Thread: Serious Problem.. Need help
    • Nirzhar Uchiha's Gadgets
      • ASrock B75 Pro3-M
      • Intel Core i7 2600 @3.40 ghz
      • 2x 4 GB Transcend 1333 mhz
      • Toshiba 1TB + Adata 128gb SSD
      • MSI GTX 770 2GB OC
      • LG 22MP65HQ 22" 1080p IPS LED
      • Creative SB X-fi Titaniium
      • On Ear: Sony MDR XB950BT / IEM: Soundmagic es18
      • Cooler Master Octane Keyboard
      • Logitech M280 Wireless
      • Xbox One + DualShock 4
      • Gigabyte Pulse 600w [80+ Bronze]
      • TechFine 1200VA
      • Windows 10 Pro 64 bit
      • Bought it on 5 may,2012 from elephant road.. upgrading started on February,2013 :)
      • SkyView Online [3 mbps]
      • 370 kBps [International] 11mBps [Local]
      • 200/200 kBps [International/local]
    Nirzhar Uchiha's Avatar
    Dhaka, Bangladesh, Bangladesh
    Default Serious Problem.. Need help
    details boli..
    At first ..u should know how my pc is connected to the power board
    1.soundbox,cpu connected to a multiplug (1)
    2.that multiplug (1) is connected to the ups
    3.the ups is connected to another multiplug (2)
    4.that multiplug (2) is connected to the main board..
    Now the problem :
    At today noon..when playing games..ups started beeping n showing ''backup''..but current chilo..then ups er plug ta khule multiplug (2) er onno plug e lagailam n it was fine..
    Then at evening..again the same prob..so ups theke pc er plug khule directly multiplug (2) e lagailam..now even weirder prob..pc 3 second er jonno connection pay..3 second pay na..then abar pay..mane continuous power paitese na..
    Another ajob thing is.. When ups shows ''backup'' .. If i switch off the ups...it shows ''charging'' meaning ups multiplug(2) theke power paitese..
    and Pc is working fine in ''backup''..so that means soundbox,monitor,cpu jei multiplug(1) e lagano..oita thik ase i guess
    I m confused.. Where is the prob.. Can anyone help? Can you @Vanguard bro?
    most probably problem is in your multiplug 2. Try connecting the ups directly to main board.
    After reading the first four lines....... i rest my case. Add few more multiplugs and you will be fine
    • areek's Gadgets
      • ASRock Z87 Extreme4
      • Intel Core i5-4670k CPU 3.4GHz
      • G.SKILL Ripjaw DDR3 1600MHz 2x4gb
      • Corsair Force LX 256gb + 500gb WD caviar green + 2TB WD caviar green + Kingston 500gb USB
      • Gigabyte ATI Radeon R9 280X Windforce 3X
      • Dell S2240L
      • Altec Lansing 2.1 speakers|| HIFIMAN HE400
      • Razer Blackwidow Ultimate Dragon Age II edition
      • Logitech G402 on QCK+ NaVi Splash
      • logitech drivefx axial feedback wheel
      • Thermaltake Toughpower gold 750W
      • Asus 24B1ST
      • Samsung ML-1666 laser printer, CanoScan Lide 25
      • yes
      • Windows 7 Ultimate SP1 64-bit
    বাংলাগেমার.কম
    Check the fuse of the UPS will you?
    • Sumit Pramanik's Gadgets
      • Asus Maximus V Formula With ThermalTake Armor A60 Chassis
      • Intel Core i5 2500K 3.3GHz with CoolerMaster Hyper 212X
      • GSkill TridentX - F3-2400C10D-8GTX
      • SanDisk Extreme SSD 120GB, WD Caviar Black 2TB x 2, WD Caviar Green 500GB
      • ASUS GeForce GTX 960 STRIX-GTX960-DC2OC-4GD5
      • LG 22MP68VQ-P 21.5 inch
      • Microlab B70 Speaker System; Sennheiser HD598SE
      • Corsair K95 RGB Platinum
      • Asus ROG Gladius II
      • Don't need one..........
      • Delta EX GPS-650AB B 650W
      • PowerTree S1250P 1250VA
      • Windows 10 Professional
      • Up-gradation Completed. Online. All system stable. Now I can sleep.
      • Quick Online (Earth Telecommunication Pvt. Limited)
      • 4Mbps
      • 4Mbps
    Sumit Pramanik's Avatar
    Oct 2010
    amio kisudin age eki problem face korsi. ei problem ta hoy jokhon cable gorom hoye jay (of course over load hoile). and cable gorom hoy jodi connection loose thake. Amar UPS porpor 2 multiplug diya main board e connected chilo. amar 2nd multiplug er cable pure gese gorom hoye.
    Then i bought BRB cable for 25tk/yards and conneted it with plug-socket. Its working perfectly fine. So you can try this. Let me know what happens...
    We all fall down
    We live somehow
    We learn what doesn’t kill us makes us stronger
      • ASrock B75 Pro3-M
      • TechFine 1200VA
    i have no other option but to connect the pc the way i m doing now.. Changed the 2nd multiplug..and it seems to b working..but 2 bar ups awaj korse for a second or so then it stopped..now pc running well
    I've the exact same setup, I've never had any issues for years.
    Probably was a faulty multiplug.
  1. Nvidia Driver Problem or Graphics Card Problem ??
  2. problem after OC
    By @nonymous™ in forum Technical Support
    Last Post: January 10th, 2011, 18:58
  3. is the problem in my ps2 or dvd?
    By eagle_gaze in forum PlayStation 2
    Last Post: January 9th, 2011, 20:30
  4. problem!!!!
    By Walking Death in forum Software
    Last Post: May 2nd, 2009, 11:22
  5. Got Problem
    By s.a_rocky in forum Older NFS Games
    Last Post: January 29th, 2009, 11:20
Page generated in 0.18548 seconds with 14 queries.
