Results 1 to 20 of 22
Thread: Max Payne 3 BSOD problem
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Default Max Payne 3 BSOD problem
    I have a 7 DVD copy.
    I followed the instruction
    2, Install social club
    3. Install the game. When it tries to get updates after install, abort
    4. Copy over the cracked content, ie. the rest of the files, from the Crack
    dir on DVD7 to your installation dir
    5.Copy "update" to youre "profile" dir in games install dir.
    But every time i try to run the game or even some times entering the Game folder is causing BSOD.
    Any help or update of the crack??????????????????????
    • Md. Asif's Gadgets
      • ASRock Z68 extreme3 Gen3
      • Core i5 2500k(4.4 GHz) with coolermaster hyper 412 slim
      • 8 GB Transcend 4*2(1600 MHz)
      • Hitachi 1 TB
      • Gigabyte gtx 670 oc Windforce 3x
      • Samsung syncmaster 943 19"
      • Creative inspires 2.1
      • A4 tech office
      • Logitech F310
      • Thermaltake smart modular 550 W
      • DVD ROM
      • Luminous solo 1200 VA
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    update your windows 7 to sp1
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    I already have windows 7 SP 1
    Nvidia driver updated 301.42
    • maniac's Gadgets
      • intel DG31PR
      • core 2 duo E4300
      • Transcend 2 GB 800 bus
      • 750 GB
      • gigabyte ati radeon 5670 ddr5 1gb
      • 22 inch samsung lcd
    maniac's Avatar
    Feb 2009
    mohammadpur,Dhaka
    follow these steps and u will be able to play without any problem
    1. turn off your AV
    2. and then reinstall this repack, but DON’T tick automatic desktop shortcut and start menu on BlackBox installation menu installer, cause you will got BSOD
    3. wait for installation done
    4. after finish, replace the maxpayne.exe and applying the update v1.0.0.22 from Reloaded to your MP3 installation folder (ask google for this!)
    5. start playing the game from playmaxpayne.exe
    oops,didnt see that u have dvd copy,still try to use the update,that might just do the trick
    • Single Player's Gadgets
      • Foxconn H55MXV
      • Core i3 540
      • 2+2 GB DDR3 (1333 MHz)
      • 400 GB Samsung(320+80 @ 7200RPM)
      • 1 GB HD5570 DDR3
      • Samsung 793DF
      • Realtek HD Audio | Creative Sound Blaster Live!
      • Creative 4400 4:1
      • A4Tech KRS-86 Multimedia
      • Havit HV-MS686
      • TT Lite Power W0316
      • 24x ASUS DVD RW
      • 16GB + 8GB Tanscend
      • Windows7 (x64)
      • Not gonna upgrade
      • DFN BD
      • 600-650 Kb/s
    Single Player's Avatar
    Dec 2011
    চেয়ারের উপর
    Check Max Payne 3 Thread for solution.Here
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @maniac
    Thanks. I will give it a try and let you know.
    Update
    @maniac is your instruction is for one with 3 DVD copy??????????
      • Foxconn H55MXV
      • Core i3 540
      • 1 GB HD5570 DDR3
      • Samsung 793DF
      • Creative 4400 4:1
      • Havit HV-MS686
      • 24x ASUS DVD RW
      • Windows7 (x64)
      • Not gonna upgrade
      • DFN BD
      • 600-650 Kb/s
    Dec 2011
    চেয়ারের উপর
    Quote Originally Posted by maniac View Post
    1. turn off your AV
    I think he is using Reloaded version not blackbox.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Which one is better reloaded or black box?
    Where can i get one????????????? I mean which shop?
    • Sumit Pramanik's Gadgets
      • Asus Maximus V Formula With ThermalTake Armor A60 Chassis
      • Intel Core i5 2500K 3.3GHz with CoolerMaster Hyper 212X
      • GSkill TridentX - F3-2400C10D-8GTX
      • SanDisk Extreme SSD 120GB, WD Caviar Black 2TB x 2, WD Caviar Green 500GB
      • ASUS GeForce GTX 960 STRIX-GTX960-DC2OC-4GD5
      • LG 22MP68VQ-P 21.5 inch
      • Microlab B70 Speaker System; Sennheiser HD598SE
      • Corsair K95 RGB Platinum
      • Asus ROG Gladius II
      • Don't need one..........
      • Delta EX GPS-650AB B 650W
      • PowerTree S1250P 1250VA
      • Windows 10 Professional
      • Up-gradation Completed. Online. All system stable. Now I can sleep.
      • Quick Online (Earth Telecommunication Pvt. Limited)
      • 4Mbps
      • 4Mbps
    Sumit Pramanik's Avatar
    Oct 2010
    Quote Originally Posted by fahimspider View Post
    You can't compare between two different thing. Blackbox is compressed version of Reloaded release which converts 1080P videos to 720P video and only English language. but there is some version in TPB(piratebay) that has Reloaded version only in English/Russian language & Single player. No other things cropped (Video Resolution). Size around 17GB. Original one is around 24GB.
    For DVD you can search IDB/Multiplan shops. but there are 6/7 Disc for full game and 5 Disc for English & 3 Disc for blackBox, now its your choice........
    We all fall down
    We live somehow
    We learn what doesn’t kill us makes us stronger
    • Nirzhar Uchiha's Gadgets
      • ASrock B75 Pro3-M
      • Intel Core i7 2600 @3.40 ghz
      • 2x 4 GB Transcend 1333 mhz
      • Toshiba 1TB + Adata 128gb SSD
      • MSI GTX 770 2GB OC
      • LG 22MP65HQ 22" 1080p IPS LED
      • Creative SB X-fi Titaniium
      • On Ear: Sony MDR XB950BT / IEM: Soundmagic es18
      • Cooler Master Octane Keyboard
      • Logitech M280 Wireless
      • Xbox One + DualShock 4
      • Gigabyte Pulse 600w [80+ Bronze]
      • TechFine 1200VA
      • Windows 10 Pro 64 bit
      • Bought it on 5 may,2012 from elephant road.. upgrading started on February,2013 :)
      • SkyView Online [3 mbps]
      • 370 kBps [International] 11mBps [Local]
      • 200/200 kBps [International/local]
    Nirzhar Uchiha's Avatar
    Dhaka, Bangladesh, Bangladesh
    i had the 7 dvd copy.. And faced the same prob.. After a week hard work i finally made the game to work n successfully finished..
    Heres procedure
    1.install the game
    2.download update 1.0.22 n replace it with original game exe file
    3.copy 'profile' folder to documents/rockstar games/maxpayne3 (or something like that)
    4.turn of net connection
    5.start the game
    6.if u face the long loading prob (u probably will) install the latest social club v1.0.9.5 (not sure about the dots but '95' at the end)
    now ur game should work fine
    update ur windows even u already hav win7 sp1...mayb its not an av prob or setup prob...hope it works...
      • Foxconn H55MXV
      • Core i3 540
      • 1 GB HD5570 DDR3
      • Samsung 793DF
      • Creative 4400 4:1
      • Havit HV-MS686
      • 24x ASUS DVD RW
      • Windows7 (x64)
      • Not gonna upgrade
      • DFN BD
      • 600-650 Kb/s
    Dec 2011
    চেয়ারের উপর
    Remember to block all types of connection of MaxPayne3.exe from windows firewall.
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Quote Originally Posted by Sumit Pramanik View Post
    Blackbox ta ki publisher...ar eita ki valo...?
      • 4Mbps
      • 4Mbps
    Oct 2010
    Nope, eita ekta group jara game Repack kore and They dont do cracking too..... Only Repacking is their buisness
    As I mentioned before... Blackbox is compressed version of Reloaded release which converts 1080P videos to 720P video and only English language. So you will loss some quality in Blackbox....... Thats all...........
    We all fall down
    We live somehow
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Will there be all the game videos included...!
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    well,I was running the game perfectly till day b4 yesterday...but when i closed my game and wanted to play yesterday...BSOD occurs when i open the exe file...onek bar try korar por o kono kisu holo na...problem persisted...any solutions anyone??
      • 4Mbps
      • 4Mbps
    Oct 2010
    yap,but low resolution..........
    We all fall down
    We live somehow
      • ASrock B75 Pro3-M
      • TechFine 1200VA
    Quote Originally Posted by giant View Post
    a friend of mine had the blackbox version of batman arkham city.. It didnt have a lot of videos.. Even the final cutscene was missing..he had to see it on youtube
    Default Problem with 5 dvd version of Max Payne 3
    Guys, Ami 5 dvd version ta kinlam...IT next er..essential software gula install korar pore just extract korte hoy..thn social club install korete ho..thn finally crack contents( profile) gula my documents e apste korte hoy, not game directory..as epr instruction "playmaxpayne3.exe" diye game open korte gele bole " could not locate game executable, please re-install"....ekhane to install korar o kono option daye nai basically...any solution???
    that BSOD is a pain!
    i had 3 dvd copy of PC DVD. i think it was a blackbox release.
    i had to go through various random forums to get a suitable update patch and latest Social Club (apparently the Social Club given in the DVD was not up to date). and... yah i had win 7 and had to update it to win 7 Service Pack 1 and updated my Nvidia gpu driver.
    you need to identify which release do you have? Blackbox/Reloaded. then you can look for a suitable patch.
  1. Constant BSOD //HELP ME OUT//
    By nafis087 in forum Technical Support
    Last Post: August 4th, 2012, 22:42
  2. Max Payne 3 installation problem
    By gamefreak in forum Action-Adventure
    Last Post: August 1st, 2012, 02:58
  3. BSOD i guess
    By gamefreak in forum Technical Support
    Last Post: July 24th, 2012, 22:28
  4. Max Payne 3 installation problem
    By furiousTaher in forum Action-Adventure
    Last Post: July 2nd, 2012, 17:26
  5. Bsod
    Last Post: December 5th, 2011, 20:56
Page generated in 0.30138 seconds with 14 queries.
