Results 1 to 20 of 20
Thread: Cooler Master HTK-002 thermal compound
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Default Cooler Master HTK-002 thermal compound
    Hello there...
    I am recently planning to bring "Cooler Master HTK-002 thermal compound". My friend found it cheap in Malaysia. Is this compound any good? Point should be noted that I am not an OCer. That thermal compound will be used with Stock clocked CPU and a nearly dead GPU.
    Thanks for keeping interest in this post!
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    Sorry for OT, If you don't wanna OC, what u gonna do with TIM then????
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by Raziel View Post
    Cuz My CPU temp is rising like the living-deads day by day.
    Just before a year ago I RMAed my mobo and then the stupid shopkeeper placed the CPU with the new mobo without any kind of thermal contact! After figuring out that, I bought a 100taka TIM tube and applied it. This TIM is good, but not that so good for this summer. Now I am getting 78C max while gaming and it will increase more and more AFAIK
    and about the GPU.... I owe a nearly dead 8400GS. It has 70C minimum temp . Never used to know the max cuz the PC stops responding or restarts while putting load on the GPU. I tried to run it by placing a spinning 80mm fan adjacent to it and the result was good. The temps were staying around 45-55C. So why not try some cheap TIM? You can name it "A Project".
    Badhon vai.... PSU er paper ta ki khuija pailenna?
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    Quote Originally Posted by Reznov View Post
    OO now i get your need for TIM. Wish u a cold winter inside your casing. and i did find papers of psu but u said you are gone outta dhaka, so didn't bother. Want to take papers now??
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Thanks for your complements. But please give me an idea about the quality of this Cooler Master HTK-002. Will it be good enough? I somewhere read that conductive TIMs are not recommended for GPU and I am not getting idea whether it is conductive or not. Plz suggest me about the quality and conductivity.
    R bro paper tar scan/captured image holeo hobe.
    ---------- Post added at 23:41 ---------- Previous post was at 18:07 ----------
    Seems like no one has idea about this TIM.. How unlucky I am
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    Sorry bro, i've little idea about this TIM, but if it's white and ceremic based, it's suitable for your GPU. It has less conductivity. And it'll not be like AS but as u don't OC it'll perform good. Remember to clean heatsink surface by Isopropyl based cleaner. othewise u won't get desired performance. Ask your friend if he can get these. Ar paper ta ki akhane post kore dibo, naki mail kore dibo? Pm me ur e-mail address.
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    This thing is silicon based. I'm afraid that it wont suit the GPU. I will better look for MX-4. I wonder where the BG TIM experts are now!
    I use hexisol which has 70% W/W Isopropyl and hope that it will do the job.
    Regards
    ***Its dielectric, but not so effective. Just fine as replacement for the stock TIMs.
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    I don't know much details about this particular paste but no matter how good the TIM is, the performance won't be that much significant if you're intending to use it under stock HS. With a little bit of caution, almost every types of TIM can be used on chips like GPU. If the paste is conductive type just use a single drop of TIM on the chip so that it won't overflow when pressed by HS. For high viscous pastes, apply paste on the chip first and then spread it neatly.
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by Mahfuz View Post
    Thanks thanks. Mahfuz vai asen kmn?
    I googled about that TIM. Now thinking about MX-4.
    100taka stupid TIM theke egulo te to ektu holeo valo result asar kotha.. taina vai?
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus 18X DVD RW
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    Quote Originally Posted by reznov View Post
    thanks thanks. Mahfuz vai asen kmn?
    I googled about that tim. Now thinking about mx-4.
    100taka stupid tim theke egulo te to ektu holeo valo result asar kotha.. Taina vai?
    এইতো চলে যাচ্ছে একরকম আর কি আপনার কি অবস্থা?
    আর হ্যা, ১০০টাকার পেষ্টের সাথে mx-4 এর তুলনা করার কোন মানে হয় না। দামের তুলনায় mx-4 অনেক ভালো পেষ্ট। আইডলে তেমন কোন ডিফারেন্স না পেলেও লোডে অবশ্যই স্টক পেষ্ট কিংবা ১০০ টাকার পেষ্টের চেয়ে ভালো ফল পাবেন। কিন্তু, স্টক কুলারের বদলে যদি ভালো কোন আফটারমার্কেট কুলারে mx-4 প্রসেসর oc করে ব্যবহার করতেন তাহলে মোটামোটি বিশাল ব্যবধান পাওয়ার আশা ছিলো। ব্যাপার না, পেষ্ট আনায় রাখনে, কয়দিন পরে একটা আফটারমার্কেট কুলার কিনে নিয়েন !
    • pcgamer's Gadgets
      • Gigabyte GA-Z87-HD3
      • i5 4670k
      • CORSAIR Vengeance 4 GB*2=8 GB DDR3 1600
      • Samsung 850 EVO 250GB, 1 TB WD Blue
      • ASUS ROG STRIX Radeon Rx 480 8GB OC
      • Samsung BX2035 LED LCD 20 inch
      • Onbord
      • Creative Labs Inspire 4400 4.1
      • A4TECH Multimedia
      • A4TECH
      • Asus U-75 HA 750 Watt
      • Asus DVD Writer
      • 1200 va (Battery-2x12volt 7.2 amp)
      • Windows 7 64-bit
      • Need to Update GPU
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    Dhaka, Bangladesh, Bangladesh
    Bro tumi jodi MX-4 pao, tailay amar jonno akta anayo. If you want I can pay you advance, I just need to know its price in Malaysia.
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Asi Alhamdulillah.. apnere to BG te ektu kom dekhi edaning
    Vai mobo to DG31. ai mobo dia OC kora r govt office a ghus chara kam korano ekoi rokom osomvob bepar. Intel Integratot toolkit diye chesta korsilam khub ekta subidha korte parini. kisu taka jomle system tai bodle felte hobe r ki...
    ---------- Post added April 15th, 2012 at 00:23 ---------- Previous post was April 14th, 2012 at 23:55 ----------
    Quote Originally Posted by pcgamer View Post
    It will be pleasure. Ami confirmed hole apnake PM diye debo. But delivering it to you would be a problem as I dont live in Dhaka anymore. you may have to come Md.pur or Rampura. And about the price ... MX-4 is around 38RM. The Cooler master is only 12RM there !
    Get the MX-4, you won't be disappointed. Or better yet, try the Phobya HeGrease Extreme if you want the best performance and is just a below the Indigo Xtreme.
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    I will try. But, what do these words mean? >Phobya HeGrease Extreme, Indigo Xtreme.
    The first one is a TIM while the latter is also a TIM but it's more like a metal cap over your IHS and very expensive. The Phobya is excellent btw and costs similar to that of MX-4.
    • pcgamer's Gadgets
      • i5 4670k
      • Onbord
      • A4TECH Multimedia
      • A4TECH
      • Asus DVD Writer
      • Windows 7 64-bit
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    Any updates?
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    Any updates?
    It will take minimum two months due to late departure of my frnd.
    He will inform the price shortly. Then I will let you know the rate. Regards
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    • pcgamer's Gadgets
      • i5 4670k
      • Onbord
      • A4TECH Multimedia
      • A4TECH
      • Asus DVD Writer
      • Windows 7 64-bit
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    Thanks. I have talked about it with dipanzan. Hope I will get MX-4 .
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    and We Will be cool again
  1. Sale (New) Cooler Master thermal compound
    Last Post: February 15th, 2012, 03:35
  2. Sale (New) 1x Arctic Cooling MX-4 Thermal Compound
    By avas911 in forum Shop - Gadgets
    Last Post: January 22nd, 2012, 11:05
  3. Thermal compound
    By Raziel in forum Others PC Hardware
    Last Post: June 14th, 2011, 01:24
  4. What is the Best Way to Apply Thermal Compound?
    By salmanshah in forum Tech News
    Last Post: June 10th, 2011, 10:57
  5. Replies: 5
    Last Post: June 9th, 2011, 15:34
Page generated in 0.31813 seconds with 14 queries.
