Results 1 to 10 of 10
Thread: need help to fix my pendrive
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Default need help to fix my pendrive
    data frequently corrupts in my pendrive.low level formatting,high level formatting,formatting with utilities like pertition manager,disk managemant,cmd prompt won't help.pls provide some solutions
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Some questions
    1 How long have you been using it?
    2 How much total rewrite cycle have you done?
    By the sound of things your pendrive's memry chip is damaged. No way you can fix it. you have to change the flash hip. which is impractical
    Once more into the fray
    Into the last good fight I’ll ever know
    Live and die on this day
    Live and Die on this day
    time to ask for a replacement.
    buy another one... guess it has reached its limit... btw if its 2GB or something try to switch between FAT & NTFS
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    off topic but is idb open tommorow tuesday
    Quote Originally Posted by TheNutKicker View Post
    IDB is closed only in the Sundays
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Thanks i called 30+ Numbers noone answered
    brand ki? Amr transcend e emon hoisilo .online recovery ,low level format ar fridge e rekhe thik kosilam. Back in 2010. It is still ok.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    just used for 2-4dayes.done about 10-20 rewrite cycle.iball got from a frnd as gift.pray 100bar format korsi!!!!
    it shows formatting failure when i try to format using windows tool + this errorName:  Capture.PNG
    Quote Originally Posted by Asif 11 View Post
    fridge e rekhe????!!!!
    sorry deep fridge e rekhe.
  1. Want to Buy 4GB Pendrive
    By Trave160 in forum Shop - Gadgets
    Last Post: July 15th, 2012, 17:03
  2. 16 gb pendrive showing 4mb
    By sayemcom in forum Technical Support
    Last Post: August 2nd, 2011, 03:01
  3. Pendrive problem
    Last Post: June 29th, 2010, 13:15
  4. pendrive to HDD copy problem
    Last Post: October 15th, 2009, 23:10
  5. Use pendrive as ram !!!
    By cybervirus007 in forum Technical Support
    Last Post: September 26th, 2009, 23:37
Page generated in 0.21074 seconds with 15 queries.
