Results 1 to 14 of 14
Thread: friend wants help for CPU within 50k
    • gamefreak's Gadgets
      • Gigabyte H55-S2V
      • Core i5-760 2.8GHz
      • Micron 2GB DDR3 x 2=4GB
      • Samsung 500GB 5400 RPM SATA
      • Gigabyte ATi Radeon HD 5750 1GB GDDR5
      • Samsung SyncMaster 793DF 17'' CRT
      • Creative Inspire 2:1
      • A4 Tech AntiRSI
      • A4 Tech
      • Xbox 360 Wired Controller For Windows
      • Gigabyte Superb 550P
      • Samsung DVD-RW
      • Rahimafrooz 800 VA
      • Win7 32-bit
      • bought it a month ago....going pretty well....thanks to BG....
      • 16-18
    Solar System
    Default friend wants help for CPU within 50k
    my friend wants to buy a CPU ONLY. budget: 50K max. ONLY for gaming.
    games like fifa (most priority) & recent releases & the likes of COD & other popular ones.
    he will need:
    1.processor
    2.mobo
    3.RAM
    4.casing
    5.graphics card
    6.power supply
    7.dvd writer
    ***NO HDD REQUIRED
    thanks
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    I5 3450...16.5k
    gigabyte b75...7.2k
    transcend 4gb 1600bus ram...2.3k
    cm gx550 ...5.5k
    7850hd...21k
    if u want to reduce cost, go for h61 motherboard.
    If u want to increase budget....well that is endless...
    i wanna buy a new processor n graphics but am a little confused on which proc to buy. not looking to overclock. want a gaming build also a little video editing. my budgets 47 grand. heres some of my options if u have other ideas pls share.Thnks in advance
    Config 1
    CPU= i5 3450
    MB= Gigabyte GA- B75M-D3H
    gpu= sapphire hd 7850
    4gb ram
    Config 2
    CPU= AMD FX 8120
    MB= MSI AMD 760G
    GPU= sapphire hd 7850
    4gb ram
    Config 3
    CPU= i5 2500k(can som 1 tell me the price of this)
    MB= Gigabyte GA-H61M-D3H
    GPU=sapphire 7850
    4gb ram
    Config 1
    CPU= i5 3450
    4gb ram
    A 2500k is useless with a H61 board as you cannot overclock the unlocked "K" series processors. The 2500 non-k should be a good combo with a H61.
    2500k is about 20-22k at Binary Logic, IDB.
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    is cm gx550 psu? if yes, please specify the brand & model a bit more.
    K processors r overkill in such a tight budget!
    i5 3rd gen B75 board 8GB DDR3 1600(4+4) TT TR2 500W Sapphire HD 7850
    or Bulldozer FX 8120 AMD 880 MB(using 760 with a 8120 is more like using i5/i7 with H61 ) 8GB DDR3 1600(4+4) 500W psu HD 7850
    Asus DRW 24B5ST 1650 taka
    CM = cooler master
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    Quote Originally Posted by gamefreak View Post
    cooler master gx550
    it is 550w gx series.
    44a in 12v rail in total.
    Better than gigabyte superb.
    Here in bg , members says it is abit inferior than Tt smart.
    But, in an indian forum i asked, they said it is better.
    At 5.5k at binary logic.
    44Amp only??? my TT LP 430 provides (total) 40A in 12V rails
    say if i buy the right motherboard which wud be better to buy then a i5 3450 or an fx 8120
    gaming... i5 3450 i guess with B75/z77
    Quote Originally Posted by ArchangeLbd View Post
    i5 3450
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    no it doesnt ..................max is 23a combined 12v1+12v2 ................psu er label valo kore dekho
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Each of the two rails has the ability to give 20A, but the total combined amperage is 23A (23A*12V = 276W).
    http://banglagamer.com/attachment.ph...5&d=1347129412
    yeah right! 40AMP 12V 480W LoL that was pure stupidity!
  1. send me a friend request
    By niloy320 in forum League of Legends
    Last Post: October 2nd, 2014, 14:00
  2. Help a friend!!
    By OoAIDoO in forum Miscellaneous Topics
    Last Post: August 7th, 2012, 14:43
  3. Help with pc config for a friend
    By Zimmer™ in forum Help - PC Buying
    Last Post: April 22nd, 2012, 15:55
  4. Friend needs spec
    By Dissent in forum Help - PC Buying
    Last Post: October 16th, 2011, 23:15
  5. PC Buying Help (for my friend)
    By Aziz37 in forum Help - PC Buying
    Last Post: April 3rd, 2011, 17:43
Page generated in 0.23826 seconds with 14 queries.
