Thread: Mouse problem
    Default Mouse problem
    Koekdin theke ekta ajob shomossha hocche. Pc te kaaj korte korte hothat kore mouse er led off hoye jacche, cursor r nore na kintu scroll wheel kaaj kore. Tarpor PS/2 port theke mouse khule abar lagale thik-thak kaaj kore. Protidin e ek duibar kore ei problem ta hocche. Eita ki mouse er problem?
    mouse er problem hole khule abar lagale kaaj kore keno?
    any help?
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    Have you tried uninstalling the mouse driver from device manager? If not, give it a try and see if it helps. Don't know much about this certain issue however, PS/2 mouse prone to freeze often without any particular reason thereby, to make it workable state again it needs to be plugged off from the PC and plugged in again.
    • areek's Gadgets
      • ASRock Z87 Extreme4
      • Intel Core i5-4670k CPU 3.4GHz
      • G.SKILL Ripjaw DDR3 1600MHz 2x4gb
      • Corsair Force LX 256gb + 500gb WD caviar green + 2TB WD caviar green + Kingston 500gb USB
      • Gigabyte ATI Radeon R9 280X Windforce 3X
      • Dell S2240L
      • Altec Lansing 2.1 speakers|| HIFIMAN HE400
      • Razer Blackwidow Ultimate Dragon Age II edition
      • Logitech G402 on QCK+ NaVi Splash
      • logitech drivefx axial feedback wheel
      • Thermaltake Toughpower gold 750W
      • Asus 24B1ST
      • Samsung ML-1666 laser printer, CanoScan Lide 25
      • yes
      • Windows 7 Ultimate SP1 64-bit
    বাংলাগেমার.কম
    Sometimes it's a loose connection issue....keep doing what you are doing when you face this issue, & if can't help much, try getting a new mouse if possible
    probable coz either cable connection or device driver stopped working...check the cable properly for any visible error.
    no additional driver installed, no visible effect in cable. I suspect the ps2 port on mobo has become loose.
    Quote Originally Posted by areek View Post
    that's what I'm doing now lol.
    • Buddy's Gadgets
      • Gigabyte H87 HD3
      • Intel Core i7 4770K @ 3.5GHz
      • 2 x 4096 MB Apogee DDR3 @1333 MHz
      • Crucial M4 64GB, 1TB Hitachi HDD
      • XFX Radeon HD 4830
      • Philips 190CW Brilliance
      • Built-In
      • A4Tech HS-100
      • Razer Lycosa
      • Steelseries XAI
      • Thermaltake TR2-RX 450W
      • Asus 16x
      • Windows 8.1
      • Smile
      • 640
      • 500
    Buddy's Avatar
    Oct 2010
    Whats your PSU ? I once had an issue like that. My PSU was outputting little more power than it normally should. At first the mouse gets turned off and doesn't respond. Re-plugging them works. Check the power levels of your PSU. If you are using a gaming mouse you probably should be cautious, because my mouse stopped working completely after 1 month.
    Quote Originally Posted by Buddy View Post
    generic psu.
    Psu and mouse! Ajib! How do I check power level? Voltmeter?
  1. Need a Mouse pad for G400 mouse
    By king_showrav416 in forum Help - PC Buying
    Last Post: September 5th, 2012, 23:25
  2. Gaming mouse vs regular mouse
    By Zamil in forum Others PC Hardware
    Last Post: February 6th, 2012, 16:09
  3. Mouse Problem
    By gamefreak in forum Others PC Hardware
    Last Post: September 21st, 2011, 22:45
  4. suggestion for a good mouse and mouse pad
    By Tarik in forum Others PC Hardware
    Last Post: July 10th, 2010, 12:02
  5. Mouse Scrolling Problem
    By dipanzan in forum Technical Support
    Last Post: October 16th, 2009, 11:21
Page generated in 0.19082 seconds with 14 queries.
