Thread: Need help with my graphics card
    Default Need help with my graphics card
    Can anyone help me I am using Nvidia Geforce GT240 and for a few days ago the cards fan stoped working. I cleaned it but still not working. When i play games the heat level are going over 70. I have no warranty now so can anybody have any solution or know any place where i can fix this problem then i will be very grateful.
    It is a great card and I don't want to lose it and thank you for your support.
       0
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    check the cables that run between the fan and the card....may be it is a simple soulering problem
       0 Mobile
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    If the fan is not working, you shouldn't use it until it is fixed. And Don't try running games with the fan off.
       0
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    ok, i had similar problem with a geforce 8500GT. then i figured out that, if i start the pc and manualy spin the fan for sometime ,it would work then. if the fan power connection is ok, u may try this.
       0
    But that doesn't solve the problem permanently
       0
  1. I need a Graphics card and a PSU
    By jigsaw in forum Others PC Hardware
    Last Post: February 14th, 2010, 13:08
  2. i want to buy a graphics card...need help....
    By morshedkhan97 in forum Technical Support
    Last Post: January 11th, 2010, 19:45
  3. which Graphics card is better ????
    By cybervirus007 in forum GPU
    Last Post: December 19th, 2008, 12:42
  4. Replies: 2
    Last Post: April 10th, 2008, 17:17
Page generated in 0.16573 seconds with 14 queries.
