Results 1 to 12 of 12
Thread: XBOX 360 Controller and Sound Problems
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    Unhappy XBOX 360 Controller and Sound Problems
    Hello Guys of BG, i have a couple of problems with my XBOX 360 Controller and an audio problem, the first problem is that my controller is Wireless and when ingame the Controller Vibrates the controller gets disconnected, now i know that's a common problem among Xbox 360 users but i REALLY Need to know where to have this problem fixed like Bashundhara City or IDB, i also have a Plug and Charge Kit, but i don't like using it since it restricts my mobility, and i REALLY Don't want to buy another Controller. Now to the 2nd Problem, you know how the sound is when you watch a Movie in VLC Player at 400% OR 200% (in the latest version) and the sound gets all fuzzy and stuff thats exactly what happens to me in some parts of a game like an exploding scene, Btw i use a Toshiba LCD TV, and i have bass boost and surround enabled and with surround off the fuzziness decreases but not completely so any help is appreciated.
    • ramiz's Gadgets
      • MSI 880GMS - E35
      • AMD Phenom II X4
      • 2 + 4GB Transcend DDR3 1333MHZ
      • Samsung 500GB
      • Gigabyte Radeon 6770
      • Benq GL930
      • Built In Realtek
      • Panasonic RP HTF600
      • 2 Genuine Xbox360 wireless controllers
      • Thermaltake lite power 430W
      • Sony DVD RW
      • Xbox 360 wireless receiver for windows
      • Windows 7 64 Bit Ultimate
    ramiz's Avatar
    Oblivion
    the controller getting disconnected when it vibrates ingame is not caused because your controller is faulty or anything, rather your batteries are running low nd all you need to do is get em changed. As for the sound issue, sorry but I can't really help you.
    Member mahadi360's Avatar
    Mar 2012
    Shaymoli,Dhaka
    when did the sound problem first showed up?? or is it from the beginning??
    You are that,what you are in BLACK
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Quote Originally Posted by ramiz View Post
    Well it seems the battery finishes within like 5 hours or so, and i can't find rechargeable batteries here and EVEN WHEN I HAD full batteries this im pretty sure happened ingame.
    @mahadi360 i don't know for sure, because i've had this xbox 360 for 3 years and i went hiatus for 1 and a half years ( i know real f'ed up) and maybe it wasnt from the beginning i really wish i could record the sound but theres to much noise around me.
    Mar 2012
    Shaymoli,Dhaka
    well you can look up in bd,because i think at least there will be a shop which they have it...
    And you can check the cables.if u r using HDMI,(local HDMI cable around 400-800 tk,shows this problm after 2-3 yrs),then just check another cable and,try it! i guess it will work then ..
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Quote Originally Posted by mahadi360 View Post
    Well actually im using the component HD cable which is brought from NY and its still in good condition, so i'm guessing its not with the cable, could be with tv or xbox 360.
    Mar 2012
    Shaymoli,Dhaka
    Quote Originally Posted by TheNutKicker View Post
    well if any of ur friends have a HDMI cable,u can give a try,or maybe the prblem is with TV or XBOX;experiment always brings good results!!
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    I'm Guessing you wouldn't know how to connect a Phillips 5.1 Surround Speaker to my Xbox 360 would you.
    Mar 2012
    Shaymoli,Dhaka
    Nope sorry,i'm a noob
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Umm, My Wireless Controller thingy is fixed but im too poor to go to the store and buy batteries every 6-10 hours, and my Play and Charge kit is causing my power brick to get Red Lights so i think i need to buy another power brick and maybe another play and charge kit (its also making noise, buts i expected that since it blew it and someone fixed it) you wouldn't know where to buy one would you.
    Mar 2012
    Shaymoli,Dhaka
    well.you can contact these ads,i'm not sure,but they are in BD :
    http://www.clickbd.com/bangladesh/45...360-black.html
    you may try ''electronic museum in rifels square'' you will find it there!! and of course you can go to bashundhara city level 7.i don't have the idea of particuler shops,but i think you will find it there
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Yeah its official my plug and charge kit is dead ok then 'SALUTE ARMS, FIRE'
  1. Problems connection xbox to xbox live
    By x360gamer in forum XBOX
    Last Post: July 14th, 2012, 00:45
  2. Replies: 4
    Last Post: July 13th, 2012, 21:25
  3. Replies: 5
    Last Post: August 14th, 2011, 23:24
  4. Replies: 1
    Last Post: May 22nd, 2011, 22:36
  5. Replies: 4
    Last Post: July 8th, 2010, 17:35
Page generated in 0.23487 seconds with 14 queries.
