Thread: Gpu driver problem!! Help!!!!!!!
    • nafis087's Gadgets
      • Gigabyte H81 S2PV
      • Intel Core i5 4460 3.2 GHz
      • 8 GB Adata DDR3 1600MHz X 2
      • Toshiba 2TB + Toshiba 2TB + Samsung 320GB + Transcend 320GB (portable)
      • MSI GTX 760 TFIV GE 2GB DDR5 OC
      • ASUS VX229H (1920x1080)
      • Microlab TMN-1 2:1, A4Tech HS-19 & A4Tech HS-30
      • A4 tech bloody b120
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • Transcend 16GB USB 3.0
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Default Gpu driver problem!! Help!!!!!!!
    I started facing this problem after buying my i5 2400 & GB h61. At that time i was using my HD 4830 with TT LP 500W.
    The problem is the computer starts to lag in everything (like opening my computer,starting winamp,utorrent etc.) even when i play games (every game) it starts to stutter a lot BUT if i REMOVE the DRIVER and then INSTALL it again then everything turns back to normal (no stuttering). This happened for about 10-11 months then all of a sudden my GPU died. I thought it was my GPUs fault but recently i bought a HD 7770 oc and for about 5-6 days it was ok but now the old problem starts to happen again. Now i have to UNINSTALL & REINSTALL my driver ALMOST everyday even TWICE a day to be able to play games.
    WHAT SHOULD I DO????? I AM REALLY WORRIED ABOUT MY GPU????
    BTW i am using AMD CATALYST DRIVER 12.8
    @Vanguard CAN U HELP ME ON THIS BRO????????
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    IT COULD be your power supply, i recommend atleast 550watt for your configuration.
    Litepower doesnt have that much power on +12v rails to run i5 and 4830
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    MY 4830 died 1 month ago now i am using 7770 oc. SO R U SURE THAT THE CULPRIT IS MY PSU?
    BUMP!!
    Quote Originally Posted by nafis087 View Post
    BUMP!!
    200% sure.
  1. Nvidia Driver Problem or Graphics Card Problem ??
  2. driver problem with Banglalion in win 7
    By adnan.alvee in forum Technical Support
    Last Post: September 29th, 2011, 16:04
  3. ATI HD 6370 driver installtion problem
    By Arif69 in forum Technical Support
    Last Post: June 22nd, 2011, 18:58
  4. Problem with agp driver
    By zaman_177 in forum GPU
    Last Post: September 17th, 2010, 05:33
Page generated in 0.16774 seconds with 14 queries.
