Thread: Philips 224el2sb 21.5" LED Monitor
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    Default Philips 224el2sb 21.5" LED Monitor
    A friend of mine wants to sell his monitor Philips 224el2sb....
    Bought from Computer source with 16.7k..
    Warranty is there... the pic of the document will be provided shortly
    Price:15k (fixed)
    Link: http://www.computersourcebd.com/Philips/Monitor/224EL2SB_654.html
    Sellers number: 01673337903
    N
    ote:
    1. No offtopics
    2. if u want to buy, then notify here and call the seller
    3. Don't Pm ME
    4. If u book the product then u have to take it within 24 hours
    5. No price suggestions plz
    Thank you
    • wolf's Gadgets
      • Asus p5g41c-m lx
      • Core 2 Duo E7500 2.93GHz
      • 2x2GB DDR3 Twinmos
      • Samsung 500 GB
      • Gigabyte Radeon HD 6850 1GB GDDR5
      • Samsung SyncMaster 2033sw
      • Delta 500w
      • Transcend 500GB StoreJet 25M
      • Windows 7
    wolf's Avatar
    Can you mention the purchase date bro
      • ASROCK h81-GL
      • WD 1tb BLUE
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    panel type: TFT-LCD
    •Backlight type: W-LED system
    •Panel Size: 21.5 inch/54.6 cm
    •Aspect ratio: 16:9
    •Optimum resolution: 1920 x 1080 @ 60 Hz
    •Response time (typical): 5 ms
    •Brightness: 250 cd/m²
    •SmartContrast: 20,000,000:1
    •Pixel pitch: 0.248 x 0.248 mm
    •Viewing angle: 176º (H)/170º (V), @ C/R > 5
    •Picture enhancement: SmartImage Lite
    •Display colours: 16.7 M
    •Scanning Frequency: 30–83 kHz (H)/56–75 Hz (V)
    •sRGB
    Connectivity
    •Signal Input: VGA (Analogue), DVI-D (digital, HDCP), HDMI
    •Sync Input: Separate Sync, Sync on Green
    •Audio In/Out: Stereo Audio, PC audio-in, Earphone out (3.5 mm jack) x 1
    Convenience
    •Built-in Audio: 1.5 W x 2
    •User convenience: SmartImage lite, Input, Volume, Menu, Power On/Off
    •OSD Languages: English, French, German, Italian, Russian, Simplified Chinese, Spanish, Portuguese, Turkish
    •Other convenience: VESA mount (100 x 100 mm), Kensington lock
    •Plug and Play Compatibility: DDC/CI, Mac OS X, Windows 7 / Vista, sRGB
    Stand
    •Tilt: -5/+20 degree
    Power
    •On mode: 17 W (EnergyStar 5.0 test method)
    •Standby mode: <0.5 W
    •Off mode: < 0.5 W
    •Power LED indicator: Operation - White, Standby mode - White (flashing)
    •Power supply: Built-in, 100-240 VAC, 50/60 Hz
    Dimensions
    •Product with stand (mm): 505 x 484 x 249 mm
    •Product without stand (mm): 505 x 351 x 59 mm
    •Packaging in mm (W x H x D): 565 x 465 x 155 mm
    Weight
    •Product with stand (kg): 4.15 kg
    •Product without stand (kg): 3.65 kg
    •Product with packaging (kg): 6.00 kg
    Operating conditions
    •Temperature range (operation): 0°C to 40°C °C
    •Temperature range (storage): -20°C to 60°C °C
    •Relative humidity: 20–80% %
    •MTBF: 30,000 hour(s)
    Sustainability
    •Environmental and energy: RoHS, EPEAT Silver, EnergyStar 5.0
    •Recyclable packaging material: 100 %
    Compliance and standards
    •Regulatory Approvals: BSMI, CE Mark, FCC, Class B, GOST, UL/cUL
    Cabinet
    •Colour: Black/Black
    •Finish: Glossy
    ---------- Post added at 08:03 ---------- Previous post was at 08:01 ----------
    @dipanzan bhaiya, plz close the thread.. My frnd doesn't want to sell it now... Sorry for the inconvinience
  1. 20" LED monitor
    Last Post: November 23rd, 2010, 01:39
  2. Replies: 0
    Last Post: August 10th, 2010, 03:00
  3. Sale (Used) Philips 107S6 17" CRT monitor
    By outragedhuman in forum Shop - Gadgets
    Last Post: May 31st, 2010, 02:44
  4. Sale (Used) Philips 21.5" lcd monitor with hdmi port
    By CHR.XR in forum Shop - Gadgets
    Last Post: April 30th, 2010, 00:16
  5. Sale (Used) Philips 17" Silver Black CRT monitor
    By minitt in forum Shop - Gadgets
    Last Post: July 11th, 2009, 22:04
Page generated in 0.16463 seconds with 14 queries.
