in U2, when i start any circuit or sprint or free-roam, the game crashes & quits to desktop. but i can play drag, drift & street-X . why is dis happening??
Vous n'avez pas vraiment connaître quelqu'un qu'en le combattant.
i really dont have idea.... my built in VGA (96 MB) runs UG2 good without some option mainly motion blur,vsync, fog and others.....
graphics level komiye dekhen. hote pare. weird problem ur facing......sorry for you...
lancard thakle khule try mere dekho... i faintly remember how i solved a similar problem last time i played it''''
option low diye dekhsi.... hoy na
r all option on korleo amr fx5200 drag, drift valoi chalai
r lan khola to possible na..... disable kore hoy na dekhlam
assa apni ki XP SP3 use koren ???
na....
XP SP2
koekdin age windows update korsi but SP3 te upgrade kori nai
XP SP2 Updated???....... apnar strange problem ki OS korte pare?? i dont think so.... GFX tao prob kore na........... taile ar ki ase..... assa arekta kaz kore dekhte paren. UG2 reinstall kore dekhen.................
