Results 1 to 19 of 19
Thread: too much problems with BTCL
    • gamefreak's Gadgets
      • Gigabyte H55-S2V
      • Core i5-760 2.8GHz
      • Micron 2GB DDR3 x 2=4GB
      • Samsung 500GB 5400 RPM SATA
      • Gigabyte ATi Radeon HD 5750 1GB GDDR5
      • Samsung SyncMaster 793DF 17'' CRT
      • Creative Inspire 2:1
      • A4 Tech AntiRSI
      • A4 Tech
      • Xbox 360 Wired Controller For Windows
      • Gigabyte Superb 550P
      • Samsung DVD-RW
      • Rahimafrooz 800 VA
      • Win7 32-bit
      • bought it a month ago....going pretty well....thanks to BG....
      • 16-18
    Solar System
    Default too much problems with BTCL
    for the last 10 days or so i can't use my net properly. ADSL light remains stable but i can't browse for long enough in either chrome or mozilla. why is that? while this happens my torrent works perfectly. for browsing to run smoothly again i need to restart my pc again. it is worth mentioning that 192.168.1.1 can't also be opened in my browser while the problem persists.
    i tried contacting EMEM but their customer service is so pathetic i feel like punching them all in their faces. last tuesday they told me that by that night the problem will be solved. although i can enjoy better browsing time than before.
    another thing i have noticed today is that while i try downloading a video using IDM, i face the same browsing issue. for 3-4 mins IDM keeps on downloading while browsing remains stable along with my torrent. then after 3-4 mins IDM can not gather any dl speed & my browsing also stops. in all these torrent works fine with the normal speed i normally enjoy.
    HELP/SOLUTION?
    Cleveland, Ohio.
    try changing ur dns settings.
    Google DNS is a good start https://developers.google.com/speed/public-dns/
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    What about torrent downloading? Does it remain stable? It happened to me a few days back. The problem looks now solved. Ping google from cmd and see if there's any packet loss.
    (If your torrent download is just fine, the problem might have something to do with port 80.)
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    yes torrent is ok.
    Quote Originally Posted by xK0ZAKx View Post
    i already use google DNS.
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    You might want to format your operating system and see if the problem persists.
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    apparently for the last 3 hours i have not faced any problems.
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    @xKOZAKx @Nikomia guys my ping is pretty high when i checked using cmd. it's 103ms. so my browsing is slow. any help?
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Quote Originally Posted by gamefreak View Post
    Ping to what? (BTCL ping fluctuates a lot in the rainy season. It's normal for your ping to be high. Wait a day or so and see if it improves.)
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    ping to google.com.
    one more thing. from last wednesday i was having frequent disconnections. tried contacting EMEM but no reply. so i called a lineman yesterday to check the line in the main tel. box. he made some tweaks (said there was some loose connection) but even after that i faced disconnections. so went to EMEM last evening to file a complaint. after returning home i found my net was stable till 7am today. but after iftar today i am again facing frequent disconnections. SNR seems to fluctuate a lot. it is 5.4/6.0 while i am writing.
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    What exchange are you under?
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    Dhaka cantonment
    Dhaka cantonment
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Dhaka cantonment
    Dhaka cantonment
    As far as I know, you shouldn't face frequent disconnection being under DC. Only those of us who are under SBN face frequent disconnection. Your problem is similar to the problem I've lately faced. It matches verbatim. Anyway, what are the first 3 digits of the TNT number through which you got this line?
    @faisal.amir.bd could help I believe.
    • faisal.amir.bd's Gadgets
      • ABIT IP35 Dark Raider
      • Intel Core 2 Duo [email protected]
      • 2GB Transcend AxeRam DDR-2 800+ @816MHz
      • 820GB (320GB Hitachi, 500GB Samsung)
      • Gigabyte Radeon HD5770 1GB DDR5 (Batmobile Cooler)
      • ASUS MS228H 1080p LED backlit
      • Creative Sound Blaster Live! 5.1
      • Creative Inspire 5200 (5.1)
      • XBOX 360 wired gamepad
      • Thermaltake TR2 600W
      • Rahim Afrooz 1000VA
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    faisal.amir.bd's Avatar
    Atlanta
    If the SNR is this low it is definitely a local problem, assuming your modem is OK.
    However, the fact that you cannot browse, whereas torrents are running fine in the background, suggests something else. Moreover, the fact that you cannot even enter your modem further narrows the problem down. Your modem is the culprit, most likely.
    When you're facing these issues, can you ping 192.168.1.1 i.e. your modem?
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    Quote Originally Posted by faisal.amir.bd View Post
    suddenly from 3am last night onwards i can browse properly with occasional disconnection as expected during the rainy season. but otherwise ATM it's fine.
    about pinging 192.168.1.1 do u mean going going for http:\\192.168.1.1 using my browser while there is the problem? if yes then yes i have faced problems while trying to open modem settings in the browser (i.e. http:\\192.168.1.1)
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    Atlanta
    Not really, what I meant was going to command prompt, and typing "ping 192.168.1.1 -t". There should be a reply from your modem. Try that the next time the problem occurs. It's probably the modem dying.
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    so the problem appeared again. i tired pinging from cmd as you instructed. and there was the following reply:
    one more thing. why doesn't emem pick up any of my calls? or is it same for you & others? they have become really s&*% in the last month or so.
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    Atlanta
    Hmm, the modem is responding to ping requests, but anyways, I think the modem is behind your problem, since you cannot access it during your problems. Maybe you could try borrowing a modem from someone?
      • Gigabyte H55-S2V
      • A4 Tech AntiRSI
      • A4 Tech
      • Samsung DVD-RW
      • Win7 32-bit
      • 16-18
    Solar System
    i could but there is none i know who use BTCL.
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    try manual resetting and then if the problem still occurs try upgrading firmware
  1. Facing problems !!! need help
    By Ic3_STrik3R in forum XBOX
    Last Post: March 7th, 2011, 12:43
  2. facing problems with gts 250...!!!!
    By morshedkhan97 in forum Technical Support
    Last Post: February 27th, 2010, 14:20
  3. game problems
    Last Post: December 3rd, 2009, 12:25
  4. Problems!!
    By Deep -xCross- in forum Technical Support
    Last Post: May 27th, 2008, 11:22
  5. Farming problems
    By kabir_sharif2000 in forum DotA Talk
    Last Post: May 21st, 2008, 13:42
Page generated in 0.28527 seconds with 15 queries.
