Results 1 to 18 of 18
Thread: PC controller help !!
    Jan 2012
    Default PC controller help !!
    Hi,
    Could someone please help me calibrate my pc controller ? I bought it from Rifles Square but its not working properly the pic of the controller can u be seen from here if it helps
    http://www.dna-et.com/gagdets-tried-...troller-for-pc
    i tried to run the calibration software but my right analog stick isnt working in the game....all the buttons seem to be messed up ie they are not assigned properly..so i was hoping someone could help me with tht.Thanks
    • Nirzhar Uchiha's Gadgets
      • ASrock B75 Pro3-M
      • Intel Core i7 2600 @3.40 ghz
      • 2x 4 GB Transcend 1333 mhz
      • Toshiba 1TB + Adata 128gb SSD
      • MSI GTX 770 2GB OC
      • LG 22MP65HQ 22" 1080p IPS LED
      • Creative SB X-fi Titaniium
      • On Ear: Sony MDR XB950BT / IEM: Soundmagic es18
      • Cooler Master Octane Keyboard
      • Logitech M280 Wireless
      • Xbox One + DualShock 4
      • Gigabyte Pulse 600w [80+ Bronze]
      • TechFine 1200VA
      • Windows 10 Pro 64 bit
      • Bought it on 5 may,2012 from elephant road.. upgrading started on February,2013 :)
      • SkyView Online [3 mbps]
      • 370 kBps [International] 11mBps [Local]
      • 200/200 kBps [International/local]
    Nirzhar Uchiha's Avatar
    Dhaka, Bangladesh, Bangladesh
    i ve used that same controller for fifa 12 , neo geo (i used to) , LEGO Batman 2 , PCSX2 (playstation 2 emulator) .. Worked perfectly for me..still using
    give x360ce a try?
    code.google.com/p/x360ce/
    there is a 'mode' button that turns on an LED. Did you try with the led on?
    • nafis087's Gadgets
      • Gigabyte H81 S2PV
      • Intel Core i5 4460 3.2 GHz
      • 8 GB Adata DDR3 1600MHz X 2
      • Toshiba 2TB + Toshiba 2TB + Samsung 320GB + Transcend 320GB (portable)
      • MSI GTX 760 TFIV GE 2GB DDR5 OC
      • ASUS VX229H (1920x1080)
      • Microlab TMN-1 2:1, A4Tech HS-19 & A4Tech HS-30
      • A4 tech bloody b120
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • Transcend 16GB USB 3.0
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    yeah just push the "MODE" button, a RED light will light up and then the right analog stick will WORK PROPERLY
    I bought Logitech Rumblepad II F510 few days, and i have to say it is just amazing. Better than XBOX 360 controller i used before. 2 years replacement warranty! What else a gamer needs!
    price koto vai?
    Jan 2012
    Thanks guys but i returned it. i recalibrated my 360 controller and tried again but its not working... it automatically goes back to the way it was.... i think there might be smth wrong with it.
    price koto vai?
    2,800/= only
    • areek's Gadgets
      • ASRock Z87 Extreme4
      • Intel Core i5-4670k CPU 3.4GHz
      • G.SKILL Ripjaw DDR3 1600MHz 2x4gb
      • Corsair Force LX 256gb + 500gb WD caviar green + 2TB WD caviar green + Kingston 500gb USB
      • Gigabyte ATI Radeon R9 280X Windforce 3X
      • Dell S2240L
      • Altec Lansing 2.1 speakers|| HIFIMAN HE400
      • Razer Blackwidow Ultimate Dragon Age II edition
      • Logitech G402 on QCK+ NaVi Splash
      • logitech drivefx axial feedback wheel
      • Thermaltake Toughpower gold 750W
      • Asus 24B1ST
      • Samsung ML-1666 laser printer, CanoScan Lide 25
      • yes
      • Windows 7 Ultimate SP1 64-bit
    বাংলাগেমার.কম
    The only reason I did not buy the F510 is because of the thumbstick design....it is convex which causes my finger to slip.
    Jan 2012
    Did you have to install anything to get the thing to work ? I wanna buy a controller for the PC but not sure which one would be good or where should i buy it from ?? any tips would be helpful
    Quote Originally Posted by RMAK View Post
    it is doesnt need to install anything.
    Quote Originally Posted by areek View Post
    No it doesnt slip, because it has dotted rubber grip over the analog stick unlike XBOX ones. Im playing FIFA too, trust me, it is great.
    • areek's Gadgets
      • Dell S2240L
      • Asus 24B1ST
      • yes
    বাংলাগেমার.কম
    The problem is, these sticks would get smoothened after a few months of use from what I saw. But whatever it is, the logitech is a good controller whatsoever. BTW, am getting a X360 controller wid 3 months warranty from India.
    Thats good but 3 months warranty aint enough for me. Ar smoothened hoye gele warranty claim korbo, problem ki, i have a very good relation with Computer Source
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    kintu logitech f310, f510, f710 er deadzone toh oonek beshi...problem hoy na?
    Quote Originally Posted by giant View Post
    adjust kore nilei to hoy
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    kivabe??
    kivabe??
    install the cd given in the box and then do the rest..................
    • shohag2018's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i7 860 OC'[email protected] 3.5ghz (TT Frio OCK).
      • a-DATA 8GB 1333MHz
      • Samsung evo 250gb SSD+1 TB 7200rpm
      • Zotac GTX 970 OC
      • Sony Bravia 26inch
      • Creative 5.1 ll Nokia BT stereo 503 ll Nokia BT Stereo 505
      • A4tech bloody b314
      • A4tech bloody v3m
      • Xbox 360 wired original
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Windows 10 pro x64
      • Cinebench r15- 600, Unigine valley- 54fps
      • Going under renovation, Next is CPU-mobo!
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    i have started using Xbox 360 controller recently.. and after a while into a game, suddenly the controller starts vibrating and the circle lights up... dosnt stop till its disconnected. any ideas?
  1. Replies: 13
    Last Post: May 19th, 2012, 13:26
  2. Controller for PC
    By Aziz37 in forum Help - PC Buying
    Last Post: August 16th, 2011, 01:32
  3. Replies: 1
    Last Post: May 22nd, 2011, 22:36
  4. Fan Controller, Where can i get 1?
    By Rakin the Devil in forum Others PC Hardware
    Last Post: March 10th, 2011, 06:35
  5. x box controller
    By INdestructible in forum XBOX
    Last Post: August 17th, 2010, 13:23
Page generated in 0.27678 seconds with 14 queries.
