Results 1 to 14 of 14
Thread: Help with an 8800GT and a lot of headscratching
    • iftybbar's Gadgets
      • Gigabyte EP43-USB3
      • E5700 @ 4GHz
      • 4GB Transcend DDR3
      • Seagate 400GB
      • 8800GT/HD5450 (temp)
      • LG1641
      • Altec Lansing ATP3
      • Logitech Generic 104 key
      • A4 Tech generic
      • Generic Chinese USB controller
      • Coolermaster GX550
      • Liteon DVD-RW
      • Windows 7 Professional x64
      • BDCOM
    Default Help with an 8800GT and a lot of headscratching
    Hello All,
    Long time lurker, and I've always been impressed with the huge expertise of the good folks here at BG.
    I'm in a bit of a situation and would like your advice:
    My config is as follows:
    E5700 with Hyper 212+, running at 4GHz
    Gigabyte P43 USB3 M/B
    4GB DDR3
    XFX 8800GT Zalman (has a VF830 on it)
    Seagate 400GB hard drive
    Gigabyte Superb 460W PSU
    The system was running fairly well until two days ago, when I updated the display drivers to 301.42. Since then, I've been getting errors such as "driver kernel has stopped responding and has been restarted." I found a guide, uninstalled (with driver sweep) and restored my old driver but the system has yet to stabilize.
    In the end, I decided to reformat and reinstall Windows 7 x64, while also resetting my bios to default (throwing off all overclocks). This made its own set of issues - windows refused to show me the desktop unless I booted up in VGA mode, and once I installed the drivers from there, every time I tried to run something 3D - the computer freezes up completely, and refuses to respond without a hard reset.
    So folks, what do I do? Is it the PSU or the GPU, or am I missing something altogether? And if I have to replace something, can you give me a clue as to how I can do it for cheap? (You know, pre-Eid, money is seriously tight)
    FWIW, my gaming needs right now are fairly limited. I was playing Final Fantasy XII with PCSX2 (hence the overclock) and Dead Space.
    Thanks!
    Edit: Temps on the GPU seem fairly cool. 61 degrees at load, mid 40s at idle. CPU peaks at 58 degrees, at sustained 100% load.
    8800GT maybe went legacy for the new drivers. MAYBE....
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    Not legacy... using 301.42 with 8800gt since they released it.
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    my 9600gt xxx also works without a hiccup on the 301.42 drivers for x64. hmmm.... must be some other factor. if i were u, the first thing i would try would be to test the gpu card seperately on a different running system and stress it for half an hour, and then check the rest of the system with a known working gpu card. if possible, give it a try.
    Try the card out on another pc, if you come across the same type of anomalies then the card itself is the culprit, but if the card proves to be okay, have your components checked one by one on another system.
      • E5700 @ 4GHz
      • Seagate 400GB
      • LG1641
      • A4 Tech generic
      • Liteon DVD-RW
      • BDCOM
    Update: Changed PSU to a Coolermaster GX550, didn't help.
    Subbed in a low-power HD5450 I had lying around and computer is stable.
    Guess it must be the card. Once in a while, after the freeze-force-reboots, the bios POST screen would get garbage on it, too.
    Any idea where I might be able to fix it, if at all? Or get an (extremely cheap) replacement, or equivalent? The 5450 doesn't cut the meat with Dead Space, though FF12 is still chugging along.
    Look in ClickBD.com and get yourself something like a 4850/5670/5770 or whatever that fits your budget, the card can be fixed temporarily, but it won't be a permanent fix as proper equipment that're required to fix it aren't available in our country, so I suggest you keep the card somewhere safe till someone imports proper tools.
    • Syeef's Gadgets
      • N/A
      • Creative SBS 2.1
      • 650VA
      • ~5 Mbps | 32 KB/s
    Quote Originally Posted by iftybbar View Post
    I think it needs reballing. Try the Oven (not microwave) trick... if you are desperate that is.
      • ASRock H55M-LE
      • LINK3
    real sry for the ot but i am having a heating problem with my 212 evo so just wanted to ask what kind of temps do u see with the 4GHz overclock when stressed with prime95 or superpi or sth else. let me know. thanks. and hope u get the xfx 8800gt running again properly again.
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    Your card got busted maybe due to poor cooling. Maybe the OC was too much for it. Did you check it in another pc ? Do that.
      • E5700 @ 4GHz
      • Seagate 400GB
      • LG1641
      • A4 Tech generic
      • Liteon DVD-RW
      • BDCOM
    Quote Originally Posted by zunaid View Post
    I see temps around 61 degrees peak with 2 prime95 instances running. Vcore is 0.05 above stock. One fan.
      • ASRock H55M-LE
      • LINK3
    hmmm.... how is that.... those are extremely good temps... is the e5700 a lower heat producer than E8400..??? and how do u run 2 prime95 instances.... didnt know abt that one. i just have 2 workers meaning 1 worker per core and i have 2 cores... so yeah... and hey, thanks for the info.... i must have really bad airflow in my case. need to work on that. and by the way, what case do u use and how many fans and what size.
      • E5700 @ 4GHz
      • Seagate 400GB
      • LG1641
      • A4 Tech generic
      • Liteon DVD-RW
      • BDCOM
    I'm not sure that the E5700 is a cooler processor than the E8400 - they're both 65W Wolfdale chips - but it does run at a much lower FSB (stock FSB is 200MHz). I'm running at 266MHz FSB because the chip has a 15x multiplier so I'm not stressing anything other than the processor, I'm guessing the E8400 would have to run a lot higher than that.
    I'm just using the fan that came with the cooler - and the case is a generic case which I've modded to fit the side panel on by adding styrofoam spacers on the side. It's not pretty, but it holds =D
    Can't post a WTB in the BG shop yet (post count is low), bummer. And every card I find on Clickbd is sold already, bummer.
    Anyone interested in selling a 4850/4870/5670/5770/GTS250/GT240 for 5k, buzz me =D 01711379034.
    btw, for the headscratching issue, you can try "Head & Shoulder Classic Clean" shampoo
  1. 8800GT RIP, should I go for the Radeon 5770?
    By faisal.amir.bd in forum GPU
    Last Post: November 27th, 2010, 15:34
  2. Sale (Used) 8800GT+Value Top 500W
    By Hamilton in forum Shop - Gadgets
    Last Post: November 7th, 2010, 09:56
  3. Closed XFX 8800GT Alpha Dog XXX Edition
    By Evil Ryu in forum Shop - Gadgets
    Last Post: May 9th, 2009, 12:20
  4. XFX 8800gt AlphaDOg XXX help!!!!!!
    By Cyber_Shot in forum GPU
    Last Post: February 18th, 2009, 03:06
  5. About 8800gt!
    By acE.Shanny in forum GPU
    Last Post: January 28th, 2009, 14:44
Page generated in 0.24712 seconds with 14 queries.
