Thread: help with IPS
    • Nirzhar Uchiha's Gadgets
      • ASrock B75 Pro3-M
      • Intel Core i7 2600 @3.40 ghz
      • 2x 4 GB Transcend 1333 mhz
      • Toshiba 1TB + Adata 128gb SSD
      • MSI GTX 770 2GB OC
      • LG 22MP65HQ 22" 1080p IPS LED
      • Creative SB X-fi Titaniium
      • On Ear: Sony MDR XB950BT / IEM: Soundmagic es18
      • Cooler Master Octane Keyboard
      • Logitech M280 Wireless
      • Xbox One + DualShock 4
      • Gigabyte Pulse 600w [80+ Bronze]
      • TechFine 1200VA
      • Windows 10 Pro 64 bit
      • Bought it on 5 may,2012 from elephant road.. upgrading started on February,2013 :)
      • SkyView Online [3 mbps]
      • 370 kBps [International] 11mBps [Local]
      • 200/200 kBps [International/local]
    Nirzhar Uchiha's Avatar
    Dhaka, Bangladesh, Bangladesh
    Default help with IPS
    we have a in gen 550 VA IPS
    It was working fine.. Untill rat e current gelo.. And instead of supplying power.. It showed Low Battery... Though the battery was full.. Then when current came every light n fan that was connected to the IPS stopped working...even the IPS isnt charging.. Its showing low battery... Bathroom er light.. Tv choltese..jeigula ips er shathe connected chilo na... What can we do .. Anyone know ???
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    circuit breaker ta check koren.... Circuit akta hoitoba poray gasay.... The same happened with us months ago...
      • ASrock B75 Pro3-M
      • TechFine 1200VA
    well.. It got fixed automatically.. twice this happened :/
      • ASROCK h81-GL
      • WD 1tb BLUE
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    bashai monay hoy wiring er problem asay... Electrition anai check koiren?
    ---------- Post added at 00:59 ---------- Previous post was at 00:54 ----------
    wiring er prob ta actually wen current asay but ips is showing that current nai and its giving its power... But some components which r supposed to work with the current on is working with the help of the ips....
    Another thing, call the customer care
  1. can pc be run with an ips
    By Nirzhar Uchiha in forum Miscellaneous Topics
    Last Post: April 14th, 2012, 17:32
  2. IPS+UPS backup for PC?
    By Flame in forum Technical Support
    Last Post: March 30th, 2012, 21:43
  3. Urgent IPS help needed!
    By shaikh_imtiaj in forum Help - General Shopping
    Last Post: June 9th, 2011, 22:46
  4. IPS with PC
    Last Post: July 17th, 2010, 13:33
  5. Want to know about IPS
    By naruto in forum Miscellaneous Topics
    Last Post: April 6th, 2010, 20:12
Page generated in 0.16298 seconds with 14 queries.
