Results 1 to 15 of 15
Thread: Help. Cpu usage 100% without any running programs
    • ramiz's Gadgets
      • MSI 880GMS - E35
      • AMD Phenom II X4
      • 2 + 4GB Transcend DDR3 1333MHZ
      • Samsung 500GB
      • Gigabyte Radeon 6770
      • Benq GL930
      • Built In Realtek
      • Panasonic RP HTF600
      • 2 Genuine Xbox360 wireless controllers
      • Thermaltake lite power 430W
      • Sony DVD RW
      • Xbox 360 wireless receiver for windows
      • Windows 7 64 Bit Ultimate
    ramiz's Avatar
    Oblivion
    Default Help. Cpu usage 100% without any running programs
    Guys I need help. I downloaded rainmeter and then a skin from deviant art and all of a sudden my pc's cpu usage went to 100% and microsoft security essentials showed that my pc was being attacked by malware. I used MSE and advanced system care, uninstaleed rainmeter, restarted multiple times but to no avail. Pls guys help me out. I'm worried that the pc may be damaged
       0
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    If its a virus, then give a fresh windows setup.
    I bleed red, Man Utd 4ever..
       1
    yup u can try reinstalling windows or just open the task manager & kill the process tht's using 100% cpu!
       1
    Member Riese's Avatar
    Bogra, Bangladesh
    Killing the process that's using 100% cpu works. But to be on the safe side do a virus scan and delete all the infected files. Then do a fresh windows setup.
       1
    • ramiz's Gadgets
      • MSI 880GMS - E35
      • AMD Phenom II X4
      • Samsung 500GB
      • Benq GL930
      • Built In Realtek
      • Sony DVD RW
    ramiz's Avatar
    Oblivion
    Quote Originally Posted by Riese View Post
    Task manager only shows firefox. In safe mode cpu usage is normal 0-3%. I tried to remove/quarintine the virus but failed. I'm a cmoplete noob when it comes to these kind of things. Windows notun kore install korle to shob kichu delete hoe jabe, including game saves.
       0
    Bogra, Bangladesh
    Quote Originally Posted by ramiz View Post
    See in the process tab in task manager.Do a windows setup then a virus scan and delete the infected files. Then again setup windows. To have your saves after the setup backup them. You will most likely find the saves in your my documents folder.
    He who knows nothing think he knows everything.
    He who knows, know that he knows nothing
       1
    maximum game er save pawa jabe documents e. but kisu game like call of duty 5 er save ektu gohine thake tai ota pawa jay na (khujle pawa jay) aar command & conquer niye bipod hote pare...eiii but fresh copy install korar por game gula fresh install korai valo.not only games all the apps... because exe file could be infected!
       1
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    A reinstall of OS wont do nothing. Run a full scan(with a recenty updated AV) in safe mode > save the saved games> reinstall OS> enjoy.
       2 Mobile
    • rextrio's Gadgets
      • gigabyte h61 d2 b3
      • i3 2100
      • adata 4 gb
      • samsung 1 tb
      • sapphire ati hd 5850
      • samsung p2450
      • altec lansing mx6021
      • a4tech
      • razer death adder
      • xbox 360 wired
      • thermaltake toughpower 600watt
      • asus
      • micro 1000va
      • win 7 64 bit
      • broadband
      • 64 kb
      • 30 kb
      • 24
    Jan 2012
    run a full scan with updated AVG anti virus 2012(install it by web),it should be fine if not then do it in safe mode & reinstall OS.
       1
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Virus kill na korte parle try my method. Kill the process then Backup my documents, next C: > users > (name of user) > AppData(if not appears, show hidden files) > Backup Local & Roaming folder. Most of the game files saved in these two folders. Now fresh install OS
    Maximum virus thake Users, Program data, windows folder e. search these folder u will find it.
       1
    • Ork7O's Gadgets
      • Asus Xonar DGX
      • Luminous 1000VA
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    ^What if the hdd is flooded with infected files? He already did a mistake by not scanning the recently downloaded file. He needs to run a full scan of the system. Find and kill the virus(es).
       1 Mobile
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    Download this: http://technet.microsoft.com/en-us/s.../bb896653.aspx (By Microsoft)
    Run it to locate the Process which is using 100% CPU (will be highlighted in red), then kill it.
       1
    • iGx : Itachi's Gadgets
      • MSI Z270 GAMING PRO CARBON ATX LGA1151
      • Intel Core i7-7700 3.6GHz Quad-Core
      • G.Skill Trident Z 16GB (2 x 8GB) DDR4-3200
      • Western Digital Caviar Green 2TB and Samsung 850 EVO-Series 250GB 2.5" SSD
      • GEFORCE GTX 1060
      • ViewSonic VX2270Smh-LED Black 22" 7ms (GTG) HDMI Widescreen LED Backlight LED Monitor IPS panel 250
      • 7.1
      • Steel Serise Siberia V2 & Creative Inspire
      • CORSAIR K95
      • SteelSeries DIABLO + Fnatic Mouse Pad
      • PS3 Controller
      • CORSAIR CX 600
      • Asus DVD ROM RW+-
      • TV CARD, SCANER,Pendrive, wireless Headphone
      • "LIKES" Back-up to 45min
      • MICROSOFT WINDOWS 10 PRO
      • P1567 3DMarks 11
      • Physics Score 3131 ||Graphics score 1430
      • Local <3
      • 8.9MB
      • 6MB
    iGx : Itachi's Avatar
    Khilgaon,Dhaka
    Reinstall ur windows... after that scan da full PC w8 kaspersky ^_^ it will back normal again..
       1
    • ramiz's Gadgets
      • MSI 880GMS - E35
      • AMD Phenom II X4
      • Samsung 500GB
      • Benq GL930
      • Built In Realtek
      • Sony DVD RW
    ramiz's Avatar
    Oblivion
    lol after 2 weeks... Problem fixed long time ago by formatting C: Drive and reinstalling windows. Thanks everyone for your help. BG Rocks.
    @aayman bro pls close the thread
       0
    Closed
       0
  1. Replies: 19
    Last Post: November 29th, 2011, 11:20
  2. My new cpu causing programs crash
    By Overlord in forum CPU
    Last Post: June 4th, 2011, 02:37
  3. Garena high cpu usage
    By cupid0321 in forum Garena Central
    Last Post: May 12th, 2011, 20:51
  4. Excessive CPU usage!!
    By VANGUARD in forum Technical Support
    Last Post: September 18th, 2010, 21:18
Page generated in 0.25290 seconds with 14 queries.
