hitachi 1TB 7200rpm
      • Ecs Elitegroup nvdigia geforce 560
      • Samsun Syncmaster SA300 18.5 LED monitor
      • A4tech-HS-105 and A4tech gaming stereo headset
      • Normal A4tech keyboard
      • A4tech X7 XL-747H
      • Xbox controller
      • 600W
      • ADATA C008 8Gb usb2.0 , Transcend 500GB portable
      • Apollo 800va
      • Windows 7 Ultimate 32bit
      • Windows 7 score are average of 7.6? :S
      • M lovin it !! =D
      • banglalion wimax
      • 65KB-68KB (512kbps)
      • 20KB
    sl0tR's Avatar
    beneath a wormhole
    Default Need solves for a lot of problems has started recently
    OK First things first, here is my PC config
    Processor : core i5 2400
    RAM : 6GB DDR3
    GPU : Nvidia gtx 560
    PSU : 600W
    HDD : 1TB 7200rpm
    OS : Windows 7 ultimate SP1 Build 7600 32bit
    Problems : [ all of this problems still exists after re installing the OS]
    1) [SOLVED]
    2) Windows startup is taking way too long , this black screen occurs after it boots to the desktop. (tried installing the latest windows loader)
    3) [SOLVED]
    4) Am i supposed to get 5MB/s data transfer speed to USB devices such as pendrives or portable HDD? tried a lot of them but still the same low speed.
    and dont know about this but a friend of mine said this isnt normal having no l3 cache memory
    So any fix/solve will very much be appreciable!
    thanks in advance!
    Hi SlotR.
    What's the name of this so called "600w" you have? It's usually the motherboard when you have so many problems at once, chances are that it's failing or since CSS/DotA2 arefairly CPU intensive games, your processor is throttling maybe due to temps? When you reinstalled your processor, did you change the TIM(thermal paste)?
    Download "Prime95" for checking CPU temps, use it to find its max temperature under full load, and then download "Memtest" and test the memory sticks(RAMs) individually. Last but not least you can try a CMOS clear and install Win7 and carefully diagnost each component without adding variables such as softwares/virus affecting the results.
    virus nd ram er prob er jonno memory dump hoi. Amaro hoito nd somedays later the ram died. Nd i got trans. one.
  1. Replies: 0
    Last Post: November 2nd, 2011, 18:15
  2. there's been quite a few new members recently...
    By CvP in forum Member Central
    Last Post: October 16th, 2008, 12:50
  3. New Members Registered Recently
    By xk::v (G®immjaw) in forum Member Central
    Last Post: August 29th, 2008, 10:16
  4. Blogging Started......
    By WoH[AMON]~Lord SMS in forum Member Central
    Last Post: May 30th, 2008, 16:33
  5. We have started!!
    By SinEater in forum DotA Talk
    Last Post: May 8th, 2008, 10:01
Page generated in 0.15829 seconds with 14 queries.
