Results 1 to 11 of 11
Thread: Urgent::Banglalion wimax connection issue!!!!!
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Question Urgent::Banglalion wimax connection issue!!!!!
    I am facing 2 problems with my modem.....
    1.Sometimes the Signal strength and link quality bar goes empty and can't be found in an hour.
    2.Sometimes the modem disconnects and when it connects again it can't acquire any IP address. After restarting the PC it can acquire IP adress......
    Can anyone give me any solution to these problems............
    I need help badly.............
    Can anyone give the link to update firmware......
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    After restart it gets IP ?? Since when? Put some more info, the rssi, cinr, etc. Btw, what did the customer care say? Seems like a modem issue to me.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    They told me to update the firmware.......
    My knowledge is poor...
    What is RSSI,CNR??
    • Ork7O's Gadgets
      • Asus Xonar DGX
      • Luminous 1000VA
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    ^ look for settings tab>connection info in the blion app,
    Quote Originally Posted by QuadStorm View Post
    What is RSSI,CNR??
    RSSI mean Received Signal Strength Indication
    source: http://en.wikipedia.org/wiki/Receive...gth_indication
    CNR mean Carrier-to-Noise Ratio
    source: https://en.wikipedia.org/wiki/Carrier-to-noise_ratio
    Microsoft .NET Framework 4
    download link: http://www.microsoft.com/en-us/downl....aspx?id=17718
    Problem
    Old banglalion users don't have any way to check cnr or rssi with built-in software.
    General Troubleshooting / Solution
    * Visit Banglalion customer care with modem, tell their duty engineer to update your software.
    * If you don't have good network/air in room then replace your dongle with indoor device.
    Software
    Troubleshooting
    * Do not allow auto login and remove anti-virus which you have.
    * Uninstall all windows recent update, sometime anti-virus also causing problem.
    * Indeed disable windows firewall.
    Hardware
    Troubleshooting
    * Do not use white cable which provided by Banglalion company, Connect your modem directly into usb port.
    * Do not let your modem temperature higher then normal because overheat is always bad for those kind of devices.
    Hope It Helps You.
    Useful Software
    Hard Disk Health Checker
    http://www.panterasoft.com/download/hhealth.exe
    PC information Viewer
    http://www.alexnolan.net/software/SysSpec.exe
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://beta.speedtest.net/result/6780327218.png)
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    What is RSSI,CNR??
    RSSI: http://j.mp/KfYQb5 CNR: http://j.mp/KfYxwV
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    Quote Originally Posted by seaksezar View Post
    CNR mean Communication and Networking Riser
    source: http://en.wikipedia.org/wiki/Communi...tworking_Riser
    Problem
    Software
    Troubleshooting
    Hardware
    Troubleshooting
    Hope It Helps You.
    and why on earth is not using the white cable provided by the company bad.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    I have to go to the customer care.........
    NO WAY WITHOUT THIS!!!
    • Ork7O's Gadgets
      • Asus Xonar DGX
      • Luminous 1000VA
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    Don't. Tell them to send somebody over your place.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    why????
    • Ork7O's Gadgets
      • Asus Xonar DGX
      • Luminous 1000VA
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    When you can get the service being in your turf, why go into their's ?
  1. QUBEE WiMAX connection issue
    By Syeef in forum WiMAX
    Last Post: May 14th, 2012, 12:08
  2. banglalion wimax 256 unlimited
    By Raziel in forum WiMAX
    Last Post: December 6th, 2011, 23:25
  3. Need for speed world with banglalion wimax
    By EEHANMAX in forum Speed Talk
    Last Post: August 16th, 2011, 01:38
  4. Replies: 30
    Last Post: April 3rd, 2011, 20:21
  5. About Banglalion Wimax speed
    By Camouflage in forum WiMAX
    Last Post: October 12th, 2010, 02:07
Page generated in 0.22561 seconds with 14 queries.
