Results 1 to 13 of 13
Thread: Problem with Q9550
    • CODhunter's Gadgets
      • EVGA z370 FTW
      • i7 8700k
      • 16GB G-Skill RGB 3000bus
      • 128GB Corsiar SSD+2TB SSHD+1TB WD
      • EVGA GTX 1070 FTW
      • Samsung 23.6' 4K
      • WV-Klong
      • Razor elite
      • EVGA Supernova 650wat
      • Windows 10 (pirated)
    CODhunter's Avatar
    Nov 2009
    Default Problem with Q9550
    Help me ASAP plz
    ami ajke akta intel q9550 kinlam(2nd hand)
    Mobo: albatron PX-43
    prob: power button deyar somoy just 1sec ar jonno CPU fan r Powersupply fan gore thn stop. abar power dile same
    tobe amar ager q8200 thiki run kore
    aitar karon ki hote pare?
    Other spec:
    GPU Quadro FX3700
    PSU: Delux 45owat
    without GPU chara try korchi, no luck
    check cmos battary and bios config in mobo cirkit.
    Reset CMOS either via jumper or take out the CMOS battery and wait 10 minutes and then put it back in.
    I've a gut feeling that you either bought a dead processor or the motherboard isn't compatible with Q9550, and you may need to update your Bios, that Albatron Mobo has only one bios update AFAIK, and it doesn't update the list of supported cpu micro codes, just to make sure, check the processor out in some other mobo.
      • EVGA z370 FTW
      • i7 8700k
      • EVGA GTX 1070 FTW
      • Samsung 23.6' 4K
      • WV-Klong
      • Razor elite
    CODhunter's Avatar
    Nov 2009
    Quote Originally Posted by BFG9000 View Post
    i hope that processor isnt dead
    today i'll check.
    btw can u suggest me some chip mobo for this processor
    G31/G41 will be able to run this i guess.but ur motherboard should support this processor. hope u v connected this the heat spreader properly.
    A G41 mobo will do, G31s are no longer available in the market, if I were you, I'd look to sell off the Q9550 for 8~9K, add 5K more and buy myself a core i3 2100 and an ASRock H61 mobo, bang for the buck!
    Check this out:
    http://www.anandtech.com/bench/Product/50?vs=289
      • EVGA z370 FTW
      • i7 8700k
      • EVGA GTX 1070 FTW
      • Samsung 23.6' 4K
      • WV-Klong
      • Razor elite
    CODhunter's Avatar
    Nov 2009
    yet no luck has found
    • Arif69's Gadgets
      • Gigabyte H61 S2P B3
      • Intel Core i3 2100
      • Dell E1910H 18.5 Wide Lcd
      • VIA HD Audio Codec
      • Lexma LK7550P Slim
      • Logitech B100
      • Generic Usb Joystick
      • ITS 500 Watt
      • Samsung SH-224BB 24X
      • Transcend Jetflash350 16 GB
      • KS
    Quote Originally Posted by CODhunter View Post
    ভাই কোন দুঃখে q9550 কিনতে গেসিলেন :/ আর নিলেও নেওার আগে চেক করে নেন নাই কেন ? অন্য মাদারবোর্দে ট্রাই করে দেখেন কি হই
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    @CODhunter ...dead processor may b...but still..check it on another compatible mobo...
    @BFG9000 ..true that...
    • iftybbar's Gadgets
      • Gigabyte EP43-USB3
      • E5700 @ 4GHz
      • 4GB Transcend DDR3
      • Seagate 400GB
      • 8800GT/HD5450 (temp)
      • LG1641
      • Altec Lansing ATP3
      • Logitech Generic 104 key
      • A4 Tech generic
      • Generic Chinese USB controller
      • Coolermaster GX550
      • Liteon DVD-RW
      • Windows 7 Professional x64
      • BDCOM
    You might want to check if it's set properly - I remember this used to happen to me with my E6300 OC when the heat sink wasn't mounted properly. In that case it turned out the CPU was starting and overheating and shutting down, all in a second.
      • EVGA z370 FTW
      • i7 8700k
      • EVGA GTX 1070 FTW
      • Samsung 23.6' 4K
      • WV-Klong
      • Razor elite
    CODhunter's Avatar
    Nov 2009
    Quote Originally Posted by iftybbar View Post
    aita kivabe solve korchilen?
    btw amar mone hoy na heat nia kono prob ache,
    ahhh dekhi ki hoy
    • Camouflage's Gadgets
      • Gigabyte Sniper B5 B85
      • Core i5-4460 3.2Ghz with Deepcool Mini Cooler in Thermaltake 'Versa-2'' Case
      • Corsair Vengeance DDR3 1600Mhz 2*4gb
      • WD Blue 1TB 7200rpm
      • MSI Gtx770
      • Samsung 22'' Wide Screen LED-1920*1080
      • Creative Sound blaster Audigy 2ZS
      • Microlab 5:1
      • HP keyboard
      • A4Tech X7 XL-747H Spider
      • Corsair-HX650W-52A in single 12V Rail with 4 (6+2) pin connectors
      • HP DVD writer
      • Transcend Jetflash-16gb & Sandisk Cruzer 4gb
      • Apollo 1200VA
      • Windows-7-64 bit Ultimate Edition
      • Pro-7.6,GPU-7.9-Windows7 benchmark
      • Satisfied what i have
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    Heatstink proper contact na hleo pc boot hoina.Be sure of it.
  1. Replies: 5
    Last Post: October 30th, 2011, 01:01
  2. Want to Buy Intel Core 2 Quad Q9550 Processor
    By cyanid3 in forum Shop - Gadgets
    Last Post: April 7th, 2011, 03:04
  3. A mobo for Q9550
    By Xanadu in forum Motherboard
    Last Post: May 31st, 2010, 21:36
  4. Closed Q9550 + X38 Asus P5E, Bargain
    By Streamyx in forum Shop - Gadgets
    Last Post: December 2nd, 2009, 00:52
  5. Replies: 41
    Last Post: August 28th, 2009, 20:07
Page generated in 0.24102 seconds with 14 queries.
