Results 1 to 6 of 6
Thread: UPS battery renewal.
    • Blurgon's Gadgets
      • Asus H97-PLUS
      • Intel Core i5 4590 3.30 GHz
      • 8 GB 1333MHz
      • Samsung SSD 850 EVO
      • GTX 1650
      • Samsung 19.5"
      • Fantech Pantheon
      • Bloody A91
      • Logitech F310
      • Thermaltake 350w
      • Power Guard 1200VA
      • Windows 10 PRO
    Blurgon's Avatar
    Dec 2013
    Question UPS battery renewal.
    Hello everyone.
    I am currently using Power Guard UPS 1200VA for 2 years. Generally, it used to give me ~10 minutes backup in a power outage under low load and would start beeping afterwards. Recently though, it starts beeping in a couple of SECONDS after a power outage, under low load, and I always manage to shut down my PC asap, so I do not know the length of time it can give backup now.
    My query is, when do I know it's time to change the UPS battery and where do I change it from if it's required. I purchased this UPS from PC Garden Sylhet.
    Thanks.
    • Sumit Pramanik's Gadgets
      • Asus ROG Strix B360-H Gaming with Xigmatek Leco Plus Chassis
      • Intel Core i7-9700
      • G-Skill Trident Z RGB F4-2400C15-8GTZR*2
      • Samsung SSD 970 EVO Plus 250GB, WD Caviar Black 2TB x 2, WD Caviar Green 500GB
      • ASUS GeForce GTX 960 STRIX-GTX960-DC2OC-4GD5
      • Asus VZ229HE Eye Care 21.5 Inch
      • Microlab B70 Speaker System; Sennheiser HD598SE
      • Corsair K95 RGB Platinum
      • Asus ROG Gladius II
      • Don't need one..........
      • Thermaltek Toughpower Grand 750W RGB
      • N/A
      • Maxgreen 2000VA
      • Windows 10 Professional
      • Upgrade Complete, System Online, All Systems are Stable. Lets ROCK.
      • Quick Online (OK Network and Communications)
      • 40Mbps
      • 40Mbps
    Sumit Pramanik's Avatar
    Oct 2010
    Did you mean it starts beeping frequently after 10min and now doing that after only few seconds? If thats the case your battery is now as good as HARAMBE. So replace it asap. Also check your battery AH rating. You can find battery in IDB or Multiplan. Also all electronics shop near you sell non-branded batteries. You can check those too. Price below 1200tk for 9AH battery for branded ones.
    We all fall down
    We live somehow
    We learn what doesn’t kill us makes us stronger
    • Blurgon's Gadgets
      • Asus H97-PLUS
      • 8 GB 1333MHz
      • GTX 1650
      • Samsung 19.5"
      • Fantech Pantheon
      • Bloody A91
      • Logitech F310
      • Thermaltake 350w
      • Windows 10 PRO
    Blurgon's Avatar
    Dec 2013
    Quote Originally Posted by Sumit Pramanik View Post
    Yes, that is correct. Could you tell me other than not getting ample backup during power outage, what other problems I might face if I don't replace the batteries soon ?
      • N/A
      • Maxgreen 2000VA
      • 40Mbps
      • 40Mbps
    Oct 2010
    Sometimes it can get instant shutdown if proper wattage is not available. Other than that no more problems as far as i know.
    We all fall down
    We live somehow
      • ASUS P8Z77-V Pro
      • Core i5 3570 @4.0 GHz
      • G.Skill ARES 2400 MHz 8GBx2
      • SAMSUNG 850 PRO 256GB
      • AMD RX 570 4GB 1300/1750 1.03v
      • HP Compaq LA26306x 23"
      • Realtek ALC898
      • GAMDIAS Hephaestus P1
      • Cougar Minos X2
      • Skylark
      • 5 Mbps
      • 5 Mbps
    Buy a good pair of batteries. There have been various discussions regarding this subject in BG, you'll have to search for a bit but you'll eventually land on the appropriate thread. I can't think of the brand name at the moment. Replacing the battery is fairly simple and you can do it by yourself.
    • Blurgon's Gadgets
      • Asus H97-PLUS
      • 8 GB 1333MHz
      • GTX 1650
      • Samsung 19.5"
      • Fantech Pantheon
      • Bloody A91
      • Logitech F310
      • Thermaltake 350w
      • Windows 10 PRO
    Blurgon's Avatar
    Dec 2013
    Alright, that's a relief. Thank you for the info.
    I contacted OSGS and they told me it'll cost ~1.1k per battery, didn't mention the AH though, I suppose I'd get 9AH ones if it costs the mentioned price. I'll do my research, thanks for the tip.
Page generated in 0.12680 seconds with 13 queries.
