Results 1 to 18 of 18
Thread: Cooler Master Evo with 2 fans at push/pull
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    Default Cooler Master Evo with 2 fans at push/pull
    i have used CM evo for my processor for a few days..the temps weren't bad..
    idle=40C
    while gaming(Run, Saboteur) for 2 hours+ =54C
    maximum load=65C (15-20 mins with IBT)
    OCed to 3.9GHz and maximum load=80C
    i recently added 2 CM xtraflo red LED fans in push pull config..and here's the new result:
    idle=39C
    after playing total war shogun 2 for 2 hours+ =51C
    maximum load=57C
    i havent OCed my processor yet after i got 2 of these fans
    and my casing airflow(negetive pressure) also increased as i now have 5 90cfm silent fans from CM...
    so what do you guys think??
    Wow thats a pretty Significant drop in temps. The case pressure helps too I guess.
    The Coolermaster R4s Dropped my GPU temp by ~2-4C, and they are much more silent and looks better than Thunderblades too.
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Cool...
    But, how far can u go with that non k 3550?
    Did u try higher than 3.9?
    Quote Originally Posted by eXcavator View Post
    More silent? Like really? I'll have to sell all my fans then, I disconnected 4 four of them, and only have 1 running because of it.
    Indeed they are. But still there is a humming sound if you have like 7 of them running at 70% Speed. Other than that even the two 200mm fans in my case @ 100% speeds are louder than 7 R4s @ 70% Speeds.
    EDIT : Just checked, they are a bit louder than the two 200mms, but they make a different sound, its more of an humming sound rather than what you get from thunderblades. But I've had 3 R4s and 3 TBs at the same time, the R4s were alot more quieter than the TBs.
    I see I guess I'll sell them off then, my fan controller broke so I don't have anything to put them down to like 30-40%.
    You could always use your board headers to tone down the fans
      • built-in
      • CM GX650
    Cool...
    i can go upto 3.9...and with bios update 4.1 is possible (thats what i've heard)..i'm going to do that after my prof...i'll try to update this thread then...this 3550 is the hottest processor of all the ivy processors so i guess thats a great result
    did you put the fan just beside the gpu?? i mean in the side panel??
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    hmmm... thats kinda weird for me... are e8400 more hotter than ivy bridge processors... i too use an evo 212 with push[default] and pull[xtraflow] with 0 case fans [i know, i have a crappy case and slots for only 80mm fans so yeah] BUT side panel removed and here are my temps...
    CPU: E8400 @ 3.6GHz
    TIM: default CM tim.
    idle temps: 51c
    load temps [prime95]: 74-75c
    [OCCT] normal: 76-78c
    [OCCT] linpack:82-85c
    is that completely cause of the airflow of my case??
      • built-in
      • CM GX650
    Quote Originally Posted by zunaid View Post
    CPU: E8400 @ 3.6GHz
    idle temps: 51c
    it might be your casing..if the airflow isnt sufficient (into and out of the case) 100 cooling fans mounted to the EVO or any other cooler wont do any good...but what i know about your processor is..it's known to have faulty sensors..if you google you'll see what i mean...so that might be your problem as well
    did you get your evo from binary..they use a lot of TIM..which actually doesnt help keeping the temp down
    and if possible reapply TIM (clean and reapply) and then place cooler..make sure it just sits over the cpu correctly..not too tight not too loose (binary people tend to get the screws too tight, which may end up damaging your motherboard)
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5" Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    Fan ta kothai pawa jai? and price koto ? newegg showing $36, so should it be around $40? if so then I will buy an unboxed processor and this fan.
    I'm getting positive reviews from newegg.
      • built-in
      • CM GX650
    Quote Originally Posted by Hamilton View Post
    thats actually below 40$...2800 or 2750 BDT from binary logic with the stock fan..and if you buy another fan make sure you get the Xtraflo red LED one..it spins faster and pushes more air...also dont tell binary people about this (i'm afraid they'll increase the price if they know it)
    the stock fan is also xtraflo non-LED version, which pushes ~83 cfm air, same goes for blue led one..but the red LED spins at 2200 RPM and pushes ~93 cfm air..i specifically wanted the red one for this reason
    fan price 850 tk for the xtraflo one and 650 tk for R4
      • 16GB DDR3 1600hz
      • Roccat Arvo
      • 500GB
      • Windows 7/ Linux
      • Smile, BD.COM
      • 75KBPS(Variable)
    Hamilton's Avatar
    Quote Originally Posted by terrygr8_007 View Post
    Thank you very much XD
    No, I have a 200mm Stock Tt fan blowing directly at the GPU
    Here is my R4 setup
      • 16GB DDR3 1600hz
      • Roccat Arvo
      • 500GB
      • Windows 7/ Linux
      • Smile, BD.COM
      • 75KBPS(Variable)
    Hamilton's Avatar
    ^^noob setup XD
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    The Stock fan is not an XtraFlow, rather a Blademaster. Its very different from a Xtraflow.
    nop 212Evo has a Xtraflow. 212+ had a Blademaster.
    Quote Originally Posted by @bhi View Post
    Oh sorry, I mixed them up
    Deleting that.
    • Mahdi's Gadgets
      • Biostar Hi-Fi Z77X in Thermaltake Dokker (with 120mm intake and 140mm exhaust fan)
      • Intel Core i5 2400 3.1 GHz with Cooler Master Hyper 212 Evo
      • 2X8GB Team Dark DDR3 OC 1600 MHz
      • Samsung 850 Evo 250GB SSD + 2TB HDD
      • Asus DCII Top 560 GTX
      • Dell S2240L 1080p 22 inch display
      • Realtek Built-in Hi-Fi chip
      • Microlab 5.1
      • Logitech K270 Wireless
      • A4Tech X7
      • XBox 360 Controller for Windows
      • XFX Pro Edition 650 Watt
      • Samsung 24x DVD-RW
      • ADATA 1TB Portable Drive
      • 1200 VA
      • Windows 10 Professional x64
      • Gets the job done.
    Dec 2011
    I have the same CPU and same cooler, my room temperature is around 25 ish due to AC. so can u give me some idea about the idle temp and temp at full load? i use a dokker with two intake fans in front and bottom and two exhaust in top and rear. i am asking these coz i had a hard time mounting it and applied thermal grease more than needed.
  1. Cooler master
    By war1oc in forum Others PC Hardware
    Last Post: August 15th, 2012, 22:47
  2. Sale (New) Cooler Master Blade Master 120mm fan for sale
    By Dee in forum Shop - Gadgets
    Last Post: February 26th, 2012, 22:02
  3. Sale (Used) Cooler Master Hyper N520 CPU Cooler
    By VIPERS in forum Shop - Gadgets
    Last Post: February 26th, 2012, 05:46
  4. Sale (New) Cooler Master Hyper 212 Plus Cpu Cooler
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: November 10th, 2011, 20:44
  5. The Cooler Master HAF X
    By Dee in forum Others PC Hardware
    Last Post: January 25th, 2011, 22:40
Page generated in 0.29508 seconds with 15 queries.
