Results 1 to 20 of 28
Thread: Problem with a speed of pc
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    Unhappy Problem with a speed of pc
    I bought my pc 3 months back...the config is given in my gadgets section...
    i was satisfied with my pc..although amar mon e ektu khotka lagtesilo due to the speed..at first speed valo chilo...took less tym for booting...bt dont know why it started getting slower...
    recently when i upgraded from win 7 32bit to 64bit...i feel lyk its taking too much time booting...about 40-60seconds is taken for booting up...the most tym is consumed in the welcome screen...the windows experience index now showed 5.9 in RAM...whereas it was 7.1 before the windows upgrade...
    i tried using MAXSMEM 2 for benching my RAM..here is the result...
    the results are almost same as before...just really consfused...
    plz guyz help me out....thnx in advance...
    mods der keu ki thread title ta change korte parbe???......"a" er jaegae "the" hobe...
    Your RAMs are just piece of ¤¤¤¤. Dual channel ei ai obostha!!! Phuck!!! Here is my TwinMOS ones
    That's why i again and again tell people not to use Transcends. Kintu ke shone kar kotha!
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Transcends are not bad (the pic is of a 2.5 years old transcend pair). May be your motherboard has some problems reading the rams.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    @Vanguard ....ya i can see that...but amar ram to single channel...dual channel dekhaitese ken???tomar bench o dekhlam...but amar kaam er kam to kisui hoilo na...any suggestions???
    @@bhi ....u sure motherboard er prob????
    Quote Originally Posted by @bhi View Post
    That higher rating is because of your i5 which has far better memory controller than i3, not that because Transcends are good. Check the fact first, then post please
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    bhai kono suggestions thakle dao...im in gr8 need for it....:/
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    he already mentioned he has single channel so his bench is perfect, and i3 die korle khub beshi hole 2k kombe.
    Quote Originally Posted by maheer.dhruba View Post
    nah if u have single channel those readings are ok and only thing left is windows, one of friend also has the same problem in 64bit windows i.e getting lower readings.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    thnx bro..so eta thik korar upae ki??will i have to add another 4gb ram???
    @maheer.dhruba things you need to do:
    1. Update the motherboard bios by using atBios software from GIGABYTE official website, do this with caution as improper bios update may lead your motherboard permanently damaged.
    2. Unplug the RAMs and reinstall them.
    3. Install intel INF update.
    4. Re run the benchmark.
    How is it supposed to be comparable when you are running them at 8-8-8-24 while he is running at 9-9-9-24? Naturally yours would yield higher scores.
    Quote Originally Posted by eXcavator View Post
    that only matters with the latency.
    If I'm not wrong, it also effects the Copy/Read/Write speeds. Though if you can, then prove me wrong by showing a benchmark at CL9-9-9-24.
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    lower delay/latency => higher data transfer rate(read/write/copy...etc) since it reduces execution time of per instruction.....
    you have rams, you have computers, so try by yourself
    Quote Originally Posted by @nonymous™ View Post
    now dont say reducing CL by 1 would result in 9GB/s bandwidth reduction
    I did, and there is a difference.
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    the OP has SINGLE CHANNEL .
    Then we should stop arguing about that matter right now. The issue is elsewhere.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    I have single channel transcend 1333mhz ram(i dont know why the software is showing dual channel)...but ei karone ki win7 64bit er WEI e amar ram rating komar kotha???32bit e 7.1 dekhato..but now 5.9
    amr ram er bepare ato valo knowledge nai..tai onek terms shombondhe ami jani na..plz guyz tell me what to do... @ @Abhi , @eXcavator ,@@nonymous™ @Vanguard
    Do you use cc cleaner? If you , then clean your temporary files and fix your registry, hope this will help you and also what antivirus you using ? It can be a virus problem too .
    WEI is bullshit anyway, stop using it.
    Maxxmem is showing false readings on my end too.
    If your PC is working fine, then just forget about it.
  1. need For Speed problem
    By zaibi1230 in forum Speed Talk
    Last Post: April 23rd, 2012, 02:07
  2. Billing Problem and Crappy Speed
    By usamagt in forum BTCL
    Last Post: January 13th, 2012, 22:58
  3. speed problem in download
    By sadi_warhead in forum Complaints & Suggestions
    Last Post: October 30th, 2011, 23:37
  4. IS Pros speed problem
    By rajiv2k9 in forum ISPros
    Last Post: September 30th, 2009, 00:25
  5. Prince of Persia Warrior Within Excessive Speed Problem
    By Leaving BG in forum Action-Adventure
    Last Post: May 7th, 2009, 14:03
Page generated in 0.30999 seconds with 19 queries.
