Thread: GPU temperature problem
    • gsshaun's Gadgets
      • Gigabyte B75M-D3H
      • Core i5-3450
      • Twinmos 2X4 GB DDR3 1600
      • Sandisk Ultra 64GB SSD+Hitachi 500GB, 7200Rpm
      • MSI GTX 760 OC
      • Sony 42" KDL W654A+Viewsonic VX2260
      • AVR Sony STR DH-520 + Creative Xfi Xtreme gamer
      • Magnat Monitor Supreme 2*200+2*100+1*250 Passive Book-shelf Speaker + JVC HA RX-500
      • Perfect USB
      • Lexma
      • Value Top 500 watt
      • DVD Rom, ASUS
      • Trascend 320 GB HDD, External
      • Windows 7, 64 bit
      • 320 Kbps
    Default GPU temperature problem
    I have a running 9600GT. It's couple of years old & for the past few days it's temp is rising to 90 degree Celsius at idle. I removed it's cooler & looks like the thermal paste is dried up. The paste was hard. I never changed the paste before. I do not have any problem to do normal tasks except playing games. After running games like NFS RUN, Undercover & Blur the video signal cut off, Monitor shows no signal. There is no problem to play games like "Most wanted" or low profile games. I think, it is time to change the thermal paste. But i just want to be sure about the cause. Is there anybody experienced this kind of problem before? & what kind of paste would be good for 9600GT? I am looking for cheap solution as i will change my GPU after this year.
    Thanks.
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    well, sorry to hear that... i had a similar problem with my 9600gt also.... my cpu would also reach 90c+ temps.... since u already removed the heatsink, u must have also cleaned out all the dust in the heatsink fins and the fan. especially the fan, make sure its clean. and as for ur high temp problem, i have to blame the dried up thermal paste. [did u try using a blower to clean out all the dust from the graphics card b4 u un-screwed the heatsink]. as for thermal grease or paste, u can easily buy it from ucc or binary logic. costs sth around 500tk. should be good for using more than 15 times.
    • gsshaun's Gadgets
      • Gigabyte B75M-D3H
      • Core i5-3450
      • MSI GTX 760 OC
      • Perfect USB
      • Lexma
      • DVD Rom, ASUS
      • Windows 7, 64 bit
      • 320 Kbps
    Quote Originally Posted by zunaid View Post
    Thanks for the info. I use blower regularly.
    • sakibchy's Gadgets
      • Asus P55D -Deluxe
      • INTEL CORE i7 - 870 @ 4.00ghz
      • 8 GB CORSAIR XMS 1600mhz
      • 1TB samsung , 7200rpm ,32m buffer
      • Nvidia GTX 580
      • Dell ultrasharp 2410 , 24" ips display with 1920 X 1200 resolution
      • Inbuilt 7.1
      • creative 6:1 inspire 6600
      • A4 tech multimedia ( cheap actually )
      • Gigabyte M6900 laser @ 2000dpi
      • Corsair VX 550 (+12 @ 41 amp)
      • Benq 24x dvdrw
      • WIN 7
      • Win index score, cpu 7.7 , ram 7.6 , GPU 7.9 , HDD 5.9
      • All those things are put together in my TT ARMOR A60 casing
      • qubee
      • 128 k
      • 32k
    Oct 2012
    Sylhet
    I'm still surprised to see your card still not died or lost its hardware acceleration even though it reached to 90C!!! But I'm sure it lost some of its performance. Anywys like use other said, get thermal paste and aplied it correctly between your wiped gpu and heatsink surface. Use a very littke amount . But if I were you I would have flash my crad with modified bios setting the fan speed higher as defult. If yoy don't have any fan over your heatsink , then get a 80 mm and mount it correctly near the gpu. Also make sure your system has correct air flow directoin ... intake and exhaust. Then monitor your gpu temp with gpu-z and track the highets temp underload. If it is below 70 c then it is good as new. If not sell it immediately. Better safe then sorry. On more thing , never use blower ... never ever. It shortened your componets life span. The heavt ait flow weaken the connection of soldiered item and reduce lifespan of diode, transistors and capacitors ....
  1. Temperature Problem. ( HD 4770 )
    By Mohaan in forum GPU
    Last Post: October 16th, 2011, 18:59
  2. CPU temperature problem
    By Badhon_raj in forum Technical Support
    Last Post: April 29th, 2011, 15:00
  3. CPU temperature problem again :(
    Last Post: April 16th, 2011, 18:54
  4. cpu temperature problem
    By Swapan Roy in forum CPU
    Last Post: March 5th, 2011, 17:45
  5. E5200 temperature problem
    By shahriar in forum CPU
    Last Post: June 8th, 2009, 12:00
Page generated in 0.16501 seconds with 14 queries.
