Results 1 to 6 of 6
Thread: argent help need for buying gpu
    • redprince's Gadgets
      • GiGABYTE INTEL G31M-ES2C
      • Intel core 2 duo E7400 @ 2.80 ~OC 3.00
      • 2 GB DDR2
      • 320 GB western digital
      • Sapphare ATI RADEON HD 6570 DDR3 2GB
      • 19inch Samsung LCD(2ms response time)
      • Microlab A-300
      • LEXMA
      • A4TECH Wireless mouse
      • X-box 360
      • Gigabyte 460W
      • Windows 8.1 x64 pro
      • 5 Years old
      • Metaphor digital media
      • 2 Mbps
      • 3 mbps
    redprince's Avatar
    Default argent help need for buying gpu
    Since I want to buy an android smartphone, I have only 5k- 6k left for upgrade my gpu .Anyone can suggest me a gpu within 6k? I need ddr3/ddr5 cause card can be 2nd hand. Anyone here to help??Thanks
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Look for an used 5670 ddr3/ddr5. 5670 ddr3 was 6k-6.3k just a few months ago.
    Your best bet is to look for a used 5750/6750 and a delux power supply.
    Amd hd 5670/amd hd 6670.
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    Can your friend extend his/her budget for a new PSU, if so, get the giga 6750 (Used of course!). If not, go for a new giga 6570 for 6k.
      • 2 GB DDR2
      • Microlab A-300
      • LEXMA
      • X-box 360
      • Gigabyte 460W
      • 5 Years old
      • 2 Mbps
      • 3 mbps
    redprince's Avatar
    Forgot to mention that I already have a psu gigabyte 460w ..Need ddr5 used grafix
  1. Gpu buying Help
    By Rorschach in forum Help - PC Buying
    Last Post: April 15th, 2012, 19:57
  2. GPU Buying help :)
    By Vиms Vm in forum GPU
    Last Post: December 11th, 2011, 15:30
  3. GPU buying help !
    By Saz1d in forum Help - PC Buying
    Last Post: November 24th, 2011, 21:26
  4. Help buying GPU :|
    By error in forum Help - PC Buying
    Last Post: January 12th, 2011, 04:36
  5. help for buying a gpu
    By Ratul107 in forum GPU
    Last Post: August 19th, 2010, 07:18
Page generated in 0.17940 seconds with 14 queries.
