Results 1 to 17 of 17
Thread: Need help with i7 Overheating problem
    • bluenight's Gadgets
      • Intel DH55TC
      • Intel Core i7-870 2.93 GHz
      • DYNET 2x2GB DDR3 1333 Bus
      • Hitachi 1TB 7200RPM
      • Gigabyte GTX560
      • Samsung SyncMaster 943 18.5 inch
      • Build In HD Audio
      • A4 Tech 2 Speaker
      • Sony Vaio Desktop Keyboard
      • A4 Tech Optical
      • USB Controller
      • Thermaltake Smart M650W
      • ASUS DVD-ROM
      • Apollo 1200VA
      • Windows 7 Ultimate 64 Bit
    Default Need help with i7 Overheating problem
    Hey guys! i recently started monitoring my hardware temperature (yeah yeah!! I know it was foolish!!), and the results got me really worried. Just look at my CPU temp
Name:	New Picture.png
    the above picture is basically at idle, just after double clicking Battlefield 3.
    And after i have started the game & played it for about a minute or so, the temperature reached...
Name:	New Picture (1).png
    So what am I suppose to do now? Please give me suggestions with details (consider me an absolute novice).
    By the way, the max value of CPUTIN once reached 423C. That's right, 423 degree Celsius!
    My configuration is: Intel Core i7 870 2.93 GHz, Intel DH55TC Motherboard, 4GB RAM, GPU: Gigabyte GTX560 (Non Ti or OC), 1 TB Samsung HDD, Gigabyte Superb E720 PSU, an ASUS DVD-ROM & built in sound card.
    Please Help. Thanks.
    • ahasanali2005's Gadgets
      • GIGABYTE GA-B75M-D3V
      • i5-3450
      • Corsair Vengeance Blue 8 GB (2X4 GB)
      • Samsung 1TB HD103SJ ATA Device
      • SAPPHIRE TOXIC HD 4870 512MB GDDR5 PCI-E
      • Fujitsu PD-LED185B 18.5-inch LED
      • Microlab X4 (5.1 Channel)
      • A4Tech Game Master Keyboard KB-28G
      • A4Tech X-710F Gaming Mouse
      • Thermaltake TR2-550-PP P/N:W0102
      • Windows 8 32bit
      • 65
      • 10
    ahasanali2005's Avatar
    Gazipur
    Ke Casing use koran!
    Bad temperature sensor, it'll burn long before even reaching 150, let alone 423, lol.
    That said, re-apply thermal paste and re-seat the heatsink. You'll be good to go.
      • Intel DH55TC
      • Gigabyte GTX560
      • Build In HD Audio
      • A4 Tech 2 Speaker
      • A4 Tech Optical
      • USB Controller
      • ASUS DVD-ROM
      • Apollo 1200VA
    Quote Originally Posted by Ahasan Dse View Post
    Normal Casing. Non brand. But I keep the side of the casing open and keep it clean & in open space.
    I read in other forums that CPUTIN sensors are not very accurate. That's not my biggest worry. My biggest worry is the 4 CPU core temperatures.
    And I don't know anything about how to apply thermal paste or re-seat the heatsink. Could you please give me a detail guideline on how to do that? Thanks.
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Latest bug of HWMonitor. It shows high values in max temp. Try Core Temp or Real Temp or Open Hardware Monitor.
      • Intel DH55TC
      • Gigabyte GTX560
      • Build In HD Audio
      • A4 Tech 2 Speaker
      • A4 Tech Optical
      • USB Controller
      • ASUS DVD-ROM
      • Apollo 1200VA
    Quote Originally Posted by SadmanBD View Post
    At idle, with both Real Temp and Open Hardware Monitor
    And after running Battlefield 3 ,
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Reapply thermal paste.
      • Intel DH55TC
      • Gigabyte GTX560
      • Build In HD Audio
      • A4 Tech 2 Speaker
      • A4 Tech Optical
      • USB Controller
      • ASUS DVD-ROM
      • Apollo 1200VA
    Ok. I took my PC to IDB and reapplied Thermal Paste. Now my 4 CPU cores temperatures are around 78 - 83C when running battlefield 3 or other games, basically doing some heavy work. And at idle, it's around 37 - 43C. Keep in mind that I have only used the PC for about half an hour after applying Thermal Paste.
    Now is that better? Should I get a heat sink just to be safe or keep it as it is? Thanks.
    That's fine enough, yeah. Still seems a bit high for the 'in load' temps, but I reckon you'll need a non-stock cooler for that.
      • Intel DH55TC
      • Gigabyte GTX560
      • Build In HD Audio
      • A4 Tech 2 Speaker
      • A4 Tech Optical
      • USB Controller
      • ASUS DVD-ROM
      • Apollo 1200VA
    Could you suggest me a good cooler or thermal heat sink which is compatible with my CPU & motherboard? My CPU is Intel Core i7 870 2.93 GHz with Intel DH55TC Motherboard (I think both are LGA 1156, I'm not sure whether it's relevant or not but I heard it was).
    Thanks...
      • i5-3450
      • Windows 8 32bit
      • 65
      • 10
    Gazipur
    I have not a big knowledge, I suggest try low price good CPU cooler COOLER MASTER Hyper 212 EVO price =2,800 Tk - 3,000 Tk(New)
    http://www.newegg.com/Product/Produc...82E16835103099Click image for larger version.
Name:	COOLER MASTER Hyper 212 EVO.jpg
    (3000 Tk @ Binary Logic IDB)
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Cooler lagbe na OC na korle. R unar to Intel mobo.
    I faced the same problem with my i7 too... bought it from rishit & they provide low quality product... & those technicians are even worse !!! they couldnt even set the heat sink properly... sooo what i did ... bought a new heat sink with fan & thermal paste... applied it properly, went to the bios boost up the fan speed to maximum (almost 3000rpm) now its running good
    when setting up the sink make sure its having enough contact with the cpu! & make sure its clean ...
    Get a tube of CM or Tt paste and then re-apply it. Should bring the temps down. Otherwise get the Hyper 212 EVO. Ask Binary to install it for you if you cannot. I guess those IDB technicians applied 20tk White Thermal Paste which are really pure BS.
      • Intel DH55TC
      • Gigabyte GTX560
      • Build In HD Audio
      • A4 Tech 2 Speaker
      • A4 Tech Optical
      • USB Controller
      • ASUS DVD-ROM
      • Apollo 1200VA
    I'm not going to overclock. But what do you mean by "Intel Mobo"? Do you mean since I have an Intel Motherboard, I won't be able to install some other non-stock cooler/heat sink or that I will face some other hardware issues? Please let me know.
    I saw some Thermaltake CPU coolers at UCC. Are they any good (what about when compared to Hyper 212 EVO since Thermaltake ones are priced at Tk.4500 and Tk.5400 while Hyper is Tk.3000, I think.......)?
    Are those coolers (Both Thermaltake & Hyper 212 EVO) compatible with my hardware (processor/motherboard or whatever is relevant)? How do I find out which cooler is compatible with my PC?
    And by the way, I read somewhere that the i7 8xx series processors heats up more than other processors. Is that correct?
    Quote Originally Posted by bluenight View Post
    He meant that with an Intel Mobo you cannot overclock hence you won't need a cooler. You can install any cooler on your board perfectly fine.
    Anyway, if 4,500 is the SpinQ VT, then stay away from that. A Hyper 212 Evo would be better. But if you want a slightly better cooler you can get one of the Tt Frios, those are more expensive and in return those perform better.
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    @eXcavator said it all. And i7 9xx series produces more heat than the 8xx series. I suggest you to buy a decent TIM and live happy
  1. Gta 4 Problem?
    By Soap Mactavish in forum Gaming Topics
    Last Post: March 21st, 2012, 12:40
  2. Overheating problem.
    By Zamil in forum Technical Support
    Last Post: March 8th, 2012, 20:16
  3. Nvidia Driver Problem or Graphics Card Problem ??
  4. help MSI N9800GX2 overheating problem
    By Cyber_Shot in forum GPU
    Last Post: August 21st, 2010, 05:50
  5. Got Problem
    By s.a_rocky in forum Older NFS Games
    Last Post: January 29th, 2009, 11:20
Page generated in 0.29314 seconds with 15 queries.
