Results 1 to 11 of 11
Thread: How to Find & Fix a Stuck Pixel on an LCD / LED Monitor
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Default How to Find & Fix a Stuck Pixel on an LCD / LED Monitor
    Hi guys, I think this post will be very helpful if you want to find dead pixels on your monitor and want to fix it instead of dealing with hassles to return it to the seller again Here is a very useful software that helps you find dead pixels:
    Dead Pixel Buddy 1.1 (Freeware) : http://www.softpedia.com/get/System/...el-Buddy.shtml
    If your LCD / LED screen has a point on the screen that is "stuck" (either it's always bright or always dark), it is potentially possible to fix it on your own. Here's how to do it:
    Pressure Method
    • Turn on the computer and LCD screen.
    • Display a black image, which will show the stuck pixel very clearly against the background. It is very important that you are showing a black image and not just a blank signal, as you need the backlighting of the LCD / LED to be illuminating the back of the panel.
    • Find a narrow object with a blunt, narrow end. A Sharpie marker with the cap on, an extremely dull pencil, a plastic stylus, or the end of a makeup brush would all work for this.
    • Use the rounded end of the object to gently tap the stuck pixel. Don't tap hard to start with, just enough to see a quick white glow under the point of contact. If you didn't see a white glow, then you didn't tap hard enough, so use just slightly more pressure this time.
    • Tap harder. Increase the pressure on the taps gradually for 5-10 taps until the pixel rights itself.
    • Apply pressure instead. If your tapping hasn't yielded any results, grab a damp (not wet) washcloth or paper towel. Fold the fabric so that you don't accidentally tear it, and hold it over the stuck pixel, and apply gentle but consistent pressure with the same object you used for tapping.
      • Try to apply pressure only to the stuck pixel and not the surrounding area.
    • Check your results. Display a white image (such as an empty text document, or sending your browser to about:blank and going to full screen with F11) to verify that you haven't accidentally caused more damage than you fixed. If you fixed the stuck pixel, your whole screen should be white. Or use Dead Pixel Buddy 1.1 (Link given above).
    Heat Method
    • Turn on the computer and the LCD / LED screen.
    • Dampen a washcloth with water that's as hot as possible. If you can, heat water on the stove or microwave until it's just beginning to show air bubbles at the bottom of the container. Put the washcloth in a colander, and dump the hot water over the washcloth.
    • Put on gloves, or cover your hands with oven mitts. You don't want to burn your fingers in the next steps.
    • Put the hot washcloth in a plastic sandwich bag. Make sure the seal is completely closed.
    • Hold the plastic bag with the hot washcloth up against the stuck pixel. Hold the plastic bag up to the screen such that the area you're using doesn't have a seam on it. As much as you can, try to only focus the heat on the stuck pixel.
    • "Massage" the pixel in slow circles. Move the bag around the pixel a bit in a massage-like motion. The heat generated will cause the liquid crystal to flow more easily into the areas that were not formerly filled.
    Software Method
    • Try running pixel-fixing software. Stuck pixels can often be re-energized by rapidly turning them on and off. There are screensavers available for download that will do this to your LCD / LED screen.
    Hardware Method
    • Try a solid state solution like PixelTuneup (http://www.pixeltuneup.com/). These devices produce specially tuned video signals that eliminate stuck pixels while enhancing picture quality, color, and contrast. Also works on televisions, including LCD, LED, plasma, or CRT.
    • Turn off the monitor.
    • Plug in and turn on PixelTuneup, then turn on the monitor.
    • Wait 20 minutes.
    • Turn off and unplug PixelTuneup.
    • Stuck pixels and other IR will be gone, and color/contrast will be improved.
    @Vanguard @aayman @Codex @dipanzan
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Can some1 make this guide sticky?
    Why not? It's good contribution
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Thanks
    • Nirzhar Uchiha's Gadgets
      • ASrock B75 Pro3-M
      • Intel Core i7 2600 @3.40 ghz
      • 2x 4 GB Transcend 1333 mhz
      • Toshiba 1TB + Adata 128gb SSD
      • MSI GTX 770 2GB OC
      • LG 22MP65HQ 22" 1080p IPS LED
      • Creative SB X-fi Titaniium
      • On Ear: Sony MDR XB950BT / IEM: Soundmagic es18
      • Cooler Master Octane Keyboard
      • Logitech M280 Wireless
      • Xbox One + DualShock 4
      • Gigabyte Pulse 600w [80+ Bronze]
      • TechFine 1200VA
      • Windows 10 Pro 64 bit
      • Bought it on 5 may,2012 from elephant road.. upgrading started on February,2013 :)
      • SkyView Online [3 mbps]
      • 370 kBps [International] 11mBps [Local]
      • 200/200 kBps [International/local]
    Nirzhar Uchiha's Avatar
    Dhaka, Bangladesh, Bangladesh
    up till now.. I ve found two dead pixels.. And u dont really need any software to catch them.. My ones were ''blue'' .. And clearly visible in blackish backgrounds.. I just pushed the pixel with the back of a pencil n poof !! Gone
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Well my one's were 2 white dead pixels and clearly seen on black background
    wah wah!!
    • S.m. Al-razi's Gadgets
      • gigabyte ud2h
      • intel core i5 2300 2.8GHZ
      • 4 GB DDR3 (1333 BUS)
      • HITACHI 500 GB
      • COOMING SOON
      • COOMING SOON
      • SIMPLE
      • SIMPLE
      • SIMPLE
      • SIMPLE
      • COOMING SOON
      • STAR 650 V
      • WIN 64 BIT
      • COOMING SOON
      • BANGLLALION WIMAX (POST PAID)
      • 69 IN IDM
    S.m. Al-razi's Avatar
    Oct 2012
    i will trying to recover my pixel.
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Bro.my bro's lcd has a dead pixel line.can it be fixed
    I like this....this is a great find...will try it on my 2nd 17 inch lcd... thanks
    • riajulzanna's Gadgets
      • Gigabyte H81-S2PV
      • Intel G3220
      • Transcend 8GB DDR3 1600
      • Hitachi 1TB
      • GTX 550 TI
      • Asus VS197D LED 18.5''
      • Realtech Audio
      • 5:1 Sound System
      • Deluxe K9020
      • A4Tech Bloody V3
      • Atech :p
      • Thermaltek TR2 RX 450 watt
      • Banglalion,GrameenPhone
      • 1mbps
    riajulzanna's Avatar
    Nov 2013
    Tht's for I like banglagamer too much ^_^
    thnx to wikihow also
  1. Stuck at 800MHz
    By Flame in forum Technical Support
    Last Post: May 22nd, 2012, 19:31
  2. Help:got stuck somewhere in black ops
    By Source code in forum Gaming Topics
    Last Post: November 2nd, 2011, 19:15
  3. Algorithm turns 8-bit pixel art into smooooth 'toons
    By emroz_2272 in forum Tech News
    Last Post: May 29th, 2011, 10:27
  4. Help me to find the best monitor
    By CvP in forum Others PC Hardware
    Last Post: August 5th, 2009, 09:36
  5. my DVD rom is stuck
    By Mad Monk in forum Technical Support
    Last Post: June 5th, 2009, 13:01
Page generated in 0.24738 seconds with 14 queries.
