Thread: Stock cooler or Chinese Haofeng cooler for i5-2310
    • Camouflage's Gadgets
      • Gigabyte Sniper B5 B85
      • Core i5-4460 3.2Ghz with Deepcool Mini Cooler in Thermaltake 'Versa-2'' Case
      • Corsair Vengeance DDR3 1600Mhz 2*4gb
      • WD Blue 1TB 7200rpm
      • MSI Gtx770
      • Samsung 22'' Wide Screen LED-1920*1080
      • Creative Sound blaster Audigy 2ZS
      • Microlab 5:1
      • HP keyboard
      • A4Tech X7 XL-747H Spider
      • Corsair-HX650W-52A in single 12V Rail with 4 (6+2) pin connectors
      • HP DVD writer
      • Transcend Jetflash-16gb & Sandisk Cruzer 4gb
      • Apollo 1200VA
      • Windows-7-64 bit Ultimate Edition
      • Pro-7.6,GPU-7.9-Windows7 benchmark
      • Satisfied what i have
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    Default Stock cooler or Chinese Haofeng cooler for i5-2310
    Well experience of using intel stock cooler wasnt fruitful for me.I had my Pentium D burnt for not changing the stock cooler which rpm was going down starting frm 1800 to 500.Thts why now i bought a haofeng for my i5-2310 cost 500 which supports 1156 socket which has larger heatstink than stock cooler.My question is that will it better better to use that haofeng over stock fan?
    Pentiume D had temperature issues but this sandy bridge series are well controlled so with stock cooler will be just fine
    • Gladiator''s Gadgets
      • Asrock z68 extreme4 gen3
      • intel corei5 [email protected] 3.1Ghz with SC
      • PQ 4gb ddr3 with1333Mhz including hs
      • Western digital 500gb blue cavier
      • sapphire hd 7770 1Gb ddr5
      • SAMSUNG
      • onboard Realtek
      • MICROLAB
      • Lexma am 546
      • a4 tech kbs 720
      • xfx 650w
      • Lite on
      • Power tree
      • WINDOWS 7 Ultimate 64bit
      • wired"Techzone" and wireless GP isp
    Gladiator''s Avatar
    Dec 2011
    Nope use the stock cooler.Though i dont know much about this haofeng but usually these chinese coolers contain poor quality material on the baseplate of the heatsink.
    Intel has provided quite good coolers with their sandy bridges.Yes they cant be compared with the big boys like tt or nocuta but as a stock cooler their performance is quite appreciable.My temp range: 39-64.
    • saadbillah's Gadgets
      • Intel D945GCNL | Intel GL40
      • Core 2 Duo E6300 1.86 GHz | Pentium Dual Core T4200 2.0 GHz
      • 2 GB | 2 GB
      • 120 GB | 320 GB
      • ASUS EN8600GT 512MB Silent Edition | Intel GMA4500
      • F&D F3000U 5:1
      • Generic Crap
      • Windows XP | Windows 7
      • 64
      • 18
    saadbillah's Avatar
    your cpu fan was faulty because my pentium D stock cpu fan's rpm is 3500+ and the stock cooler keeps my pentium D 6-8 degrees cooler than haofeng.
    Quote Originally Posted by Camouflage View Post
    what was your processor temp before it died??
    Vous n'avez pas vraiment connaître quelqu'un qu'en le combattant.
      • MSI Gtx770
      • Microlab 5:1
      • HP keyboard
      • HP DVD writer
      • Apollo 1200VA
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    I saw tht arnd 91-92c through bios & thn in nwt boot blue screen & end of the line of th8 D.
  1. Sale (Used) Core 2 quad q6600 with asus p5g41t mlx3 with haofeng cooler
    By silentslipper in forum Shop - Gadgets
    Last Post: May 21st, 2012, 01:48
  2. Sale (Used) AMD CPU stock cooler
    By salmanshah in forum Shop - Gadgets
    Last Post: January 27th, 2012, 15:05
  3. Suggestion needed for replacing stock cooler AM3
    By Valkyrie™ in forum Others PC Hardware
    Last Post: May 29th, 2011, 21:55
  4. Replies: 2
    Last Post: March 2nd, 2010, 19:06
  5. Replies: 42
    Last Post: February 21st, 2010, 15:51
Page generated in 0.17311 seconds with 14 queries.
