Results 1 to 13 of 13
Thread: seagate HD problems...
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    Default seagate HD problems...
    i bought a seagate barracuda 2TBHD from binary a few days ago... and since then i can hear a mild clicking sound..4-5 times/day...it happens when i start running an application or PC becomes active...my pc hanged a few times.. (but thats most probably due to chrome, after i somehow manage to force shut the application...it runs great)..just a minute ago i ran AIDA64... here's what it showed.
    ID Attribute Description Threshold Value Worst Data Status
    01 Raw Read Error Rate 6 116 99 105741632 OK: Value is normal
    03 Spinup Time 0 95 95 0 OK: Always passes
    04 Start/Stop Count 20 100 100 98 OK: Value is normal
    05 Reallocated Sector Count 36 100 100 0 OK: Value is normal
    07 Seek Error Rate 30 69 60 8226332 OK: Value is normal
    09 Power-On Time Count 0 100 100 464 OK: Always passes
    0A Spinup Retry Count 97 100 100 0 OK: Value is normal
    0C Power Cycle Count 20 100 100 99 OK: Value is normal
    B7 <vendor-specific> 0 100 100 0 OK: Always passes
    B8 End-to-End Error 99 100 100 0 OK: Value is normal
    BB Reported Uncorrectable Errors 0 100 100 0 OK: Always passes
    BC Command Timeout 0 100 100 0 OK: Always passes
    BD High Fly Writes 0 100 100 0 OK: Always passes
    BE Airflow Temperature 45 63 63 622854181 OK: Value is normal
    BF Mechanical Shock 0 100 100 0 OK: Always passes
    C0 Power-Off Retract Count 0 100 100 8 OK: Always passes
    C1 Load/Unload Cycle Count 0 100 100 100 OK: Always passes
    C2 Temperature 0 37 40 37 OK: Always passes
    C5 Current Pending Sector Count 0 100 100 0 OK: Always passes
    C6 Offline Uncorrectable Sector Count 0 100 100 0 OK: Always passes
    C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passes
    F0 Head Flying Hours 0 100 253 471 OK: Always passes
    F1 <vendor-specific> 0 100 253 2422068520 OK: Always passes
    F2 <vendor-specific> 0 100 253 3251223664 OK: Always passes
    what does it mean?? do i need to change it?? is the so called 'Click of death'??
    i'm going to run seatools or something like that...but i'm not sure if thats going to work :S
    any suggestion?
    if u have warranty claim a new one, & if u cant do that update ur HDD's firmware...existing firmware version is written on it... btw how much did it cost?
      • Philips 191EL 19&quot; LED @77 Hz
    If you hear just a click while at startup or during wake up from an idle state of the hard drive, it's absolutely normal, Seagate hard drives tend to be a bit noisy.
      • built-in
      • CM GX650
    its 12k from binary
    @terrygr8_007 it is your platter problem. CHANGE IT ASAP.
    ANd yes, it is the "click of death", if you dont believe me, keep it for 1 more month................... you will surely believe me then.
      • built-in
      • CM GX650
    what will i tell them?? will they change it just cause there's some mild 'click' which isnt regular?
    Quote Originally Posted by terrygr8_007 View Post
    wait and get it totally damaged. Then go for warranty and never buy any product from Binary Logic. Dokan tar serious problem ase, 560ti anlo, noshto, sickleflow anlo, with wrong package info (it is actually less than 1800rpm), akhon abar faulty seagate ana shuru korse................... that shop is purely faqed up.
      • built-in
      • CM GX650
    they didnt bring sickleflow (they just call it sickleflow, may be they think it'll sell more with that name)...they brought 90 cfm silent fans...and they are spinning at 1804 RPM right now (i have 1) and max was 1869 RPM which isnt bad and guess what!! they're really silent...one of my friend was really surprised to see it..but its not like they are truly 90 cfm fans...they are more like 70/80 cfm fan...anyway...not a bad deal at 650 Tk as TT thunderblade's market price is 700 Tk and they push almost same amount of air but with disturbing sound...
    http://www.coolermaster.in/product.p...category_id=63
    this is the fan they brought
    what if the HD goes past it's warranty period and then dies?
    and CM's LED isnt that disturbing
    Thunderblade price is 625/=
    1. Long sleeved Cables.
    2. Better Light.
    3. 1 year warranty.
    4. 70.4cfm
    5. Runs at 1760-1780 (my sickleflow even drops as ~1750) and i use both Thunderblade and Sickleflow.
    My vote goes for Thunderblade as the price is less.
      • built-in
      • CM GX650
    sometimes the motherboard cause the fans to run slow (if connected to motherboard, especially gigabyte)...besides i'm not talking about sickleflow..i'm talking about 90 cfm silent fans which binary brought..and i never used thunderblade..so i really can't compare them..btw at what RPM your thunderblades run?
    amaro samsung hd502hj ei model ta te clicking prob hoitese. Ei model ta te totally problem ase. Just waiting when it will die
    Quote Originally Posted by Asif 11 View Post
    thats seagate, not samsung.
    If reallocated sector count is > 0, change it asap.
    It's about to die, period.
  1. Seagate HAMR tech
    By codename5302 in forum Tech News
    Last Post: March 25th, 2012, 02:07
  2. Replies: 3
    Last Post: December 20th, 2011, 10:31
  3. Replies: 5
    Last Post: July 1st, 2010, 19:09
  4. Closed HDD 250GB Seagate
    By alucard in forum Shop - Gadgets
    Last Post: February 7th, 2010, 12:31
  5. I want to buy SEAGATE HDD
    By coldfire7 in forum Shop - Gadgets
    Last Post: September 24th, 2008, 14:43
Page generated in 0.27944 seconds with 14 queries.
