Thread: Max Payne 3 installation problem
    Exclamation Max Payne 3 installation problem
    Readme-
    2, Install social club
    3. Install the game. When it tries to get updates after install, abort
    4. Copy over the cracked content, ie. the rest of the files, from the Crack
    dir on DVD7 to your installation dir
    5.Copy "update" to youre "profile" dir in games install dir.
    social club install korsi...
    crack folder e dhukte kono problem hosse na, unlike some other users.
    But crack copy kon folder e korbo bujtesi na,readme te sposto kore bole nai..
    1st crack folder tar moddhe sg_mp3cr folder tar data gula niye game directory te paste korlam...
    erpor update folder tar moddhe common folder niye copy paste korlam game dir e...
    platform folder tao copy paste korlam...kintu platform name age theke game dir e kono folder silo na... so platform er data gula pc folder tar moddheo paste korlam.
    Still game offline mode e run korte chaile bole
    [Code]
    Dynamic library Gsrld.dll failed to load
    [Code]
    Npp release... crack ke korse jani na... mone hoy reloaded
    using win7 64bit
    pliz help
    • Reventon's Gadgets
      • Gigabyte H67MA-D2H
      • Intel Core i5 2400 3.1 ghz.
      • 4 GB DDR3 1600 BUS CL7 OCZ FATALITY EDITION
      • WD CAVIER BLACK 1 TB
      • Sapphire AMD 7870 GHZ edition
      • PHILIPS 224EL LED 1080p HDMI+DVI
      • ON BOARD
      • 4:1 creative inspire
      • a4 tech
      • a4 tech
      • COOLER MASTER SILENT PRO 600W
      • Samsung.
      • should be better
    Reventon's Avatar
    Sep 2009
    Moghbazar
    Exactly same problem...can anyone plz help us....
    People should stop blaming games for allegedly *copying* each other: "oh this game is Skyrim copy", "this game is WoW knock off", "this game is just another DMC" - enough!
    On this rate every 3rd person action will be God of War, every 3rd p shooter Gears, every 1st will be CoD.. it's ridiculous. They are called genres people! And if you look carefully you'll see allot more than mimicry out there.
    • wackedGUNZ's Gadgets
      • Gigabyte B75M-D3H [Case: InWin Mana 136]
      • Intel Core i5-3450 @3.1Ghz
      • Twinmos Mainstream 4GBx1 1600Mhz
      • Western Digital Cavier Blue 1TB 64MB Cache
      • Sapphire R7 260X 2GB OC
      • AOC i2269VWm IPS 21.5inch
      • Realtek Azalia ALC887
      • Microlab FC-360
      • Razer Deathadder 3.5G Black Edition
      • Corsair VS-450
      • Asus 24X DRW-24B3ST DVD Burner
      • Sentron 1200VA
      • Windows 7 Ultimate
      • lol...don't care!
      • nearly full :)
      • zxonline
      • 160kBps or 1.2mbps
      • same as above
    wackedGUNZ's Avatar
    Quote Originally Posted by Taher fu®ious™ View Post
    Readme-
    [Code]
    [Code]
    using win7 64bit
    pliz help
    Quote Originally Posted by Reventon View Post
    amr mone hoy you guys should try the theta or revolt crack. Everyone here posted that revolt crack is flawless and also the theta crack is working great. So, you might try that instead of the crack that came with the DVD>
    reloaded crack r update thik moto instruction follow korlam... ekhon game cholbe but loading screen e atkay thake!
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Intel Corei5 2320 3.0Ghz
      • Twinmos DDR3 4gb 1333bus
      • Samsung 500gb sata
      • ATI Radeon 6670 GDDR5 1GB
      • Dell s1909w 18.5inch LCD
      • Realtek HD
      • Delux 2:1
      • A4TECH . 2.4G wireless keyboard (GR-152)
      • A4TECH 2.4G wireless PADLESS MOUSE (G9-730FX )
      • Logic
      • ValueTop [Blue] 400w
      • ASUS 24x Sata DVD Writter
      • Ipod Classic 2GB,4gb Siliconpwer Pendrive
      • Windows 7 Ultimate 64bit
      • CPU : 7.4 RAM : 7.4 GAMING GRAPHICS : 7.1 GRAPHICS 7.1 HDD : 5.9
      • I LoVe My RiG nd It Will Be More Updated Soon ;)
      • Banglalion Wimax 1mbps Pre-paid
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    Taher bro turn off ur antivirus/firewall n disconnect ur net connection and also update ur social club to 1.0.0.9.5 or something like this..i was facing similar prblms wid the npp 7 dvd version bt now it is solved..
    If the above process dnt wrk then reinstall win7sp1
    whats going on max payne 3 7dvd or 3dvd?????................its a rideculous problem for all gamerz..........i can't run this bulllshit in my pc and laptop........'read me' file of the dvd is properly mentioned things............i try to all of them in my pc 5 times.........but it just showing me 'Max Payne 3' loading screen.............tht's all..........i can't with my patience for this one of my favourite game.......plz help me anybody........
    • Nirzhar Uchiha's Gadgets
      • ASrock B75 Pro3-M
      • Intel Core i7 2600 @3.40 ghz
      • 2x 4 GB Transcend 1333 mhz
      • Toshiba 1TB + Adata 128gb SSD
      • MSI GTX 770 2GB OC
      • LG 22MP65HQ 22" 1080p IPS LED
      • Creative SB X-fi Titaniium
      • On Ear: Sony MDR XB950BT / IEM: Soundmagic es18
      • Cooler Master Octane Keyboard
      • Logitech M280 Wireless
      • Xbox One + DualShock 4
      • Gigabyte Pulse 600w [80+ Bronze]
      • TechFine 1200VA
      • Windows 10 Pro 64 bit
      • Bought it on 5 may,2012 from elephant road.. upgrading started on February,2013 :)
      • SkyView Online [3 mbps]
      • 370 kBps [International] 11mBps [Local]
      • 200/200 kBps [International/local]
    Nirzhar Uchiha's Avatar
    Dhaka, Bangladesh, Bangladesh
    Quote Originally Posted by Mithun View Post
    install latest version of social club.. That is v.1.0.95 or something like that.. That should solve the 'loading screen' prob..had the same kinda experience
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    Mentioning @zOanz .
    Quote Originally Posted by nirzhar View Post
    ok bro....thnx......i try it.........
  1. Max Payne 3
    By aayman in forum Action-Adventure
    Last Post: January 6th, 2014, 13:23
  2. Max payne 3 update issue
    By devilmaycry in forum XBOX
    Last Post: May 19th, 2012, 18:31
  3. Max Payne 3
    By game_o_holic in forum Action-Adventure
    Last Post: May 30th, 2011, 21:30
  4. Max Payne: the movie
    By s.a_rocky in forum Movies & TV
    Last Post: September 22nd, 2008, 16:21
  5. Max Payne, the Movie
    By cRush in forum Trash
    Last Post: July 13th, 2008, 00:17
Page generated in 0.21274 seconds with 14 queries.
