Results 1 to 8 of 8
Thread: Help for buying 22 inch asus monitor...
    Default Help for buying 22 inch asus monitor...
    I wanna buy a 21.5 inch monitor....... I prefered ASUS ML229H........ I just heared about one month later the tax will be cut down for 22 inch..... as todays price of this monitor is 20.5 k......so i can get the monitor in 15-16 k after one month...... IS IT TRUE?????
    so i am waiting.......... nw please let me know what should i do????
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    prices will go down but i don't think it will 15/16k.....more likely to be 17/18k.....u know it takes time in bd for the reduction process
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Price won't be reduced untill they finish selling their current products, which may take this whole year
    • shafi's Gadgets
      • Gigabyte Z170 gaming 7, apple macbook pro late 2013 retina/ apple ipad air/iPad pro 9.7 iPhone 7+
      • CORE i7 6700K WITH coolermaster hyper 212 evo/intel haswell i7 2.3 ghz
      • GSkill RipJaws v 3000 32gb ddr4/16 gb ddr3 1600 mhz on mac
      • Samsung 850 evo 250gb+1tb+wd ezex 1tb, trancend 35t3 3 tb, Wd black 5tb, 950 pro, muskin 1tb
      • gigabyte gtx 1080 xtreme sli/ intel iris pro+ nvidia gt 750m 2gb gddr5
      • samsung ku 6290 4k uhd tv, Dell S2716DG
      • Sound blaster zx
      • Akg k7xx,Samson sr 850, audio technica ath m50x, ,dt 990 pro, hd 598
      • corsair vengeance k95 rgb
      • logitech g500s, g700s,g502,g402, deathadder chorma on razer goliathus speed edition
      • ps4, xbox one controller
      • corsair rm i 1000w
      • 32 gb trancend, 64gb sandisk, 16gb kingston
      • Windows 10 education, mac osx maverick 10.9.1
      • wei- cpu and ram-7.6 on stock, gfx-7.9
      • thanks a lot to omnipotent creator(as a muslim allah) for my awesome rig, xbox one and ps4
      • Teksavvy 150mbps unlimited
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    well i have bought the 23 inch version of ur mentioned model, its color quality is simply awesome, and pretty much identical to our 3d tv(the video quality) of gaming as well as still photos, it cost me around 23.5k
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by sohel-DU View Post
    Price won't be reduced to that low coz the original price is 148.11 pound, which is more than 17000 BDT. Search in the small shops other than brand shops like Global brand and you may find it for 19700-19800 BDT, though not many small shops have that model..
    • shafi's Gadgets
      • Sound blaster zx
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    SORRY TO SAY THAT i have found only 2 pieces available after searching for about a hour and 3 floors of idb, the 23 inch version was available in global and 21.5 on daffodil computers, and i took home the 23 inch version,so if u want to buy this, make haste. And also i couldn't find other branded monitors like samsung, philips, dell or hp(except the 3d monitros,) the market was flooding, when i took a visit to idb, with accer, aoc and viewsonic. And i bought the monitor on 11th august.
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Seems to me I also found the same result. I only found 2 pieces of Asus ML229H in IDB. Their dealer is Global brand but they are out of stock. There was 1 small shop from which I bought it and there was daffodil where I saw this with the price of 20800 BDT. I told them I already found it for only 19700 BDT and they were ready to reduce it's price, but I did not bother with that and bought it from the small shop...
    yup...... tnx for ur suggetion.. bt i will wait for 1 month, hope for the best..........
  1. Sale (Used) Viewsonic VA2226W 22 inch LCD Monitor
    By Master Chief in forum Shop - Gadgets
    Last Post: May 31st, 2012, 21:52
  2. Want to Buy lcd/led monitor 20/22/24/26 inch
    Last Post: March 2nd, 2012, 00:25
  3. Sale (Used) Asus 21.5 inch VH222D lcd monitor
    By Arif69 in forum Shop - Gadgets
    Last Post: June 6th, 2011, 09:24
  4. Want to Buy 15-17 inch LCD monitor
    By йЦммєя³¹ in forum Shop - Gadgets
    Last Post: May 1st, 2009, 02:44
  5. Buying a 22'/24' inch lcd monitor...
    By hasib981 in forum Technical Support
    Last Post: October 28th, 2008, 19:46
Page generated in 0.19031 seconds with 14 queries.
