আজকে windows setup দিলাম, কিন্তু ঝামেলায় পরে গেলাম তো
abar সেই generic host problem back
net off হয়ে যায়, PC restart দিতে হয়, ফোরামে কোথাও দেখসিলাম একটা topic এখন খুজে পাইনা।।
কেউ definite solution দাও please....
I bleed red, Man Utd 4ever..
try any of these 4 solutions.
http://www.sizlopedia.com/2007/04/28...process-error/
sniper er 3/4 ta PC te ei prob hoitese koyek din dhore.
i will try these solutions tomorrow.
one cheap solution is, when this message comes up, do not press any button on it, but just move the message window out of sightleft or right of the monitor, becoz it is 'always on top'. then when an memory error message comes up, do the same. this way, net connection keeps working any way. so what you have to do is just not press any button.
no, this one doesn't work that way. if you just leave it there....after 4 or 5 mins, net auto closes, audio gets thrashed etc etc.
well, it happened when, at first, i pressed close message button. but later i followed this no-click-on-message-box practice.. then managed to save net and audio too. in fact, i was having 10-20 messages accumulated at the corner of the screen sometimes.
I had the problem in several PCs. But after installing XP SP3 the problem is gone. So upgrading to SP3 maybe an easy fix.
Try Changing ur date to 2-3 years back and check! :S
(Just a try.. doest hurt)
Giddy can be traced back to the same Germanic root *gud– that has given us the word God
Malicious Worm
see the 18th post :
http://banglagamer.com/forums/f53/br...t-process-t152
hope it works.
Hunt for Tiberium.... dont get infected by it.. its the Healer
same thing/link is posted in this thread, above.. by asif.
that post also really needed some formatting.
