Results 1 to 20 of 20
Thread: DVD drive problem
    • TaherTheRetard's Gadgets
      • CONSOLE MASTER RACE
      • 136
    Khilgaon
    Default DVD drive problem
    My dvd drive disappears in the middle of any copying process I can open/close the drive though ............ dvd drive appears again after rebooting
    Sounds like it's a problem from the circuit, but just to make sure, change the power cable connector or a molex to SATA power converter if you have one, and the SATA data cable to see if it helps.
      • 136
    Khilgaon
    Quote Originally Posted by K' View Post
    that didn't work and I have an IDE drive
    Time for a new drive ( ´∀`)
    Try changing the IDE cable and see if that helps you, but I believe that the circuit of the drive is wearing out, the last thing you can try is doing a firmware flash, but if your circuitry is messed up, flashing won't help.
    • sadi_warhead's Gadgets
      • MSI G41
      • Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz (4 CPUs)
      • ADATA 4096MB RAM DDR3
      • 1 TB Samsung H3
      • Gigabyte GTX 560OC-1GI 1 GB
      • 22" samsung 2233sw
      • Realtek HD Audio output input
      • Creative 2.1/A4tech headphones
      • BenQ mulitmedia
      • A4 teCH
      • Sony controller
      • Fortex 600w
      • Windows 7 Ultimate 64-bit (6.1, Build 7600)
      • Motamuti-:| :)
      • Ispros
    sadi_warhead's Avatar
    MIRPUR
    Fly High, Do or Die, Dare to Dream, Cheer Extreme!
    just to make completely sure connect that to another pc and play some dvd or write some stuff,if this again happens,buy a new drive.
      • 136
    Khilgaon
    Damn! ekhon tahole laptop>pendrive>pc
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    If you're certain about the IDE cable being faultless then the only thing that could resurrect the drive in normal is a firmware flash. However, this is only worthwhile enough to give a try depending on the duration of use. If the duration of use exceeds beyond more or less two years you better than change that optical rom with another one.
      • 136
    Khilgaon
    Goodbye my last IDE drive........ you served me well for the last 6 years
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    I've bought a new Samsung SH 222 4/5 days ago. Superb performance! You can check out this dvd wrtr.
      • 136
    Khilgaon
    Quote Originally Posted by Reznov View Post
    bro koto nise?
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    1500/= . Dont forget to check the serial number written onto the product and box. They both must be similar. Market is full of unboxed products
    And don't forget to update your firmware too, it helps, trust me!
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    is there any risk to do it Romulus bro?
    bhai wat is Romulus ???
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    @deadorchid , stop spamming and reviving old threadsm? :/
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    .^ after seeing his post i was like. . .rofl . . . . @dipanzan , here is another one.
      • 136
    Khilgaon
    how to update firmware? (yes I'm a n00b)
    Thanks
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by fAzIL p0lA View Post
    Thanks
    Let me know about your updates.
  1. Help please! DVD Drive not found/not working (Vista/HP DV9000)
    By ScS :: XTR in forum Technical Support
    Last Post: May 7th, 2011, 17:00
  2. Problem with New HARD DRIVE.....
    By zaman_177 in forum Technical Support
    Last Post: September 6th, 2010, 21:07
  3. Problem with my new hard drive,,,
    By zaman_177 in forum Others PC Hardware
    Last Post: July 17th, 2010, 11:06
  4. Replies: 6
    Last Post: June 13th, 2010, 19:25
  5. Buying a new DVD drive need advice
    By TAHMID in forum Technical Support
    Last Post: March 12th, 2009, 22:46
Page generated in 0.28566 seconds with 14 queries.
