Results 1 to 8 of 8
Thread: Patch installation problem - 3.3.5a to 4.0.0.12911
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Question Patch installation problem - 3.3.5a to 4.0.0.12911
    Hi gyz I currently have WOTLK 3.3.5a installed. Recently I thought of playing Cata and downloaded from patch mirror side the first applicable patch which is 4.68 GB. It consists a folder "DPB" and withing it contains this files:
    WoW-3.3.0.10958-4.0.0.12911-NA-Stage-1
    WoW-3.3.0.10958-4.0.0.12911-NA-Stage-2
    WoW-3.3.0.10958-4.0.0.12911-NA-Stage-3
    WoW-x.x.x.x-4.0.0.12911-Updater.exe
    Now I have placed this files in my Wotlk folder and tried running the exe file. It opens up a box with error message like this :
Name:	patch error.jpg
    I have also downloaded all other patches untill 4.0.6a as molten requires upto thjis to play cata. I have downloaded the patches from this mirror site : http://www.wowwiki.com/Patch_mirrors
    Now can you guys pls help me how I can patch up???
    • gogeta's Gadgets
      • Gigabyte Z370/DG31PR/Laptop MB name janina -_-
      • Intet i5 8600k @4.7ghz/Intel Core 2 Duo E7400/Intel Core I7 2.26 Ghz
      • Gkill Ripjaws 2*8GB 3000bus/4 Gb DDR2 (Twinmos)/16 GB DDR3
      • Samsung 2+2 TB/256 GB M.2 Samsung 970+512 Intel SSD
      • Gigabyte 1070ti/GTX 860m
      • LG22"/Samsung 22 ''/Samsung 19"/Lenovo 15.6''
      • Creative Sound Blaster X-Fi Titanium HD+ Realtek Built in 8 Channel Card
      • Creative 5.1/Microlab/Razer Kraken Pro 7.1 HP
      • Asus Strix Tactic Pro Mechanical KB/CM Devastator Pro
      • A4Tech Bloody v3m/Logitech G402/CM Storm Devastator
      • Logitech 310/Xbox One Genuine Controller
      • Seasonic 620w Bronze 80+
      • Asus 24x DvD-Writer/Lenovo Portable DVD WR
      • 16 GB Adata/2 TB WD Portable*2
      • Crown micro
      • Win 10 Pro/Win 10 Home
      • Lawl...
      • Doze Internet
      • 4 Mbps
      • 4 Mbps
    gogeta's Avatar
    Dalaran, Northend
    I updated my Client using Launcher.exe... Or just get cata from someone of the forum.. I live in Ctg so I cant help.
    Btw, Cata client was uploaded in Torrentbd. Check there if its still available and if someone still seeding.
    @kabir_sharif2000
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by gogeta View Post
    @kabir_sharif2000
    How long did it take to update through launcher?
    updating through launcher is a headache. i had to follow molten full info to get my downgrade from 4.3 whn it updated to 4.3...
    i live in dhanmondi, i can give u full cata
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by graodon View Post
    Very much appreciate it bro!!! How do I take it from you? I have 500 GB external hard drive. Can you give me your mobile no. ?
    Sent you a PM @graodon
    replied hehe
    i also hve an external HDD.
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Hey guys at last I was able to patch up to 4.0.6a and run WoW Cata. Currently there is some ingame download ongoing. I am using Qubee 1 Mbps. How much download speed does that ingame download get? As far I know, it will download 14-16 GB data?
    nice..
    will take awhile depending on howmuch u pull every second
  1. Max Payne 3: installation problem
    By Tawrat in forum Gaming Topics
    Last Post: October 17th, 2012, 12:05
  2. Nfs:the run installation problem
    By Source code in forum Gaming Topics
    Last Post: December 16th, 2011, 08:11
  3. Win 7 After-Installation Problem
    By thekoRngear in forum Technical Support
    Last Post: January 9th, 2010, 22:51
  4. XP installation problem in laptop
    Last Post: May 10th, 2009, 01:56
  5. GTA IV Installation Problem.. help me
    By CHR.Satiator in forum Sand Box
    Last Post: February 14th, 2009, 23:06
Page generated in 0.15418 seconds with 15 queries.
