Thread: Suggest me Brand+Model for 20 inch LED monitor
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Question Suggest me Brand+Model for 20 inch LED monitor
    Hi gyz, I'm gonna buy a 20 inch LED monitor. Been using my old Samsung CRT monitor for 6 years. Can you suggest me best Brand+Model with product link and cost available in Bangladesh? I'll fix the budget later. I have HD5570 GPU atm, but going to buy 78xx-79xx after 5-6 months. Thanks in advance.
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Only LG E2040T was available when i bought previous month from Multiplan. There was no Dell,Samsung available. Try IDB first. 20'' is pretty much rare.
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    picture quality is nice and dandy. bought at 10,800/= BDT.
  1. Suggest me a LCD/LED TV within 30-50k . . .
    By Ork7O in forum Help - PC Buying
    Last Post: March 21st, 2012, 19:24
  2. Want to Buy lcd/led monitor 20/22/24/26 inch
    Last Post: March 2nd, 2012, 00:25
  3. Wanna buy a 22 inch LED monitor....Help guys !!!
    By Robin in forum Others PC Hardware
    Last Post: January 4th, 2012, 00:47
  4. Which is the best 21.5 inch LED available in the market?
    By Arif69 in forum Help - General Shopping
    Last Post: October 25th, 2011, 02:48
  5. Want to Buy 15-17 inch LCD monitor
    By йЦммєя³¹ in forum Shop - Gadgets
    Last Post: May 1st, 2009, 02:44
Page generated in 0.15493 seconds with 14 queries.
