Thread: [HELP!!!] GPU temp problem
    • OoAIDoO's Gadgets
      • Gigabyte GA-Z68A-D3-B3
      • Kingston HyperX 2 x 2 GB 1600 MHz
      • Corsair F60 + Samsung 1TB + 1.5TB
      • Gigabyte HD 5670 GDDR5
      • Fujitsu 24 inch TFT LCD
      • Creative Sound Blaster X-Fi Titanium
      • Shure SRH440 Professional Studio Headphone
      • Logitech G110
      • A4 Tech X7 XL-747H
      • PS3 DS3 Controller :P
      • XFX Core Edition PRO550W
      • ASUS DVD-ROM
      • iPod Touch 4G + StoreJet 25D3 USB3 500GB
      • Micro 1000VA
      • IS Pros
      • 256 kbps or 32 KB
      • 256 kbps or 32 KB
    OoAIDoO's Avatar
    Azimpur Dhaka
    Default [HELP!!!] GPU temp problem
    my 5670 ddr5 was doing fine until yesterday
    now temp is ~65 degree c at idle and shows garbage(also hangs) when i start any game
    what should i do now?!!! pls help
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Quote Originally Posted by OoAIDoO View Post
    i think the cooling is loose somehow or the paste dried
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    and also check the cooling fan is running properly
    • king_showrav416's Gadgets
      • Gigabyte H55M-S2V
      • Intel Core i3-530 @3.3GHz
      • TwinMOS Twister @1600Mhz 4GB with Heat Sink
      • SAMSUNG HD502HJ 500GB
      • MSI R6850 Cyclone PE/OC
      • SAMSUNG 20" LED SA300
      • Realtek HD audio Built in
      • Creative inspire 2:1|| A4tech HS-28
      • Logitech Y-SZ49
      • A4TECH K4-28D
      • ThermalTake Tr2 380w 80+ Bronze
      • Samsung DVDRW SH-S223c
      • Team 4GB Pen drive
      • Windows 7 Ultimate SP1 64bit
      • HaPPY :)
      • BTCL 512kbps
      • ~64
      • 28
    king_showrav416's Avatar
    Oct 2011
    bro gfx aar heatsink aar fan ta kaaj korche tho???? amar akbar 4670 te fan atke gia chilo akbar hoisilo airokom tokon Idle deki 40-43 aar modde thakto 68 ae uthe gia chilo tokon ami 5ta tab khule browsing korsilam......... just akta khocha dea te gura start hoa chilo......
    • OoAIDoO's Gadgets
      • Logitech G110
      • ASUS DVD-ROM
      • Micro 1000VA
      • IS Pros
      • 256 kbps or 32 KB
      • 256 kbps or 32 KB
    OoAIDoO's Avatar
    Azimpur Dhaka
    fan works, PC hangs even at 100% speed
    thermal paste might be the concern
    but i dont have any thermal paste
    • babu.'s Gadgets
      • Gigabyte H81 S2PV/ Gigabyte B75 D3V
      • Core i5 4590/ i5 3470
      • 8 GB Adata XPG 1600 @ CL9/ 8 GB Team
      • 3 TB WD Blue
      • Shaphire R9 270X VaporX
      • LG 22'' mp65HQ/ Dell 17''
      • Altec VS4621, Skullcandy INK,D airphone
      • Tharmaltake TR2 600w/ TT LP 430w
      • Transcend 2TB Portable HDD
      • Windows 10, 7(64 bit)
      • CPU - 7.6, Ram - 7.7, GPU 7.9, HDD - 5.9
    babu.'s Avatar
    Mar 2012
    Khulna
    Try to check ur gpu with ati tray tools. pretty useful software. use artifact scan with gpu processor + memory. it can detects internal failure.
    • wayne's Gadgets
      • MSI 880GMS-E35 Themaltake Commander ms-i
      • AMD Phenom II X4 965 Black Edition 3.40GHz cooled by Cooler Master Hyper 212+
      • Transcend 8GB 1333MHz
      • Samsung HDD 1TB 7200RPM
      • Saphire Radeon HD7850 OC 2GB Dual-X Edition
      • Dell 21.5 inch S2240L
      • Realtek HD
      • Sony Ericsson HPM-85
      • A4 Tech KR 85
      • A4-tech Bloody GUN3 V3
      • X-box 360 controller for windows
      • Corsire VS450W
      • HP DVD-RW
      • Trancend 32GB USB 3.0
      • X
      • Windows 10 TP
      • happy enough :)
      • New Lava Communications
      • 107~114 kbps
      • 100~200 kbps
    wayne's Avatar
    Dec 2011
    you can buy thermal paste from ucc.
    If y have warrenty on your gpu then take it to service center
  1. ECS GTX 550Ti Temp......:O
    By musvi in forum GPU
    Last Post: March 31st, 2012, 15:13
  2. cpu temp and core temp
    By Md. Asif in forum CPU
    Last Post: October 19th, 2011, 04:12
  3. Problem with CPU core temp.
    By salmanshah in forum CPU
    Last Post: January 14th, 2011, 19:11
  4. core i5 high temp problem
    Last Post: January 12th, 2011, 04:34
  5. Team temp
    By ЯV●1ShoT in forum CS: Source
    Last Post: November 10th, 2008, 00:44
Page generated in 0.18788 seconds with 14 queries.
