Thread: Some Common Xbox 360 problems!!And Their Reasons!!!Must See!!
    • 4 months Left's Gadgets
      • Asus.{Dont know Model}
      • Celeron 2.8 GHZ. Angry???
      • 1.5 gb.
      • 60 gb. Are u laughing??
      • nvdia geforce agp8x 128mb.Smiling??
      • Samsung Eco Magic 22 inc
      • Sb Live! Ct4830.A sound Card outdated Before My birth.
      • Speaker CamBridge Sound works And Headphones Sony
      • Lexma (bijoy Version)
      • Benq P150 Optical Mouse
      • No controllers
      • Asus Power Tack
      • PowerGuard
      • Windows 7 Ultimate 32bit
      • Dont know
      • Will Be updated For Gaming in Dec12 Insaallah!!
      • Qubee 1mb/s
      • 135 kb/s
      • 138
    4 months Left's Avatar
    Under your bed.Over ur head.Actually im Dead
    Default Some Common Xbox 360 problems!!And Their Reasons!!!Must See!!
    Here I am Going to post Some Common Xbox 360 problems and Reasons.. to tell.i can tell in short which might help you out.
    **Problem 1.Middle of the Game This error "'Game Error This Disc Is Unreadable'''
    **Reason:Bad Burn,Bad Disc,your Lens Weak,The disc Is Dirty.
    **Fix:Change Disc.
    **Problem 2.On Dashboard When U Hit play the Game [eg. Play Max Payne 3] After a few seconds The game Even Does Not Appears Says The disc is Unread able.
    **Reason:Same as Problem 1's Reason
    **Fix:Change Disc Bro.
    **Problem 3. The Disc Is Unsupported
    **Reason:Your Current Firmware Is LT+2.0 and You are Trying To play And LT+3.0 burnt disc or LT+3.0 game.Or,Your Firmware Is LT+3.0 and your trying to play and LT+2.0 game or disc.
    **Fix:Read The Reason Carefully.Now use Ur common sense To pick the Fix
    **Problem 4. After U Insert A Disc says play game and the picture of the game does not appears.When U hit play game Says Unreadable Disc.
    **Reason:U are using a Modified Phat Drive In a slim Console{That's what the shop guys of basundhara did to me.And I am Facing all Problems specially lens Problems}Lens Problem,DVD drive is gone or Dead.
    **Fix:Change Lens,Kill The shop guy.
    **Problem 5:Xbox 360 Frequently Freezes.
    **Reason:Major Problem
    **Fix:Go to www.facebook.com/techmology and Post about Your Problem.
    **Problem 6:Xbox 360 Showing 3 red rings.
    **Reason:Hardware Failure,Over Heating.
    **Fix:Your Out Of Luck.Its Dead.Thats Why this problem is called Red Rings Of DEATH.
    I'll Update about More Problems very soon Insaallah.Hope This Helps Somebody.Please make this Thread Sticky @aayman and Any other problems then go to www.facebook.com/techmology its ur best bet.
    Time And Tide Waits For None...But When History repeats Him self,At the end Of the Day.....They wait for politicians.
    • -xeibit's Gadgets
      • MSI B85-G43 Gaming
      • Intel i5 4590
      • Gskill ripjaws 16GB @ 1600MHz
      • WD 1TB BLUE
      • Sapphire R9 380 Nitro 4GB
      • Dell S2240L
      • Turtle Beach EarForce X-RAY
      • CM Storm Quickfire Rapid (MX BLUE) with PBT Blank White Keycaps
      • Steelseries Sensei Paired with Hyper X Fuxy (Large)
      • XFX Xgear Dual Reflex Controller
      • Thermaltake Smartpower 630w Modular
      • <3
      • 128 KBps
      • 96 KBps
    -xeibit's Avatar
    Amr Problem 4 ta hoa shuru korse lt2 korar por theke -_-. Ami sure silam je mod korse or kaj aita. Pore bole 4k dia lens lagaite hobe notun
    Ple
    ase Quote or PM me if you want a response.
      • 1.5 gb.
      • No controllers
      • Asus Power Tack
      • PowerGuard
      • Dont know
      • Qubee 1mb/s
      • 135 kb/s
      • 138
    Post Edited.See Guys.Might Help If you are Stuck.
    acchah 6no. problem ta howar karon ki sudhu over heating??? eta jate na hoy tar jonno ki primitive step nwa uchit? :s
      • 1.5 gb.
      • No controllers
      • Asus Power Tack
      • PowerGuard
      • Dont know
      • Qubee 1mb/s
      • 135 kb/s
      • 138
    Keep it on a cool place.And If its Caused by hardware failure,ur out of luck. @tapos
  1. Problems connection xbox to xbox live
    By x360gamer in forum XBOX
    Last Post: July 14th, 2012, 00:45
  2. my newly bought xbox 360 slim PROBLEMS
    By marufzubery in forum XBOX
    Last Post: February 24th, 2012, 16:34
  3. Can I Play Xbox Live With Smile, Without Any Problems?
    By SinisterFahim in forum Smile/BDCom
    Last Post: April 26th, 2011, 06:03
  4. Replies: 3
    Last Post: October 14th, 2010, 23:25
  5. Replies: 4
    Last Post: July 8th, 2010, 17:35
Page generated in 0.17480 seconds with 14 queries.
