Creative Inspire T6200 5.1 and SOL Republic Tracks HD
Keyboard:
Logitech MK250 (Wireless)
Mouse:
Logitech B100
Controller:
Logitech Dual Action
Power Supply:
Antec NeoEco 550M Semi-Modular
Optical Drive:
None
Operating System:
Windows 10 Home x64
ISP:
Triangle
Download Speed:
128
Upload Speed:
128
CBA
Suggest me an affordable monitor for color critical work.
I intend to replace my current monitor with one that is well suited for color critical work (e.g. graphics design, photography).
The panel has to be an IPS one. Resolution should be 2k and no less than 24inch and not larger than 27inch. Budget is around 30 but if it's a really good panel I might consider extending it a bit.
Samsung 970 pro 512gb, 850 evo 250gb+1tb, Wd black 5tb, 950 pro, muskin 1tb
Graphics Card:
Gigabyte Aorus RTX 2080 TI
Display:
samsung ku 6290 4k uhd tv, Dell S2716DG
Sound Card:
Sound blaster zxR
Speakers/HPs:
Akg k7xx,Samson sr 850, audio technica ath m50x, ,dt 990 pro, hd 598
Keyboard:
corsair vengeance k95 rgb
Mouse:
logitech g500s, g700s,g502,g402, deathadder chorma on razer goliathus speed edition
Controller:
ps4, xbox one controller
Power Supply:
corsair rm i 1000w
Optical Drive:
None
USB Devices:
32 gb trancend, 64gb sandisk, 16gb kingston
UPS:
None
Operating System:
Windows 10 education, Ubuntu 18.04 LTS
Benchmark Scores:
wei- cpu and ram-7.6 on stock, gfx-7.9
Comment:
thanks a lot to omnipotent creator(as a muslim allah) for my awesome rig, xbox one and ps4
ISP:
Shaw 600 mbps unlimited
Download Speed:
75MB/s
Upload Speed:
Don't upload
Console:
128
Vancouver
Do u guys have dell p2415q in bangladesh? It comes with factory color calibrated with report and overall an excellent 4k 24 inch monitor. Mac osx and windows scale really well with this monitor. I paid like 547 canadian dollar for my unot which is around 34k bdt.
Please suggest me some panels. Thanks!
Viewsonic VX3209-2k. It is a 10-bit panel. 1.07 Billion color. If you know what i mean
You suggesting a 16.7M colored monitor for color critical work? Seriously? I myself using that monitor, of very mediocre level i would say.
And you suggested something that is not within his requirements. Check his requirements first. I felt this was the best that he could get within his budget that meets the requirements.
Not that I am a techie, since you have a good reputation on dealing with these, I am sure you know stuff that I dont. Correct me if I am wrong.Thank you
Conventional display devices use 8-bits per color channel (or 24-bits per pixel) to display images and video. Although this amounts to more than 16 million colors, it still corresponds to a fraction of the colors we perceive in the real-world. This is illustrated in Figure 1, where the green triangle shows the boundaries of the sRGB color space on the CIE-xy chromaticity diagram.
Conventional sRGB compliant 8-bits monitors can only represent the colors that lie in this triangle, while the human eye is capable of perceiving all the colors in the entire chromaticity diagram. This discrepancy is further emphasized by the fact that today’s most professional cameras and printers have a color gamut larger than that of sRGB (such as Adobe RGB shown by the red triangle in Figure 1), creating a bottleneck on the display side.
Graphics Card:
Display:
Sound Card:
Sound blaster zxR
Speakers/HPs:
Keyboard:
Mouse:
Controller:
Power Supply:
corsair rm i 1000w
Optical Drive:
None
USB Devices:
UPS:
None
Operating System:
Benchmark Scores:
Comment:
ISP:
Download Speed:
75MB/s
Upload Speed:
Don't upload
Console:
128
Vancouver
A 32 inch 2k monitor would be a terrible idea, they look blurry as hell, specially if someone is closer to screen. Also unless someone is doing super professional level work like he has a job at million dollar company making ultra accurate videos, you don't need 10 bit panel. As long as the panel is factory calibrated, you are good to go.
Dell p2415q is an excellent choice. But the dell ultrasharp series like the one
@sensei
mentioned would also be a good choice.
Keyboard:
Mouse:
Logitech B100
Controller:
Power Supply:
Optical Drive:
None
Operating System:
Windows 10 Home x64
ISP:
Triangle
Download Speed:
128
Upload Speed:
128
CBA
Thanks everyone for the suggestions! 10-bit panels are mostly useless and a burden unless one works in Hollywood. Besides, no consumer graphics card can natively output 10-bit color and that's reserved for Quadro/FirePro cards only. I don't plan on using 1080p any longer and my new panel has to be a 2k one. Dell UltraSharp U2515H looks like a solid choice but I can't seem to find it in stock anywhere in BD
