Results 1 to 10 of 10
Thread: Hard Disk Problem - Help Needed
    • schizo55's Gadgets
      • GIGABYTE B75W-D3H
      • Intel Core i5 3550
      • 4GB DDR3
      • 1.5 TB
      • ATI Radeon HD 6750
      • 1440x900
      • microlab 2:1
      • A4TECH
      • Logitech G400s
      • Corsair VS450
      • LITEON
      • Windows 7 Ultimate 64bit
      • Dot Internet / Link3 / Mazedabd
      • 400 kBps
      • No Limit
      • 12
    schizo55's Avatar
    Jan 2010
    Default Hard Disk Problem - Help Needed
    So recently i got a big problem with my hard disk.I got 2 HDD,one 250gb in which my OS is installed and the other 500gb secondary HDD,so yesterday suddenly all the drives of my 500gb HDD vanished.At first i thought my HDD crashed as i saw the error disk boot failure when i restarted my pc but then i reattached the sata cables of the HDD and when i turned on my pc again,it detected the HDD and all the drives were back.All the drives were accessible except one drive which got corrupted but the problem is after a couple of minutes all the drives of tht HDD again vanished.I even tried changing the sata cable but the same thing happens.If i completely turn of my pc and turn it on again i find those drives again but for a couple of minutes,after that it again dissappears.Guys help me out here plz..
    • shohidul's Gadgets
      • Intel dp55wb
      • core i5
      • 4gb
      • 320 gb
      • nvidia gts250
      • samsung 22inch
      • internel
      • a4 tech
      • a4 tech
      • 600 watt
      • sony
      • rohimafroj
      • windows 7 64bit
      • ispros
      • 35-45 KBPS
      • 30-35 KBPS
    shohidul's Avatar
    Mar 2012
    virus or bad sector or cable problem .
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    check ur bios if it detect any hdd, if it does, probably ur problem is virus. Give a scan by nod32 or kasper.
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Do these drives disappear just when you try to access them? Then its a virus. I had the same problem with a secondary HDD
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    @OP, Did you try a fresh installation of OS > A complete scan with an updated AV n safe mode ?? If not, do it. One other thing, did you ever defrag your HDDs???... I am a lil curious you know!
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    go to disk management and see if ur drives are visible from there or not
    • [email protected]'s Gadgets
      • Asrock Z68 extreme 4
      • Core I5 2500k @ 4.4ghz
      • 8 GB corsair 1600 mhz
      • 1 TB hitachi
      • Sapphire HD 7970
      • 21.5 B2230 samsung
      • f&D
      • Thermaltake Smart power 650W
      • Luminious 1000VA
      • Windows 7 64 bit
      • Antaranga
      • 1Mbps
    xer@x's Avatar
    check full computer by latest anti virus
      • GIGABYTE B75W-D3H
      • 4GB DDR3
      • 1.5 TB
      • 1440x900
      • microlab 2:1
      • A4TECH
      • Logitech G400s
      • Corsair VS450
      • LITEON
      • 400 kBps
      • No Limit
      • 12
    schizo55's Avatar
    Jan 2010
    @Reznov the drives just dissapear after a couple of minutes
    @rk7 no i still haven't done a complese os installation and about defragment..i use to do it once in a while bt rarely..
    @optimus prime no the drives are not visible there..already checked
    @[email protected] i already did a scan with avast and found like 4000+ viruses with only 5% scan..
    its probably virus ..so can anyone give me an idea how can i get rid of all this viruses the fastest way??
      • 1 TB hitachi
      • Sapphire HD 7970
      • f&D
      • Luminious 1000VA
      • Windows 7 64 bit
      • Antaranga
      • 1Mbps
    xer@x's Avatar
    Quote Originally Posted by |s c H I z o| View Post
    no shortcut , scan and delete all virus , then install fresh copy of windows , then again scan and delete virus
      • GIGABYTE B75W-D3H
      • 4GB DDR3
      • 1.5 TB
      • 1440x900
      • microlab 2:1
      • A4TECH
      • Logitech G400s
      • Corsair VS450
      • LITEON
      • 400 kBps
      • No Limit
      • 12
    schizo55's Avatar
    Jan 2010
    does anyone have any idea about which virus would be able to cause this???...
    ---------- Post added at 21:02 ---------- Previous post was at 18:29 ----------
    i did another scan but this time did not find any viruses... but the problem remains..
  1. Unknown Hard-disk Problem In Win 7
    By Rorschach in forum Technical Support
    Last Post: February 7th, 2012, 15:39
  2. hard disk crash! Help!
    By sayemcom in forum Technical Support
    Last Post: April 19th, 2011, 23:52
  3. Disk Manager does not detect Hard Disk
    By Flame in forum Technical Support
    Last Post: March 11th, 2011, 11:31
  4. Hard Disk Problem
    By dying4004 in forum Technical Support
    Last Post: August 12th, 2010, 00:09
  5. Want to Buy need 160 GB hard disk
    By ĘŁєčŦЯŐй Shajal in forum Shop - Gadgets
    Last Post: May 20th, 2009, 17:45
Page generated in 0.21386 seconds with 14 queries.
