Results 1 to 20 of 21
Thread: Need Help!!!!!!!!!!!
    • Badhon's Gadgets
      • GIGABYTE GA-G31M-ES2C (Rev. 1.x) (Intel G31 Chipset)
      • Intel Pentium Dual-Core E5200 (2.5 GHz, 800 FSB, 2 MB L2 Cache, 45nm) (Default Clock)
      • 1x Patriot 2GB DDR2 800 Bus (Single Channel) (Crappy Brand)
      • SAMSUNG F1 320GB SATA 7200RPM
      • SAMSUNG SyncMaster 550s 15" (Max. Resolution 1024x768) (White)
      • Onboard (Realtek 8-Channel HD)
      • Microlab M-119 2:1 Amplified Subwoofer System (Black)
      • Perfect
      • Leno Optical
      • USB Network Joystic
      • Value-Top 400w
      • LiteON 16x DVD-ROM
      • Windows 7 Ultimate x86 Genuine
      • My Girlfriend
      • Avg. 30-40 KBps.
      • Slower Than A Turtles
    Badhon's Avatar
    Petaling Jaya
    Unhappy Need Help!!!!!!!!!!!
    Ami Firefox Diye Jokhoni Kono Site E Access Korte Jai Tokhoni Ei Page Ta Ase:
Name:	I'm ¤¤¤¤ed.jpg
    Then Je Site E Dukte Chaitesi Kono Motei Ase Nah. So FireFox Diye Kono Bhabei Kono Site E Access Korte Partesi Nah. Keu Bolte Parben Kibhabe Ei Faltu Problem Hoite Mukkti Pabo???? Need Help!!!!!!!!!!!!!!
    A strong man doesn't need to read the future, he makes his own
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Clear history and cookies.
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    there might be some trojans blocking your internet access. do as hrishat said. also start msconfig and disable any software entries from startup which seems unfamiliar to you.restart and see if it works.
    Member TooCool's Avatar
    New York City
    Follow these instructions:
    Tools > Options > Advanced > Network > Settings > NO PROXY.
    That should fix the problem.
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    Quote Originally Posted by hrishat View Post
    Ja Korar Sobi Korsi. History R Cookies Koekbar Clean Korsi But Jei Lau Hei Kodu
    ---------- Post added at 09:33 ---------- Previous post was at 09:32 ----------
    Nah Emon Kono Software To Pailam Nah Jeta Unfamiliar
    ---------- Post added at 09:35 ---------- Previous post was at 09:33 ----------
    Quote Originally Posted by TooCool View Post
    Oita Unchecked Deyay Ase
    Different browser eo same problem hoy?
    New York City
    Thats weird, this is usually a problem associated with Proxies. If you're not set to proxy IP, then maybe you've unknowingly installed some sort of proxy add-on or tool bar perhaps? Try uninstalling and re-installing your browser.
    Yes, what's up with the other browsers?
    Disable recently installed add-ons and contact your ISP. :-S
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Contact your isp if problem persist.
    ---------- Post added at 21:31 ---------- Previous post was at 21:30 ----------
    http://en.wikipedia.org/wiki/Zscaler
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    Sudhu FireFox.
    Quote Originally Posted by Badhon View Post
    Sudhu FireFox.
    use opera then.
    I guess you already tried uninstall/reinstall. Do that once more and delete that Mozila folder from
    users/appdata/local/
    users/appdata/roaming/
    then install again.
    And don't forget to try an older version.
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    use opera then.
    then install again.
    Thanks 4 Help. But Ami Ekhon Comodo Dragon Use Kortesi. Mozila Amar Jonno Best Coz Oita Diya Ami Sob Kisui Kori. Ager Moto Firay Ante Parle Amar Jonno Onek Better Hobe. Dekhi Ajke Raate Da-Chapati Niya Bosbo
    da chapati diya kaj na hole amare boilen, ekta atom bomb pathaia diboni.
    Edit: ki ki addon use korten ff e?
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    List Dibo????????
    List Dibo????????
    what how many?:0
    I'd like to see that anyway.
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    what how many?:0
    Hisab Kore Dekhlam Pray 50 Er Kasakasi, 49Ta
    ff er startup time koy ghonta? I mean koto shomoy lage?
    ---------- Post added at 23:29 ---------- Previous post was at 23:24 ----------
    This is really making me more interested about the addons you use. Addon gular ekta screenshot diye den. You won't have to type that much names then.
    O r ff shomporke apnake advise dea amar thik hoy ni bole mone hocche. Maa er kache nana barir golpo hoye gese r ki.
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    Start Up Hoite Beshi Somoy Laage Nah. R Sob Add-Ons E Kajer, Be-Kajer Kono Add-Ons Nai.
    ScreenShot Kalke Dite Parbo. R Last Er Line Gula Lojja Dilo Amare But Ami Eto Pro Nah
    tateu cholbe. onek kajer add on shomporke jana jabe.
    Ami amar shob kajer jonno Opera use kori btw. and I really like it. ff o kichu kichu kajer jonne babohar kori.
    at least better than me.
    • Badhon's Gadgets
      • Perfect
      • Leno Optical
      • Value-Top 400w
      • My Girlfriend
      • Avg. 30-40 KBps.
    Badhon's Avatar
    Petaling Jaya
    Opera Slooowwww.....R Je Porimane Temp File Create Kore, Kheyal Na Korle C Drive E Bishal Jaiga Mere Bose Thake. Ami Ei Karone Opera Use Kori Na (Jodio PC Te Ase). Comodo Ekhon Bhorosha.
    Again Lojja!!!!!!!!
Page generated in 0.30685 seconds with 14 queries.
